Replaced Spark Plugs 71k miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by TGBTG7701, Feb 27, 2021.
  1. Feb 27, 2021 at 5:47 PM
    TGBTG7701
    TGBTG7701 [OP] New Member
    Keith
    2016 SR5 4x4
    3" Lift 33/12.50- 20 tires
    I have a 2016 Tundra, 5.7 4x4 71k miles. I noticed my idle was not as smooth as usual, and MPG was a little worse than normal ( not like they get great MPG ) so I decided to change the spark plugs. This was my issue, the plugs looked like there was 100k+ miles on them electrode gap was .050+. I replaced them with the same OEM Denso plugs it came with, it runs smooth and seems to have a little more power through out the power band.
    Has anyone had the OEM plugs give out before the 100k mark?
    HulkSmurf14 likes this.
  2. Feb 27, 2021 at 5:55 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Depends on fuels used and how long your trips might be on average...
  3. Feb 27, 2021 at 6:06 PM
    TGBTG7701
    Keith
    2016 SR5 4x4
    That is most likely the reason, fairly short trips to work each day. I am not complaining, the plugs are not difficult to change, and if you catch discount codes right, price is not that bad on the plugs.
  4. Feb 27, 2021 at 8:08 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I replaced at 60k. Super easy. Helped about 1.5mpg. The old ones looked good though. I usually only do longer hauls.
  5. Feb 27, 2021 at 9:02 PM
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Replaced mine a little over 100k. Definitely notice a huge difference when daily driving after swapping them out.
  6. Feb 27, 2021 at 11:21 PM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    Yikes! Definitely time for a change there..
    Just got my 2020 used Tundra with 10k and I think I will
    pull the plugs for a peek.
    Just foundScreenshot_2021-02-27 2020 Toyota Tundra Spark Plug - 9008091180 - Genuine Toyota Part.jpg this online...
  7. Feb 28, 2021 at 2:43 AM
    TriniMan
    TriniMan New Member
    SEAN
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    You may also what to add a can of Seafoam to the next gas fill up to clean your fuel delivery system. Also, over looked, take an old tooth brush and clean your throttle housing. Both are often over looked but will may a huge difference.
    JohnLakeman and kentran5397 like this.
  8. Feb 28, 2021 at 4:44 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Inspect the electrodes for wear. Unless the electrodes are obviously worn, your improvement has probably resulted from replacing fouled plugs. New, clean plugs can foul again. Service life of Denso iridium-tipped sparkplugs has proven to be 100-120K miles as Toyota claims.
    Ethanol gasoline sucks. I just finished cleaning fuel systems, rebuilding carburetors, and replacing carburetors on all my small engines to repair ethanol damage. Vehicles are designed to handle the ethanol better, but are still subject to problems. Add Chevron Techron before your next fill up, or run a tank full of Chevron gasoline. Chevron gasoline is pricey, but has the Techron additive blended in. You may find further improvement.
    Tundra2 likes this.
  9. Feb 28, 2021 at 6:51 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    A few years ago, I replaced the plugs on my brothers 09 Tundra with 140k. Plugs still had another 40k left, he mostly drove highway miles. But coming from Subarus that ate plugs at 30k, I was impressed.
  10. Feb 28, 2021 at 7:18 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    They are all easy to get to?
  11. Feb 28, 2021 at 8:00 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I don't care what the manual says, I would never wait until 100k miles to change my spark plugs.
    Darkness likes this.
  12. Mar 1, 2021 at 5:26 AM
    JohnLakeman
    Still following the 30/30 program?...Replace the spark plugs every 30K miles, and gap to 0.030" regardless of what the manual says?
    Suprafantx and BTBAKER like this.
  13. Mar 1, 2021 at 6:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I didn't know this about chevron, or them having an additive. Thanks. I always find your wealth of info helpful, and educational. :thumbsup:
    A quick search yields the nearest Chevron to me...
    A second option. Shipped to your door.
    JohnLakeman[QUOTED] likes this.
  14. Mar 1, 2021 at 6:08 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    If you have a Stewart's I think their premium is ethanol free.
    SPP
  15. Mar 1, 2021 at 6:45 AM
    Funnyguy713
    Houston TX
    Use a company vehicle and only drive my Tundra on the weekends so also change my oil every 3,000 miles or once a year.
    Like clean oil in my Tundra, thats how I roll. :mudding:
  16. Mar 1, 2021 at 6:57 AM
    JohnLakeman
    There are a few Chevrons around my area closer than yours. :D Chevron is bigger farther west to Cali than in Texas. I just mention Chevron gasoline as an alternative for those that don't care to open the bottle and pour in the contents.
    My personal choice has always been the bottle, primarily because I suspect concentration is low in the gasoline, being intended for maintenance rather than remedial. Wally Wurl was once my go-to, but these days, Amazon to your door is king. :D
    BTW, I'm not sure Techron will be a panacea for the by-products of ethanol. Techron may help clean out the residue from ethanol, but won't keep it from forming. I switched all my small engines to 101 octane ethanol-free gasoline. I figure that if I buy the expensive ethanol-free gasoline, I can save back the money and labor on rebuilding carbs and cleaning fuel systems. That stuff is too expensive ($4.35/gallon) to burn in quantities the Tundra uses, but so far, no obvious effects on the Tundra.
    Tundra2[QUOTED] likes this.
