Morimoto XB LED Headlights
Discussion in 'Lighting' started by Glennjc1978, Nov 16, 2019.
  1. Nov 16, 2019 at 10:11 AM
    Glennjc1978
    Glennjc1978 [OP] New Member
    Glenn
    2021 trd pro lunar rock
    I installed the new morimoto xb headlights on my 2016 tundra limited. For those of you that have installed them.Does anyone know how to make the DRL say bright all the time.Mine dim when you turn the park lights or headlights on.
  2. Nov 16, 2019 at 11:15 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I believe that's a safety feature. My OEM lights have always done that, my 2015 platinum headlights lower led strip would dim, and when I installed 2018 LEDs the harness is wired so they will dim. I'd stick with it as is.
    Headlight Revolution likes this.
  3. Nov 18, 2019 at 7:58 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    That is a safety feature wired into the truck to cut power down on the DRLs when the headlights are on. :)
  4. Nov 18, 2019 at 8:10 AM
    Glennjc1978
    Glenn
    Is there a way to bypass that?
  5. Dec 18, 2019 at 6:20 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    The harness that is supplied that they instruct to add to your fuse box will provide full power to the DRL’s at all time. The only problem is they never turn off. As soon as the ignition is turned on the DRL’s get power and they are on until you turn off the ignition
    Disclaimer: These are new, the information provided by MANY different distributors and the customers that have the lights already are not in line with one another
  6. Dec 18, 2019 at 6:48 AM
    Glennjc1978
    Glenn
    I have that harness. You are correct they stay on all the time.But even with that harness installed as soon as you turn on the park lights or headlights the drl dim.I would like to find a way around that.
    azTony likes this.
  7. Dec 18, 2019 at 7:08 AM
    azTony
    Tony
    Sun Lakes, AZ
    I see, I just installed yesterday and have not drove at all just looking at them during the day in my garage
  8. Feb 9, 2021 at 3:05 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    2016 CrewMax Platinum
    I am also looking for the same mod. I have looked around but no one seems to have an answer. I do see the “safety” thing mentioned quite often. The OP I’m assuming and I as well would be willing to settle for always on, however and again I’m assuming, but I drive with park lights on all the time. Visible for safety and I love rockin my yellow fogs all the time. Problem is we get dim DRLs. We don’t need the DRLs bright all the time to blind drivers at night, just in the day time to be more visible. Some of us tundra owners are going for a specific “look”, mine includes nice bright DRLs in concert with my bright (SAE DOT approved) yellow fogs.
    So if anyone can help, it would be greatly appreciated.
  9. Apr 4, 2021 at 7:21 PM
    Glennjc1978
    Glenn
    I still haven't been able to find out a way
  10. Apr 4, 2021 at 7:27 PM
    The only time that they are full brightness is when all of the lights are off. They must dim due to DOT regulations.
  11. Apr 4, 2021 at 8:17 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    I think that would be too bright with headlights on.
  12. Apr 5, 2021 at 9:45 AM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    Again... I’m fine with them being dim with the headlights on. I just want them to be bright when the park lights are on. As I drive with park lights and fog lights on during the day. And the drls look really dim, compared to the fogs.
    P.S. I also live in Washington state... 60% of people here, drive with their high beams on, all night long.
    thalgott3 likes this.
  13. Apr 5, 2021 at 9:50 AM
    I don't think there is a way to do it without burning something up or decreasing the life expectancy of the leds.
  14. May 24, 2021 at 7:46 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    @PR_02 @Glennjc1978 Do those XB headlights retain the tilt feature (ability to point the lights up/down)?
  15. May 24, 2021 at 7:56 AM
    Glennjc1978
    Glenn
    Yes
    Cruzer likes this.
