Grab the bottom of your steering wheel for me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Airn890, Jan 10, 2021.
  1. Feb 28, 2021 at 9:03 PM
    #61
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've never seen a spring in the steering column that could effect or eliminate wheel shake.
    4Runner column
    French Avocado likes this.
  2. Mar 1, 2021 at 3:35 AM
    #62
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Post# 36 last paragraph. It's the only one I can find at the moment.
  3. Mar 1, 2021 at 6:03 AM
    #63
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Unfortunately that isn't an option because the rack and pinion in not serviceable. If there's an issue it's simply replaced and on the Tundra there is a fair amount of labour for the R and R. Maybe a rebuilder of steering gears may be able to do it but it would be easier to address the issues causing the shake in the first place.
  4. Jun 18, 2021 at 6:38 PM
    #64
    Peterjohn
    Peterjohn New Member
    Hello, 2020 tundra same exact issues.. before I trade it in and loose money any find a fix ? Would solid steering rack bushing help ?
  5. Jun 18, 2021 at 6:41 PM
    #65
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you not have warranty?
  6. Jun 18, 2021 at 6:47 PM
    #66
    Peterjohn
    Been in 14 times, multiple tire balance, multiple alignments , new front diff and driver cv. Just was turned down for lemon law because it’s not a safety concern. Very disappointed in Toyota, never thought about a different truck till now.
  7. Jun 18, 2021 at 6:50 PM
    #67
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    More than likely it's a tire issue. Move the fronts to back and see if it gets better. Have you call Toyota customer service?
  8. Jun 18, 2021 at 6:52 PM
    #68
    Peterjohn
    yeah called, I filled lemon law with them. may file with my state or just get ride of truck. Just seeing if someone found the issues.. does the same thing with my winter rims so doubt it’s tires.
  9. Jun 18, 2021 at 7:46 PM
    #69
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Give it back to the dealer and tell them to fix it. It's under warranty. Don't pick it up until they show you it's fixed. There is no way Toyota Corporate is not going to resolve this.
  10. Jun 19, 2021 at 5:19 AM
    #70
    Peterjohn
    It feels like the engine is causing it, it changes harshness at different Rpms. I was told they will not look at it for this issue again. I’m very disappointed with Toyota all around.
    Was going to trade it in on a 21 tundra but with how I was treated I can’t give Toyota anymore money. Been looking at 2500 duramax
  11. Jun 19, 2021 at 6:23 AM
    #71
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would like to see the problem. Make a video of the wheel shake and post it up.
    Wheel shakes is cause by a rotational imbalance of rotating parts so things like tires, wheels, brakes rotor, CV axles, etc. Its unlikely engine related.
  12. Jun 19, 2021 at 6:43 AM
    #72
    Peterjohn
    its not a shake it’s a vibration, nothing to see.. Service manager said yeah I feel it but it’s not really that bad, he drove the truck for 2 minutes.
    Would the brakes cause vibration with no brake pedal pulsating ?
  13. Jun 19, 2021 at 6:51 AM
    #73
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So a vibration. No brakes would unlikely cause any vibration and there would be a change when the brakes are applied.
    What rpm does the vibration occur? What vehicle speed does the vibration occur? Is there a change in the intensity of the vibration when rpm and vehicle speed change.
    If a family member or friend drives the truck what would their comments be?
    So you only had one service manager drive the truck for two minutes?
  14. Jun 19, 2021 at 7:16 AM
    #74
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    @Ruggybuggy I love you, man, but you need to come down to The States and see the shit show that dealership service departments are down here. Every service department, regardless of brand, that I have dealt with always has their priorities effed up. They behave as if their sole purpose is to make you leave as quickly as possible. Some are more polite than others, but they all try to do zero work on the vehicles and act like doing anything beyond an oil change is them doing you the biggest favor in the history of mankind. They treat every customer as though they are exaggerating every problem and like they are just being whiny.
    2mchfun and Ruggybuggy[QUOTED] like this.
  15. Jun 19, 2021 at 8:46 AM
    #75
    Peterjohn
    wife drives truck, she complains worse then me.
    lower rpms are worse. 6th gear at 65 it
    Vibrates bad.
    3 different Toyota dealers, 6 plus Toyota techs, regional technician.. same results.. yeah I feel it but that’s normal, wasn’t there for the first 7k miles
  16. Jun 19, 2021 at 8:56 AM
    #76
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If they are saying it's normal I would challenge them in showing you on one of there new Tundras the same condition.
    Do this little test for me and see if you can duplicate the vibration. In an empty parking lot put the truck in drive and keep your left foot on the brake. Step on the throttle slightly and slowly increase the rpm until you feel the vibration. If the vibration is there note what rpm it happened. Report back.
  17. Jun 19, 2021 at 10:59 AM
    #77
    Peterjohn
    I was told no new ones in stock.. walked to sales and drove a 21 with ten minutes of leaving service.. dealers do not care I was told they don’t get paid for diagnostic work so if it’s not obvious they don’t fix it.
    Tried what you asked down a back road, very little vibrations getting up to 3k rpm but truck started to go.. if I accelerate hard I can feel it maybe coming from back but it may just be the tires grabbing hard.
  18. Jun 19, 2021 at 12:25 PM
    #78
    glowblue
    glowblue From time to time
    VA
    I’d say sell it to Carvana but you’ll be hard pressed to find a replacement. You’ll at least get your money back (or in my case net $4k over what I paid new.)
    Ruggybuggy likes this.
  19. Jun 19, 2021 at 1:09 PM
    #79
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    There might be a loose nut behind the wheel. It happens all the time around here.
  20. Jun 19, 2021 at 1:51 PM
    #80
    Wyoming
    Can't tell if you're making a crack at the driver, or if there might actually be hardware in need of tightening.
  21. Jun 19, 2021 at 1:54 PM
    #81
    batman900
    batman900 Yep
    24-RAM 2500, 05-Tundra, 11-Accord
    I still gotta insist you try somewhere like Firestone before giving up on the ride. Still wished I would have done that before tossing my new Taco out the window. They did what 2 dealers and over a dozen visits couldn't for my wife's 4Runner. Just leave it with them and tell them to call when it's fixed.
    Peterjohn likes this.
  22. Jun 19, 2021 at 2:04 PM
    #82
    Peterjohn
    Thought about carvana but like you said I wouldn’t be able to replace plus it’s most cost efficient to trade in.
    Loose nut ? Please elaborate.
    I wish it was just me lol, everyone that I let drive it says the same thing.
    I was told they will not work on it for this issue anymore.. hate to leave the Toyota supposedly reliably but my hands go numb on long drives..
    going to try a local shop and see what they say.
  23. Jun 19, 2021 at 2:07 PM
    #83
    WBW
    WBW Resident lurker
    Bruce
    Just trying to be a little funny. I guess it didn't work as I had planned.
    batman900 likes this.
  24. Jun 19, 2021 at 3:52 PM
    #84
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your hands go numb after long drives? That may be an over exaggeration. If the vibration is that subtle there is no way it should put your hands asleep unless these is something physically wrong with you. I've had carpal tunnel surgery on both hands and my motorcycle doesn't put my hands asleep.
    As for the test I asked you to do. You felt no vibration from the truck up to 3K when the truck wasn't moving. You had mentioned previously that you noticed it at lower rpms under load while moving. So I'm thinking engine, trans and exhaust are not the issue. Next I would inspect the driveshaft for damage. I would also jam some rubber between the leaf springs to eliminate them as the cause.
  25. Jun 19, 2021 at 5:00 PM
    #85
    Peterjohn
    Sour patch kid.. first your sour then your sweet and give me solutions to try.. I’ve check driveshaft all seems normal, all weights appear to be in place. If it was from the rear wouldn’t I feel it in floor or rear seats? I’ve even rode in the bed only up to 30.. didn’t feel anything serious.
    last service manager that drove it said the engine maybe starting to break in. I told him I don’t think Toyota engineers designed a truck to vibrate the steering wheel when the engine breaks in at 9200 miles.
    Going to try a local shop this week before trading it in..
  26. Jun 19, 2021 at 8:24 PM
    #86
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm just repeating what your saying. It's hard enough to diag your problem without adding confusion.
    Anyways I'm out. Good luck to you.
    French Avocado and Kn4x2 like this.
  27. Jun 20, 2021 at 5:59 AM
    #87
    Peterjohn
    Not lying or exaggerating I drive with my left hand, pointer and thumb most the time. It sits on the door and yeah they were going to sleep while driving I had to keep switching hands. I’ve rode a couple bikes and this can be worse. Not sure what you have.
    I was trying to make light of the situation but apparently we have different senses of humor, I’m sorry didn’t mean to upset you.
    thanks for the pointers and I appreciate the help.
  28. Oct 9, 2021 at 12:23 PM
    #88
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
    Having the same issues. It was intermittent up till the last service. Now I can feel it in the steering wheel (lower portion) and in the gas pedal. Definitely noticeable around 30-35mph and 70-75mph.
    Tires were rotated during this past service, which leads me to believe it is a balance or alignment issues. Going to take it back soon to have them check. Hopefully it doesn’t require multiple trips. Truck has 20k.
  29. Oct 9, 2021 at 12:27 PM
    #89
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    My experience would lead me to believe the techs may have not put your wheels back on correctly. Just take them off one at a time and put them back on, making sure to tighten the lug nuts in a cross pattern and see if that fixes it.
  30. Oct 9, 2021 at 5:51 PM
    #90
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I’ll add that it’s not an alignment issue. Vibrations are caused from something rotating. There is nothing rotating with a bad alignment. Look for items such as tires, wheels, rotating brake parts and driveline.
    diablodalton and Cpl_Punishment like this.
