  1. Apr 9, 2021 at 10:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  2. Apr 9, 2021 at 10:39 PM
    empty_lord
    05 rollover special
  3. Apr 10, 2021 at 6:46 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Had one of these. Actually it's what I traded in for the Tundra. Was gonna keep longer, but one of the kids left a sippy cup full of milk under the passenger seat and it was in there a while. Milk turnt and leaked out onto the carpet. Just couldn't get the smell out. Had the wing and the faux wood interior trim pieces. Disc changer in the dash with a 3 disc cartridge thingy. Was a great car. Boring, but dependable.
  4. Apr 10, 2021 at 11:07 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What on earth is this thing and why does it have a mustang on the grille?
    FrenchToasty and NWPirate like this.
  5. Apr 10, 2021 at 11:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That's the new mustang sedan.
    Jack McCarthy likes this.
  6. Apr 10, 2021 at 11:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Someone pissed in the trash can. Good to be back in my hometown. :D
  7. Apr 10, 2021 at 12:02 PM
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    Mach E I believe. EV mustang
  8. Apr 10, 2021 at 12:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Apr 10, 2021 at 12:47 PM
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    I can already picture people modding the Mach E to put in something like the Maserati $3,000 active speaker exhaust pipe to sound like a v8.
    Tundra2 likes this.
  10. Apr 10, 2021 at 1:18 PM
    NWPirate
    Zach
    WA
    Ford EcoBoost too right?
    :puke:
  11. Apr 10, 2021 at 2:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looking at my truck in the plate glass window of this building it appears that I've burnt out one of the led chips on the pass side bulb. Appears to be the "outer" side of the housing that dark again. Check this photo from my projector install before I went back to OEM. It was the drivers side back then. Passenger side now.
    When I replaced with Katanas the other one was burnt out on one chip also. I assumed it was crummy LEDs.
    Odd that this is number two. Anyone have ideas on where I can start checking for reasons why this would be happening?
    Everything here is pretty much stock. Stock wiring. Relatively new relay, and foglight switch.
  12. Apr 10, 2021 at 2:58 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Assumed you were still in penis cola campground and ran across Elvis decorated bathroom !
    Darkness and Tundra2[QUOTED] like this.
  13. Apr 10, 2021 at 2:59 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    off-brand 1st Gen
    no sparky here, but a bad ground would allow irregular current that would shorten life of a delicate device.
  14. Apr 10, 2021 at 3:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Nope, back in KY.
    A return to budding trees, and thunderstorms on the horizon. Smell of rain in the air, and piss on the floor. Used shit tickets aplenty.
    I'll have to investigate when I get time. Still unpacking, mostly.
    chrisb and NUDRAT[QUOTED][OP] like this.
  15. Apr 10, 2021 at 4:28 PM
    empty_lord
    05 rollover special
    Just the bulbs of only one diode died
    Tundra2[QUOTED] likes this.
  16. Apr 10, 2021 at 4:54 PM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    I gave the 'Rolla some much needed maintenance before touching the truck today. Car got an oil change plus I replaced the O-ring on the timing chain tensioner I'm pretty sure was leaking. @empty_lord Have you seen any other common oil leaks on the 1ZZFEs?
    Turned the crank until I heard the tensioner click.
    Drove it afterwards and it ran great. I decided to treat the roof rust with some Rustoleum rust reformer. I will do at least one layer with flat black rattle can - don't really care how nice it looks.
    After I toyed around with the car I messed with the Tundy and did a drain-and fill of both the transmission and transfer case. Transmission spat out around 3.7ish quarts and was only slightly discolored. The pan was dropped around 70K ago so I will continue to just drain and fill, next one will happen when I do the engine oil which won't be due for a bit.
    With my setup the dome lights aren't too helpful even with LEDs. I'm working on adding some LED strips, will square it out and maybe add another strip of lights down the middle. I bought some fabric I plan to tack on the headliner because I'm sick of the current color. I won't do the whole headliner, just inside the square created by the light strips
    BubbaW and FrenchToasty like this.
  17. Apr 10, 2021 at 4:56 PM
    empty_lord
    05 rollover special
    Headgaskets like to seep out the back of the motor, but never terrible. Other than that valve cover gasket or timing cover seeps. Mine leaked most of its life. But never enough to worry. Treat that engine good and it’ll be with you the rest of your life.
  18. Apr 10, 2021 at 5:03 PM
    des2mtn
    Tonto cover
    Good to know. It's never been a terrible leak but enough to keep an eye on. Car's got about 150K and my Tundra has 155K - hoping to treat both right the rest of my life, if life allows.
  19. Apr 10, 2021 at 5:17 PM
    empty_lord
    05 rollover special
    The 06 corolla I had made it to 880k before the accident. And even with the axle shoved through the engine block and hitting the crank, it ran like a fucking top. I loved that little shitbox. The car I took my drivers test in
    chrisb likes this.
  20. Apr 10, 2021 at 5:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Check this, and check this too. Another idea brought to you by drunk me.
    FrenchToasty and des2mtn[QUOTED] like this.
  21. Apr 10, 2021 at 5:18 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    That's some serious bling there, maybe even add an ornament !
    GODZILLA and des2mtn[QUOTED] like this.
  22. Apr 10, 2021 at 5:23 PM
    des2mtn
    Tonto cover
    Oh you wait, they change color. It'll be like a karaoke bar inside.
    BubbaW[QUOTED] and Tundra2 like this.
  23. Apr 10, 2021 at 5:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. Apr 10, 2021 at 5:31 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    Now you got me thinking of Saturday Night Fever and a new mirror ornament for ya but I digress !
    Tundra2 likes this.
  25. Apr 10, 2021 at 7:08 PM
    FirstGenVol Brake Czar
    2002 AC
    I don't think I ever shared this video. This is where the Taco guys talked about me going so slow. It was true.
    This is a few miles from the TN border in NC. It took us 3 hours to go around 6 miles. I learned that my truck gets real hot in 4Hi at low speeds. Going forward I'm pretty much going to stay in 4Lo if I'm going slow.
    https://youtu.be/8hG-NHw8KKE
    MS22, speedtre, Jack McCarthy and 4 others like this.
  26. Apr 10, 2021 at 7:10 PM
    NUDRAT
    SW CT
    off-brand 1st Gen
    Looks like you did it quite well.
    MS22 and FirstGenVol[QUOTED] like this.
  27. Apr 10, 2021 at 7:12 PM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Keep driving it slow, they won’t own their trucks in a few years
    chrisb, Darkness and des2mtn like this.
  28. Apr 10, 2021 at 7:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    They must be used to this. Only need to watch the first minute, or so.
    https://youtu.be/aZNy6wuQqtU0
    Good job by the way! They'd be laughing at me cause they'd have to pull me out a lot...:anonymous:
  29. Apr 10, 2021 at 7:18 PM
    2002 AC
    Honestly, I think it was my suspension setup. I was getting beat up so bad and they were fine. Plus I'm so much heavier(I assume). I've come to love my Icons on pavement, but I'd like to try something else off-road.
    Tundra2 likes this.
  30. Apr 10, 2021 at 7:21 PM
    2002 AC
    We actually could have taken your truck. It would have added a fun layer to it. :)
    With the right tires, you could have made it through most of it.
