Interior Fuse Box Location and Information
Discussion in 'General Tundra Discussion' started by csuviper, Jan 27, 2016.
  1. Dec 8, 2017 at 5:46 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    .......and it's little. Just look for the small shiny rectangular cover.
  2. Dec 8, 2017 at 5:55 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    And bitch to get to unlike my Taco. Observe the orientation of the cover. I kept putting mine on backwards and wondered why it would not stay on
  3. Dec 8, 2017 at 5:57 PM
    Tundra Fan
    Toby
    lol
    Mine won't go back on because of an add a fuse so I keep it in the upper glovebox.
    NewImprovedRon likes this.
  4. Dec 8, 2017 at 6:56 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Same
  5. Dec 8, 2017 at 9:03 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    "no negative vibes, man" or you'll never get it back on!
  6. Dec 17, 2017 at 7:53 AM
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Which color is the illumination wire, and what size is it so I can get the correct positap?
  7. Dec 17, 2017 at 10:14 AM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Thanks!
  8. Aug 18, 2018 at 2:23 PM
    Whitetundra95
    Whitetundra95 New Member
    2016 Toyota Tundra Crewmax
    Hey so I want to add floor board lighting. Don’t want to tie into the switch because those only come on when you open the door. I want to tie it into the illumination lights, or just any light that is on when you turn your headlights on so that they come on when my headlights do. Any suggestions on how to do it?
  9. Aug 18, 2018 at 3:52 PM
    Whitetundra95
    Thank you so much!! Just signed up for this and this is so helpful already! Thanks again!
  10. Mar 9, 2019 at 9:19 PM
    Ccleme11
    Ccleme11 New Member
    Chad
    2010 Blue Tundra SR5 Rock Warrior
    Cold air intake, 50" Roof Mounted LED Bar, Smittybilt M1 Front bumper
    Which wrie is the illumination wire?
  11. Mar 9, 2019 at 10:03 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
  12. Mar 17, 2019 at 1:33 PM
    Scotty Dive
    Scotty Dive New Member
    Connecticut
    on my 2018 the fuse panel is slightly different in what circuits are in there. However, I needed to tap into a couple of circuits to add heated seats (no seat labeled fuse in there) and an always on USB charger. Anyway, the low profile add a fuse that I use will no way allow the cover to go back on. Not the end of the world, but is there a solution that allows the cover to go back on?
  13. Mar 17, 2019 at 4:35 PM
    Kingdomconstruction
    Kingdomconstruction New Member
    Anton
    2008 toyota tundra sr5 4 door v8 4.7
    Lifted skyjacked Fuel rims and tires 35 inch Exhaust upgraded to max
    One section 2 rows in a block under hood fuse box arent lighting up with test light the rest do tho
    My cd player and whippers donyt work
    Under dash box also one side no power other lights up with the tester thing
    Plz help
  14. May 31, 2019 at 11:40 AM
    99645 Tundra
    99645 Tundra New Member
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    thank you i guess ill have to pull each fuse and check for continuity, for some reason i don't have the fuse legend and cover, again thank you
  15. Jun 20, 2020 at 6:09 PM
    AdyTexas
    AdyTexas New Member
    To me it looks like someone either replaced the fuse block (from another vehicle) or sprayed it with water (maybe a nice interior wash). The wire harnesses and places around the block are clean.
  16. Oct 26, 2020 at 1:28 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    So the blank spots don’t have an amperage number called out. If Inuse an empty spot how do I know what size fuse to use. Do I just use a fuse rated just above my device draw or is there another way to know how big a fuse to use?
    Tundra2 likes this.
  17. Oct 26, 2020 at 5:21 PM
    Tundyfundy
    Bay Area, CA
    If it helps I installed seat heaters that need a 15amp fuse
    Tundra2 likes this.
  18. Mar 27, 2021 at 1:42 PM
    Viliamu808
    Viliamu808 New Member
    Trailer brake fuse? You seem very knowledgeable..trying not to call my mechanic friend..got an error on the trailer brake..heard may be the fuse
  19. Apr 8, 2021 at 9:42 PM
    SOLTENOFSWAT
    SOLTENOFSWAT New Member
    16' Limited Tundra TRD 4x4
    Where is the parking brake fuse located? Anyone??
  20. Mar 8, 2022 at 6:25 AM
    #50
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Tapping panel fuse to add new switches will allow them to dim with other dash lights or do I need to tap a blue wire closer to an existing switch to get dimming? Or is dimming ground controlled on tundra?
  21. Jun 19, 2022 at 6:00 PM
    #51
    Bwest18D
    Bwest18D New Member
    2016 Grey Tundra off-road
    Sound
    Absolutely do have to remove the kick panel though. I read this as “no need to remove any panels” and I was about to shoot my self for lack of finding it. Then I removed it. THEN I re-read the post. THEN I feel stupid right now. So even though you’d have never known it, I was cussing someone who posted something up one side and down the other. And I’m sorry for it
  22. Sep 8, 2022 at 6:21 AM
    #52
    LateOnTheBrakes
    LateOnTheBrakes New Member
    Yorktown, VA
    2021 Voodoo Blue Platinum
    TRD exhaust, TRD skid plate, TRD pro wheels, TRD sway bars, AIRAID intake
    My fuse box is missing the cover with the locations and amperage. Is there a part number for the replacement? The 00405469 on the cover doesn't show up.
  23. Feb 14, 2023 at 6:20 AM
    #53
    Hungry86Man
    Hungry86Man New Member
    13 tundra test level kit and 18 test rims
    Level kit, 370 js alternator, 80 ahhr lto battery, batcap 4000 4 4/0 runs from alternator to rear for amps. Oh and fully deadneded
    Spray wd40 every where. For future reference. It will displace any water or moisture and is non electrical conductive. And cleans while getting rid of rust or that carbon build up. Use a tooth brush and really Get there. Then with a metal brush scratch all the wire ends and clean that brass up
  24. Apr 30, 2023 at 1:20 PM
    #54
    Dillilgas
    Dillilgas New Member
    BVW
    2017 Tundra Unicorn
    I need to install constant power to dashcam. Best spot to use that has constant power?
  25. May 1, 2023 at 4:12 AM
    #55
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I haven't check personally, but I'd say if the Cigarette fuse (top right in your first picture and bottom left in your second picture) has constant power I'd use that. Easiest way to find constant power is use a test light and check each fuse with the truck off.
  26. May 1, 2023 at 4:19 AM
    #56
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    FR P/SEAT (left and right power seat) had power in my truck while it was off, but not while cranking. It does not have power seats.
  27. Jul 20, 2023 at 9:22 PM
    #57
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Curious if anyone knows of a circuit that is hot 100% of the time, including while cranking. I’m installing a dash camera this weekend and would like constant power if possible.
    Thoughts?
    Edit:
    Found one (open unused space) that is hot 100% of the time. Used that for my constant and found another open unused space for the “key on” hot.
    Easy peasy.
  28. Nov 17, 2023 at 5:51 PM
    #58
    2012_Tundra
    2012_Tundra New Member
    2012 Tundra
    I need some help looking for a part, the part in question is the lid for the fuse box under the dashboard on the driver side, any help would be appreciated
