Best / easiest option for monitoring transmission temps?
Discussion in '2.5 Gen Tundras (2014-2021)' started by batman900, Mar 27, 2021.
  1. Mar 27, 2021 at 4:05 PM
    batman900
    batman900 [OP] Yep
    24-RAM 2500, 05-Tundra, 11-Accord
    Hi there,
    NOT to make another Tundra missing the trans cooler thread.... I got my new Tundra with the notion that I will keep it a very long time and go on many adventures... So at the very least I'd like to actively monitor my trans temps since that DOES seem to be the weakest link if there ever was one now.
    I was about to purchase a Scanguage II but saw that others had issues with adding some kind of codes or junk? I'd really like something easy that I can use just anytime I feel the need. My only hitch with using my phone would be that on our travels I use it with apple carplay for maps. I dunno exactly how I would monitor temps in those situations.
    Thanks!
  2. Mar 27, 2021 at 6:39 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Mar 28, 2021 at 4:09 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    I choose not to worry about it. I’ve got more than enough things to fret over. If I have the overtemp light coming on I’ll revisit this. Until/unless that happens I’ll just continue to drive the shit out of it.
  4. Mar 28, 2021 at 4:47 AM
    Kung
    KG, VA
    Same for me, though my use case is a bit different. I don't tow all the time; and even if I did, most of it would be with my 14' trailer. When I purchased my Tundra, my towing requirements were literally that I be able to tow what I could before (a 20' or so camper, and my 14' trailer) a few times a year easier than my '13 F150 could.
    This'll do that easily. With that usage I SERIOUSLY doubt I'll ever get close to having any issues; but if I ever get any overtemp light come on, or I start towing more, I'll install the aftermarket cooler.
  5. Mar 28, 2021 at 4:59 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    ScangaugeII is the easiest method of monitoring your transmission fluid temperatures. I own an UltraGauge Blue to avoid the cord. That also ties up my iphone, but I can get by using one or the other. An adapter cord is helpful to keep your iphone charged if you use it to monitor temps.
    Minor hack skills are required to input the proprietary codes into ScangaugeII properly. Not difficult, just go slow and proof read thoroughly. All the other alternate methods will require the same or greater hack skills. At least with ScangaugeII, you do not have to setup the display format, which is much more complicated than the simple data codes.
    Face the facts, Toyota never intended owners to read their transmission fluid temps directly.
    A great volume of information pro/con on all monitoring methods exists in the forum archives. Use search.
    batman900[QUOTED][OP] likes this.
  6. Mar 28, 2021 at 5:24 AM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Veepeak OBDCheck Bluetooth 4.0 OBD2 Scanner for iOS & Android https://www.amazon.com/dp/B076XVQMVS/ref=cm_sw_r_cp_apip_xPaVsaiIgr5Uo
    I use it with the OBD Fusion app on my iPhone. Simple plug and play.
    You can buy the Toyota pack in the Fusion app for 9.99 and get a ton of gauges to monitor. I haven’t done that yet, as I can monitor the trans pan and TC temps without it.
  7. Mar 28, 2021 at 5:46 AM
    batman900
    batman900 [OP] Yep
    Thanks a bunch all, think I got the info I needed.
  8. Mar 28, 2021 at 5:46 AM
    LML 3500HD
  9. Mar 28, 2021 at 7:25 PM
    PNWTunrda
    PNWTunrda New Member
    Dean
    2016 Tundra
    Scanguage works just fine, also used it for the transmission service to check the level at the temp per Toyota's service manual.
  10. Jan 19, 2023 at 6:31 AM
    jhinderliter
    jhinderliter New Member
    pretty slick not having to add another gauge
    did it work ?
    Johnmatrix likes this.
  11. Jan 19, 2023 at 6:38 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Be sure to check out all these threads about 2019+ transmission failures related to not having the factory trans cooler.
    this one:
    this one:
    and this poor guy:
  12. Jan 19, 2023 at 6:40 AM
    jhinderliter
    Just bought a used 2014 ..
    studying up
  13. Jan 19, 2023 at 12:49 PM
    Terndrerrr
    Music City
    Dual 5.7s
    I did buy the Toyota pack. I monitor engine oil, coolant, trans pan, TC, lockup status, and battery. Works great.
    There was one guy who burned his up in his 2019 towing a 3k lb trailer daily. He ghosted the forum after posting a service write-up from his dealership which connected the failure to lack of an external cooler. Also, practically all of us are still within the 5yr/60k warranty. My perspective has always been that it’s a very tough transmission. But it was originally designed with an external cooler on tow-package trucks. Nothing in the design changed when they deleted it except potentially lockup programming.
    If you bought to keep long term, investing the relatively small amount of money for one makes sense. Especially if you tow. If you’re gonna sell in before the base 60k/5yr drivetrain warranty is up, no need to bother.
    Leo's first and Johnmatrix like this.
  14. Jan 19, 2023 at 1:06 PM
    Love to see that post and read through it.
  15. Jan 19, 2023 at 1:33 PM
    Terndrerrr
    Music City
    Dual 5.7s
    There’s more to it if you search his posts. I had some of the details wrong. Truck is a 2020. He tows 3k 5 days a week for work and then a travel trailer sometimes on the weekends. The dealer doesn’t say explicitly that lack of a cooler caused it. Toyota corporate was supposed to get back to the guy to tell him what exactly caused the failure. I’d be very surprised if they said, “yeah, it’s because we deleted the external cooler up front. Whoops, lol.”
    I’m just glad there is a case logged through a dealership service center where a de-cooler’d truck had a transmission that burnt up and needed to be replaced. Still don’t think we’ll see more failures until past the warranty period. This guy’s usage falls well outside the majority of Tundra drivers. My thinking is that this failure rate is acceptable for Toyota. :notsure:
    Over 200k Tundras produced 2019-2021. Suppose Toyota saved $500 (this is a total guess) per truck by deleting the thermostat, hard lines, hoses, radiator, any mounting hardware, and using 1.5-2qt less trans fluid. That would save them $100M.
    meyer and KNABORES like this.
  16. Jan 19, 2023 at 2:14 PM
    Bet he wasn’t towing in S4
    Saltyhero13 likes this.
  17. Jan 19, 2023 at 2:30 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    https://edgeproducts.com/shop/insight-cts3
    I haven't looked into the Banks, and was disappointed to learn that the company Edge, does not make a monitor (like the Edge CTS3) that supports a 2019 Tundra V8. However, when I plugged in a 2014 Tundra V8 only the CS2 came up.
    Henry1jg likes this.
  18. Jan 19, 2023 at 3:12 PM
    Terndrerrr
    Music City
    Dual 5.7s
    :notsure:
  19. Jan 19, 2023 at 3:14 PM
    That’s what I would have told them too…..
  20. Jan 19, 2023 at 3:19 PM
    Terndrerrr
    Music City
    Dual 5.7s
    I don’t think there’s any basis for thinking he’s lying. He seems to know what he’s doing from his posts. He said he did the exact same thing for 7 years in a 2013 and had zero issues. The 2013 has a cooler.
  21. Jan 19, 2023 at 3:25 PM
    I certainly wouldn’t want to accuse him of such. Posting mostly in jest about that. While not a perfectly controlled scientific experiment , makes a man wonder for sure. Unfortunate outcome for him, very rare it seems, at least from the Tundra community here to have a trans failure, cooler or not. Most report stable trans temps when towing in S4, rarely above 230-240°. Toyota reports the trans fluid to be stable up into the 300° range. Not sure what wizardry that is, I wouldn’t want my trans fluid temps anywhere near that.
    meyer likes this.
  22. Jan 19, 2023 at 4:16 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    This thread has some good data about tranny temps.
    https://www.tundras.com/threads/green-thunder-oil-analysis-thread.94464/
    Post 18 and 39 have the test results. I use the Veepeak and OBD Fusion app mentioned earlier here. What I have learned for my use is I likely don’t need the added cooler if I pay attention or use the tow button and S4 if in doubt. One more oil test to decide for sure for me. I tow moderate weights some, load truck and go some, off-road some. When towing if I use tow haul and am on level ground, D works fine unless it’s summer, then S4. If towing anytime on hills, corners, etc. have to use S4, it’s the shifting that spikes temps. If off-road 4L is a must.
    Get the set up to monitor your temps, it’s kind of fun in a way.
  23. Jan 19, 2023 at 4:20 PM
    batman900
    batman900 [OP] Yep
    Hey buddy, since that post I have added a trans cooler and it's been great. I also use the Veepeak without issue. Thank ya
    Pmac[QUOTED] likes this.
  24. Jan 19, 2023 at 4:26 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Not the cheapest - but you can kill two birds by ditching the entune HU for an aftermarket with Maestro unit.
    ohiowa and vilord like this.
  25. Jan 19, 2023 at 4:30 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    I got the ScanGaugeIII about 6 months ago and have nothing but positive comments. As you can see both trans temps are on my monitor. You can also look and clear codes, tons of “trip” functionality along with MPGs, etc.
    JimboSlice413 and Henry1jg like this.
  26. Feb 1, 2023 at 12:16 AM
    meyer
    meyer New Member
    michael
    2021 tundra sr5 doublecab longbed
    hand grab, linex
  27. Feb 1, 2023 at 3:46 AM
    Max trans fluid temp was 246°. Toyota WS fluid is good for around 300° per Sweers. Not saying 246° is good, just that the Toyota engineers designed it based on a higher operating temp. If I were towing heavy up the Ike, I would put a cooler on mine.
    Saltyhero13 and RustyShackle323 like this.
  28. Feb 1, 2023 at 4:27 AM
    meyer
    meyer New Member
    michael
    hand grab, linex
    That was under 10 minutes in winter in Colorado. Try hours of towing in summer. I ve read reports some are overheating without towing, just sitting in traffic. Engineers are clearly not in charge, bean counters are, Sweers is making excuses for yet another Toyota facepalm. Btw by the time the tranny idiot light goes off you ve already burnt your ATF. If the tranny had a dipstick, it doesn t, another bean counter facepalm, you d be able to smell the burnt oil. Unless Toyota has some secret ATF that beats all other oils out there they need to issue a recall on the 19-21s.
  29. Feb 1, 2023 at 4:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I was running ~230 unloaded cruising down hwy. houston heat
    put in cooler. Never reach 198.
    Henry1jg and meyer[QUOTED] like this.
  30. Feb 1, 2023 at 4:41 AM
    Link to these overheating reports please
    RustyShackle323 likes this.
