Bakflip MX4 supposed to sit like this?
Discussion in 'Tonneau Covers, Caps and Shells' started by Sangly168, Jun 27, 2018.
  1. Apr 9, 2021 at 3:57 PM
    Hawkdriver19
    Hawkdriver19 New Member
    2017 CrewMax SR5 4WD White w/ XP Blackout kit
    In case anyone is still questioning the MX4 fit, I just installed one on my 2017 crewmax. The rear sits up higher on the tailgate than my old F1 but looks like it has a decent seal. We have had a lot of rain over the last 48 hours and no evidence of water from the rear lip. On the other hand, there are holds at the rear rail channel that allows water to pour into the rear corners of the bed
  2. Sep 6, 2021 at 5:56 AM
    TinyTundra
    TinyTundra New Member
    PA
    '21 Tundra Crewmax SR5 4x4 Off-Road
    @Hawkdriver19 Were you able to find a fix with the leaking issue in the rear channels?
  3. Sep 6, 2021 at 9:33 AM
    Hawkdriver19
    TinyTundra,
    I took dense foam and glued it to where the holes are. When the tailgate is closed the foam is pinched in place and does a pretty good job of keeping the water out of the tailgate. I thought about putting some RTV in the hole but haven’t done it yet.
    TinyTundra likes this.
  4. Nov 30, 2023 at 6:47 AM
    Lunar * Rock
    Lunar * Rock New Member
    So I finally got mine installed. Does one side (left for me) sit higher than the right on the tailgate?
    When the gate is down it’s fine. When the gate goes up, the cover on the left side lifts
