Kicker key 500.1 vs AudioControl acm-1.300
Discussion in 'Audio & Video' started by skip1980, Feb 23, 2021.
  1. Feb 23, 2021 at 5:14 PM
    skip1980
    skip1980 [OP] New Member
    Columbia, Missouri
    I am running a dsr1, sub and box with a 8 channel amp from James. I want more out of the subwoofer so I am going to add a dedicated sub amp. I have it narrowed down to these 2 amps both are rated 300watts ar 2ohms. Anyone have any experience with one or both?
  2. Feb 23, 2021 at 5:59 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What subs are you running?
  3. Feb 23, 2021 at 6:13 PM
    skip1980
    Columbia, Missouri
    I'm just running one 10in infinity sub at 2 ohms. It's like 250-300 rms rating.
  4. Feb 23, 2021 at 9:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    The only reason id go with the audio control is if you are running the factory head unit so you can eliminate the bass roll off.
    Edit, I see you have the dsr-1, just get whichever is cheaper
  5. Mar 1, 2021 at 11:04 AM
    skip1980
    Columbia, Missouri
    Found 1 more amp that fits the profile. Rockford fosgate T500X1br. So it's between the Rf, audiocontrol acm-1.300 and the kicker key 500.1.
  6. Mar 4, 2021 at 7:45 AM
    Danimal86
    Daniel
    Sacramento, CA
    what 8ch amp are you running?
  7. Mar 4, 2021 at 9:13 AM
    skip1980
    Columbia, Missouri
    Jbl dsp4086
  8. Mar 5, 2021 at 8:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    Thats pretty cool, never seen an 8ch that small
  9. Mar 5, 2021 at 8:45 AM
    skip1980
    Columbia, Missouri
    Yes it is, also had built in DSP. I am running every speaker in the truck off this amp. Need more out of the sub because it's only getting 60 watts. Well I pulled the trigger on the AudioControl ACM-1.300. Well see how the sub sounds when getting 300 watts.
  10. Mar 5, 2021 at 9:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    i watched a video on it, looks like a decent dsp too.
