All in one mirror and blind spot mirror
Discussion in '2nd Gen Tundras (2007-2013)' started by MXPCUS, Mar 31, 2021.
  1. Mar 31, 2021 at 8:34 AM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Can I get a mirror like the one on my work truck, but on my Tundra? One with a separate blind spot mirror? And I don't need one with a signal indicator. The little stick ones are kind of worthless unless you have a lot smaller vehicle20210331_103200.jpg
  2. Mar 31, 2021 at 9:06 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  3. Mar 31, 2021 at 9:08 AM
    BlueCrushSC16
    Charleston, SC
  4. Mar 31, 2021 at 9:13 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I'm having the same problem. I'm actually switching back to my stock mirrors. I bought a set from A1-Auto. The small lower mirror only adjusts right to left not up and down. Since the passenger side mirror is not convex there's a huge blind spot on the passenger side.
  5. Mar 31, 2021 at 9:17 AM
    BlueCrushSC16
    Charleston, SC
    Looks like the 3rd option I linked looks to be the best for what you guys need corrected. I don't like the chrome, but that's easily fixed, IMO.
  6. Mar 31, 2021 at 9:17 AM
    Stover87
    Stover87 New Member
    I have the OEM tow mirrors that are linked above. In my experience they are very helpful when backing up a trailer or pulling a wide enclosed trailer. When it comes to daily driving they make the blind spots much bigger than the non tow mirrors. I often watch cars appear in top mirror and disappear for a few seconds, to then reappear in the bottom mirror. If you are after the towing or looks benefit then go for it! If you are looking for more visibility while daily driving then, in my opinion, stick with what you have.
    Njmike13 likes this.
  7. Mar 31, 2021 at 9:18 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
  8. Mar 31, 2021 at 9:21 AM
    BlueCrushSC16
    Charleston, SC
  9. Mar 31, 2021 at 10:20 AM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
  10. Mar 31, 2021 at 10:43 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
  11. Mar 31, 2021 at 10:49 AM
    biebs96
    PA
    I have 3” spot mirrors on each side. I can see the bottom outside edge of my rear tires, which is helpful in tight parking. I can also now see my trailer tires.
    mav7021234 and 300BLK like this.
