Rear seat fold down mod
Discussion in 'General Tundra Discussion' started by joonbug, Oct 29, 2016.
  1. Dec 9, 2020 at 5:01 PM
    #91
    Freakenrage
    Freakenrage New Member
    2013 Tundra DBL cab RW
    Two XS batteries D3400 NVX 10 farad cap Samsung tablet Arc KS 600.2 sub amp Arc 4050 CXLR 4 channel amp Sinfoni Quartorigo Mids and Highs (front) Deaf Bonce Sylverster Mid (rear) Sundown Audio tweeters (rear) SMD fuse holders SMD Output Meter (SMD-OM-1) SMD Output Meter (SMD-OM-1) SMD Voltage Meter (SMD-VM-1) Two JL Audio Powerwedge 10TW3-D4 2-Ohm Zero ga big three K&N CAI 3-Trumpet Train Air Horn Kit 150dB Access Cover Hood Guard AMP power steps Westin Bull Bar Bully Dog GT+T tuner 35/12.5/17 Steel grill Hammerhead rear bumper Coachbuilder 3" Shackles Coachbuilder steering stops and Tie rods Linex bed coating Morimoto Headlights and fog lights
    Sorry If I mess this up, I'm new to the forum. I made risers for my rear seat and I can now fold down my rear seat without the hook mod. I'm not done with the risers yet but it works great for clearance under the seat and now the back of the seat folds down. Not even using the bolts on the back. no issues yet.
  2. Dec 9, 2020 at 8:08 PM
    #92
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Interesting, raising the rear seat seems to accomplish the same thing as shortening the hooks or bending the hoops.
    Nice work BTW :thumbsup:
  3. Dec 10, 2020 at 5:44 AM
    #93
    Freakenrage
    Thanks, I was hoping the risers accomplished both things. Now I can get to the rear battery terminals if needed.
  4. Dec 10, 2020 at 6:15 AM
    #94
    Trooper2
    JR
    And welcome to the forum.
    You should introduce yourself in the New Members thread. Mention your handy work there as well.
  5. Dec 10, 2020 at 6:17 AM
    #95
    Freakenrage
    I was just reading the intro email from Bob to do that. Lots of good stuff in here, thanks.
  6. Dec 18, 2020 at 7:21 PM
    #96
    LennyFL
    LennyFL New Member
    New to me 2007 with 59,600 miles
    I can't tell from the pictures but how did your raise them? How high?
  7. Dec 18, 2020 at 8:31 PM
    #97
    Freakenrage
    I did a 1 1/2" square pipe that I bought at home depot then cut it down. I did have to get longer bolts for the posts, but it worked great. I'll be driving all day tomorrow but could get more pic's if it will help. To raise it up I put a small bottle jack under the seat with it folded up to raise the back then bolted the front feet down and it was good to go.
    619Tundra likes this.
  8. Dec 18, 2020 at 9:46 PM
    #98
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    This is great. I would like to do this mod tomorrow morning. I also have a pair of 10TW3s and need room for the grilles. Nice set up. Can you post more pics?
  9. Dec 19, 2020 at 5:58 AM
    #99
    Freakenrage
    Thanks, I'll post more, but it will be tomorrow. Driving about 12 hours today, but will get you some more pic's.
    619Tundra[QUOTED] likes this.
  10. Dec 19, 2020 at 6:04 AM
    #100
    619Tundra
    Thanks. How tall is your box? I'm building one right now. Does the grille hit the bottom of the seat?
  11. Dec 19, 2020 at 6:08 AM
    #101
    619Tundra
    Here's my box, I'm trying to figure out the mounting depth of the sub so that it won't hit the bottom of the seat with the grille. I appreciate your input.
    MTRock likes this.
  12. Dec 20, 2020 at 9:43 AM
    #102
    Freakenrage
    Wow that is a nice box. I did two separate boxes and yes they hit the seat. I actually used them like that till I built an amp rack and that touched. I almost built a box but these worked if I cut some of the seat posts back.
    CS110LG-TW3. Single 10TW3 PowerWedge, Sealed, 2 Ω
    External Width (W) 20.75 in / 527 mm
    External Height (H) 14 in / 357 mm
    External Depth (D1) 4.5 in / 114 mm
  13. Dec 20, 2020 at 10:22 AM
    #103
    619Tundra
    How tall is the box? What seat post did you cut?
  14. Dec 20, 2020 at 10:27 AM
    #104
    619Tundra
    I see 4.5 in depth. Does it hit the grille still after lifting the seats 1.5 inches?
  15. Dec 20, 2020 at 11:14 AM
    #105
    619Tundra
    The website says 6-1/4 in depth.
  16. Dec 20, 2020 at 11:20 AM
    #106
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    So what are you guys that do this mod using it for? I almost like having the extra height (like when folding the bottom part of the seats up) versus width for storage
  17. Dec 20, 2020 at 2:07 PM
    #107
    Freakenrage
  18. Dec 21, 2020 at 5:49 AM
    #108
    Freakenrage
    Sorry did not see this. No I'm clear with the risers.
  19. Dec 21, 2020 at 5:51 AM
    #109
    Freakenrage
    I did it so my sub grills don't hit and my amp after the rack I built.
  20. Dec 21, 2020 at 5:55 AM
    #110
    619Tundra
    Nice. I looked up the box dimensions and they give me a depth of 6-1/4, that must be with the grille on?
  21. Dec 21, 2020 at 6:42 AM
    #111
    Freakenrage
    Yeah that is with the grills on. I should have just taken a pic with the tape measure on it. I'm fighting a bit of power drain on longer playtimes. I really need to upgrade my alternator, but that damn thing is under the engine. errr.
  22. Dec 21, 2020 at 6:51 AM
    #112
    619Tundra
    How many watts are you running?
  23. Dec 21, 2020 at 7:01 AM
    #113
    Freakenrage
    Arc KS 600.2 sub amp -- I did not test the true power, but I'm sure it's over the 1200 watts.
    Arc 4050 CXLR 4 channel amp -- I do have the spec on this one and I'm doing a little over 800 watts on this one.
    I thought the two XS 3400 batteries and 10 fraud NVX cap would hold it longer. I started dipping into the 11's on power Saturday, not good for sub amp. Waiting to see if Mechman 240 goes on sale this month. I'm pissed I did not pick one up around Thanksgiving when they were on sale.
  24. Dec 21, 2020 at 7:12 AM
    #114
    619Tundra
    Check out HKB
    Check out HKB electronics.
    Freakenrage[QUOTED] likes this.
  25. Dec 21, 2020 at 9:36 AM
    #115
    619Tundra
    Did you modify the mounting point on the rear wall?
  26. Dec 21, 2020 at 10:21 AM
    #116
    Freakenrage
    No, the hooks hold the seat in tight, so the rear mounts with the screws are not being used now. I'm glad I didn't do the hook mod before this. I did sound deaden the whole back wall.
  27. Feb 27, 2021 at 7:27 AM
    #117
    Dickey
    Dickey New Member
    Katie
    Spring, TX
    2008 tundra dc 2wd and 2011 tundra cm trd 4x4
    i have a 2011 crew max and the seats do fold down
    well 1 of mine folds down and the other is broken im actually looking for the part number to fix the handle
    does anybody know the part number?
  28. Jun 9, 2022 at 5:31 PM
    #118
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    I only have an answer for #2 if it helps you sleep at night… found it elsewhere on the forum AFTER I did the mod to put a grab handle on. It was for a NHTSA score increase (sorry, I meant your own safety :confused:) so your head doesn’t hit it during a forward-force impact.
    gosolo[QUOTED] likes this.
  29. Jun 9, 2022 at 5:37 PM
    #119
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    So passengers don't count against the score?
    1lowlife likes this.
  30. Jun 9, 2022 at 5:40 PM
    #120
    Northwest Arkansas
    I think the shotgun-side full dash airbag is bigger volume and helps prevent that. I also found an airbag in the driver’s side a-pillar when I was installing the oh-sh!t handle. Although… every time I look at it now, I think about my head hitting it and drive safer.
