TRD Pro Grille LED Light Kit
Discussion in 'Sequoia Builds' started by Adamdsgn, Sep 23, 2020.
  1. Sep 23, 2020 at 10:53 AM
    Adamdsgn
    Adamdsgn [OP] New Member
    2018 Toyota Sequoia
    Does anyone know or has anyone attempted to install the Amber LED Light Kit that is available for the Tacoma TRD Pro Grille and 4Runner TRD Pro Grille?
    I think this would look great on Sequoia Pro Grille. Would love to know if anyone has attempted this and where they got the lights from is so.
    See link below for the Tacoma Kit:
    https://caliraisedled.com/products/...ikRaU_uq2pt6eptn8RbPOBHJd7SA86TRoCDLoQAvD_BwE
    silverhack likes this.
  2. Sep 24, 2020 at 10:42 AM
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    As far as i know, they haven't made one for the Sequoia yet. I have both the Tacoma and Sequoia Pro grilles, they are similar, but the spacing on the sequoia is bigger.
  3. Sep 25, 2020 at 6:02 AM
    Adamdsgn
    2018 Toyota Sequoia
    Correct on all fronts. I assumed the spacing for the 4runner and Tacoma grille was smaller, but there are kits for the Tundra out there.
    I guess more specifically is the spacing on the Tundra TRD Pro grille the same as the Sequoia? Is so, there are several kits that will fit the Sequoia.
  4. Sep 25, 2020 at 8:20 AM
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    https://www.tundras.com/threads/led...n-tundra-trd-pro-grille-18-19-yotaleds.43240/
    I think these will work, the spacing on both the tundra and sequoia look pretty damn close to me.
  5. Sep 25, 2020 at 8:40 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    DIY...it will be cheaper :)
    I bought lights off Amazon and ran my own wiring for my Tundra and Tacoma.
  6. Sep 26, 2020 at 3:43 AM
    War Machine
    War Machine SSEM # 5 3MW
    I can check since I have both. What measurement do you need exactly?
    GODZILLA likes this.
  7. Sep 28, 2020 at 6:04 AM
    Adamdsgn
    2018 Toyota Sequoia
  8. Sep 28, 2020 at 6:05 AM
    Adamdsgn
    2018 Toyota Sequoia
    Not sure of the measurement of spacing needed. The YotaLEDs owner posted in the Tundra forum and I shot her a message. When she responds I'll ask her if there is a spacing measurement we can use as a baseline and get back to you.
  9. Dec 18, 2020 at 12:16 AM
    NFARIDI
    NFARIDI New Member
    Any update on this?
  10. Dec 21, 2020 at 5:58 AM
    Adamdsgn
    2018 Toyota Sequoia
    I received a message back from owner and she said currently they do not have a package for the Sequoia and the Tundra TRD grill spacing is slightly different than the Sequoia. She did say someone had bought the Tundra brackets and modified them for the Sequoia grill, but she couldn't tell me who. She instructed me to buy the bracket kit and see if I can get it to work...
    NFARIDI likes this.
  11. Feb 23, 2021 at 7:11 AM
    NFARIDI
    NFARIDI New Member
  12. Feb 23, 2021 at 2:58 PM
    Adamdsgn
    2018 Toyota Sequoia
  13. Mar 3, 2021 at 7:44 AM
    Adamdsgn
    2018 Toyota Sequoia
    Order placed and package in pre-shipment!
  14. Mar 3, 2021 at 8:26 AM
    NFARIDI
    NFARIDI New Member
    ordered mine as well. i went with amber although now i'm thinking i should have went with white since i don't have any other amber on my sequoia.
  15. Mar 3, 2021 at 10:22 AM
    Adamdsgn
    2018 Toyota Sequoia
    I went with the Amber as well. Not sure the other (white) version is going to have the same effect. I have yellow overlays on my TRD Pro fog light, which I will probably remove once I get these installed. Any idea how hard these are going to be to wire and what they will be wired to? Do they wire up to the DRLs?
  16. Mar 3, 2021 at 11:03 AM
    NFARIDI
    NFARIDI New Member
    my guess is that it's up to you how or what you want to wire them to. You can do them with the DRL's, to a separate switch, low-beams, foglights, etc.
  17. Mar 3, 2021 at 12:05 PM
    Adamdsgn
    2018 Toyota Sequoia
    Website states they come with a sort of plug and play wiring harness... They claim 15 minutes from box to install with no splicing of wires. Just wondering if anyone has experience with similar installs. The install instructions they have on the website are FAIRLY straight forward, but again they're waiting on feedback from installs to finalize some of the specifics for the add-a-fuse in the stock fuse box.
    NFARIDI[QUOTED] likes this.
  18. Mar 9, 2021 at 12:17 PM
    Adamdsgn
    2018 Toyota Sequoia
    LED Kit was delivered today. Install seems pretty straight forward. The wiring harness is pretty legit and contains just an add-a-fuse for the box depending on how you want them to operate.
    Plan on setting aside about an hour tomorrow to get everything installed and buttoned up.
  19. Mar 11, 2021 at 7:49 AM
    Adamdsgn
    2018 Toyota Sequoia
    Got the YotaLED kit installed yesterday. Extremely easy and the fitment and quality is top notch. Really glad I didn't just DIY this with random pieces purchased from Amazon.
  20. Mar 24, 2021 at 12:37 PM
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia
    Looks good! Do you have any daytime pics with the lights off or night shots with them on?
  21. Mar 26, 2021 at 9:36 AM
    farnsrocket
    farnsrocket New Member
    My Yotaled kit should arrive today!!!
  22. Mar 27, 2021 at 5:09 AM
    farnsrocket
    Got mine installed last night......pretty easy install, the online directions could be a little more clear and on my 14’ I couldn’t find this fuse location H-LP LH-LO 10 Amp Fuse. It says you can use this location if you only want the lights on with your headlights.
    The kit is top notch and the metal brackets and wiring are great!
    TeamHall and S. Equoia like this.
