Suggested Lifts?
Discussion in 'Suspension' started by LGTundra, Apr 3, 2015.
  1. Apr 3, 2015 at 5:37 PM
    LGTundra
    LGTundra [OP] New Member
    2015 1794 Edition: SuperCharger, 3-1 Toytec, 20'' Fuel Wheels, 33" Trail Grapplers, Bushwackers, A.R.E. Z-Model Cap
    2015 1794 Edition.....
    Looking to do a 4-6 inch lift....6 inch if it fits in the garage. Just looked on Rough Country and it says their 4 & 6 inch are out of stock.
    Should I wait?.....or are there ones just as good. Used mainly for street ride.
  2. Apr 3, 2015 at 5:47 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Rough country is crap. You get what you pay for in that case, I'd never buy a rough country for a $50k truck.
    My $.02
  3. Apr 3, 2015 at 5:51 PM
    If you want a 4-6" suspension, I would look into BDS.
    Anything under, (~3.5") go with Toytec.
  4. Apr 3, 2015 at 6:50 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    4x4?
  5. Apr 3, 2015 at 8:03 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    You got a budget or is the sky the limit? You got a size tire you wanna run with? And you ok with cutting the cross member on the 5+ lift?
  6. Apr 3, 2015 at 8:48 PM
    TruckyTruck
    Gary
    If he is 2wd, no cutting the crossmember
  7. Apr 14, 2015 at 12:25 PM
    LGTundra
    Thanks for the response.....all are appreciated. Since I am inpatient and primarily using for the street, I am going with a 3 inch ToyTec lift with 33" Trail Grapplers 20" Fuel wheels with +0 offset (the dealership is doing it all with a 1 yr warranty). Will post pictures when all is complete! And for Trucky Truck.....yes 4x4.
  8. Apr 14, 2015 at 1:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Awesome. Good choices. You will be happy with the 3" Toytec lift. Did you go with the ultimate bilsteins or boss kit?
  9. Apr 14, 2015 at 1:18 PM
    TruckyTruck
    Gary
    Spacer lift? What fuel wheels?
  10. Apr 14, 2015 at 1:50 PM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Good choice! Like @csuviper asked...what exactly did you end up with?
  11. Apr 14, 2015 at 2:33 PM
    LGTundra
    Lift: ToyTec / BOSS Ultimate 3″ Lift Kit
    Fuel Wheels:
    FUEL ONE PIECE BOOST - D534 (20")
    Tires: 33" Nitto Trail Grapplers
    2015 1794 Black
    Once all work is completed....will post pics
    FunkinTundra likes this.
  12. Apr 14, 2015 at 5:37 PM
    Woot! You'll love the BOSS kit! It rides so much smoother than the other lifts, IMO.
    I bet you can stuff 34"-35" tall tires in there if you wanted to go a little taller.
  13. Apr 15, 2015 at 3:02 AM
    LGTundra
    Sean266.....yes on the 34-5" but dealership said they wouldn't do the warranty if they had to trim anything. So I passed on it. I tried to push them on it or have an outside company do the lift but then it couldn't be worked into the finance and all the BS along with it. So I went with the 33's.
  14. Apr 15, 2015 at 3:55 AM
    Weird.
    They only need to trim the bumper a bit, push the fender liner in, and re-tap a screw into the front bumper into the fender liner.
    Post up pix when complete!
    LGTundra[OP] likes this.
  15. Apr 15, 2015 at 11:30 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Ooh :D nice! Lookin forward to checkin it out!
  16. Apr 16, 2015 at 4:58 AM
    LGTundra
    Sean266.....love how you know all this stuff inside and out! Stay tuned for pics!
  17. Apr 16, 2015 at 11:19 AM
    Not even close. I know a little, but nowhere near @csuviper (who has taught me some) or other members here and other forums.
    LGTundra[QUOTED][OP] likes this.
  18. Apr 16, 2015 at 5:14 PM
    LGTundra
    Ok one last night....Feel like an undecided bitch!!
    2015 1794 4wd Tundra use is for street with an occasional off road.
    Here is what I need help on:
    3 toytec lift with 33" tires on 20" wheels
    Or
    4.5 Rough Country lift with 35" tires and 20" wheels
    What one should I go with!?!?!
  19. Apr 16, 2015 at 6:50 PM
    3" Toytec BOSS kit
    34-35" tires on 17-18" wheels.
  20. Apr 16, 2015 at 10:45 PM
    LGTundra
  21. Apr 17, 2015 at 3:23 AM
    LGTundra
    Sticking with ToyTec. I do feel more comfortable going with a better known brand. You guys had already made it pretty clear ToyTec is better!
    Thanks gents!!
  22. Apr 17, 2015 at 7:37 AM
    Toytec is great, but if you do any wheeling, I would do a suspension lift and not a spacer lift if it were me.
    Suspension lift is safer, rides smoother, and can save your shocks.
  23. Apr 17, 2015 at 10:57 PM
    csuviper
    Broomfield, CO
    Honestly a spacer is a spacer with stock suspension regardless of brand. Toytec makes quality products though.
    The 4.5" is a drop bracket lift. If you go to that extent you should just make it a 6" lift. Rough country is one of the cheaper drop bracket lifts for a reason. I'm not a fan.
    Recommendation from me is always a replacement of struts with longer struts or coilovers for 3" or 6" lifts. As Sean said spacers leave the front suspension stiffer.
  24. Apr 26, 2015 at 11:58 AM
    FlatAir2
    FlatAir2 New Member
    Shaun
    2012 Grey Tundra CrewMax Rock Warrior
    I have a question about the Toytec BOSS lift sine you all seem smart in regards to this...
    I put on the Ready Lift Leveling Kit with 3" front and 2" rear blocks. How will all of that effect the Boss install as well as will it need to come off? Can it stay on and add a bit more height?
    I hope me asking here isn't rude, if it is I'm sorry. I'm new to this.
  25. Apr 26, 2015 at 5:24 PM
    csuviper
    Broomfield, CO
    The Toytec Boss lift kit come with coilovers for the front that are adjustable between 0 and 3" of lift. The rear comes with new longer shocks and 1" block, 1.5" block or add a leaf.
    For the front you will need to remove the spacer and the stock struts and replace with the new coilover.
    For the rear you can leave the 2" block on if you want or replace the 2" block with a new 1.5" block. Also depends on what rear shocks you have, if stock you should replace with the new longer ones.
    You might save a little by just getting the front coilovers and keeping the rear how you have it now.
    Its is not suggested that you combine the spacer lift with the new coilover.
