Confused about towing capacity
Discussion in 'Towing & Hauling' started by MXPCUS, Apr 18, 2021.
  1. Apr 18, 2021 at 2:53 PM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Still a new experience owning a truck. Do I have a 1/2 ton or 3/4 ton truck? My payload is 1435 lbs, but my towing capacity is 7800 lbs? I don't understand
  2. Apr 18, 2021 at 3:15 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    You have a halfton, which is, admittedly, an outdated term. It might be easier for you to think of them as 1500/2500/3500 series trucks, rather than 1/2, 3/4 and 1-tons.
    ColoradoTJ and onesojourner like this.
  3. Apr 20, 2021 at 1:17 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Look at the sticker in the driver door sill for your trucks payload info
  4. Apr 20, 2021 at 2:09 PM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    You have a 1/2 ton that weighs 6900lbs. The payload capacity is 1435lbs. That’s the max load inside the truck and in the bed. Max towing capacity is 7800lbs. That’s the max load for towing a trailer. Does that make sense?
    MXPCUS[OP] likes this.
  5. Apr 20, 2021 at 2:32 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    You have a Class 2a truck, or better known as a 1/2 ton. Classes are based on the GVWR of the vehicle.
    https://en.wikipedia.org/wiki/Truck_classification
    3/4 tons are class 2b, 1 tons are class 3. Towing capability has no bearing on truck classification, only GVWR. GVWR = curb weight + payload
    Cpl_Punishment likes this.
  6. Apr 20, 2021 at 2:37 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    If you are going to Canada be care full not to be over loaded. They would not let a friend of mine across because he was overloaded.
    He was in a Ram 2500 diesel with an extra 40 gal fuel tank and a 25' 5th wheel. The 5th wheel loaded was weight 7,200 lbs.
    It was the truck that was overloaded.
    MXPCUS[OP] and BravoDeltaRomeo like this.
  7. Apr 20, 2021 at 3:01 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    So does this mean you can tow 7,800LBS and have 1435lb in the bed as well?
  8. Apr 20, 2021 at 3:07 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  9. Apr 20, 2021 at 3:14 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    No. Because the tongue weight from the trailer counts against the payload. At least 10% of the trailer weight should be on the tongue. So, in this example, tongue weight would be at least 780 pounds leaving you 655 pounds in the truck for passengers and gear.
  10. Apr 20, 2021 at 3:51 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Probably depends where you are. In Alberta you seem to be able to do what you want (including tandem towing with a fifth wheel) as long as you're not blatantly over weight. In BC you can't tandem tow, fifth wheel or otherwise.
  11. Apr 20, 2021 at 4:52 PM
    Kanobi13
    Kanobi13 New Member
    Hmm doubt that they are no where near payload or towing unless had 420 goodies in cab hidden.
  12. Apr 20, 2021 at 5:01 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Those are legal in Canada now.
    BravoDeltaRomeo likes this.
  13. Apr 20, 2021 at 5:02 PM
    Kanobi13
    Kanobi13 New Member
    Awesome they just legalized in my state now just need federal to legalize
  14. Apr 20, 2021 at 5:21 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    They are....but if you get stopped with that much, you'll be charged with Trafficking. :rasta:
  15. Apr 20, 2021 at 5:25 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    True. I was thinking of a small amount in the cab, not 7200 lbs in the trailer...
  16. Apr 20, 2021 at 5:41 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Forget about the stickers on your truck, if you want to know the true towing and payload capacity, find the GCWR and GVWR for your truck, which should be in your manual. Everything you add to your truck, like a person, bigger tires, bed liner, etc, reduces your towing and cargo carrying capacity.
    GCWR for your truck, less the total weight of your truck (weigh it), including any cargo and passengers, is your towing capacity.
    GVWR, less the actual weight of your truck and everything in it (weight it), is your cargo capacity.
    It's that simple.
