Let’s see your aftermarket front and rear bumpers!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMB4x4, Apr 23, 2019.
  1. Oct 5, 2020 at 4:33 PM
    #331
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    You have a 2016 so you do not need a pro grille for the bar on a C4 bumper, because you do not have the TSS system. That is the only thing the bar affects.
    Your sonar is the parking sensors, and many bumpers have the sensor cutouts. If you replace your rear bumper you will lose BSM if you have it. The sensors for this are inside the rear bumper, and sit behind the plastic. They cannot see through the metal corners of aftermarket bumpers. This is why all trucks with BSM have color matched rear bumpers.They are NOT the small round sensors. Those are your parking sonar and will work fine as long as the bumper has holes to mount them.
  2. Oct 6, 2020 at 11:23 AM
    #332
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I cut it that way and designed the bumper to match the angle. There is plenty of room based on departure angle for the wheeling I do.
  3. Oct 7, 2020 at 8:53 AM
    #333
    King R 808
    King R 808 New Member
    2020 White Tundra TRD Pro
    12 K Smittybilt X-20 Synthetic line.
    matictundra likes this.
  4. Oct 7, 2020 at 8:54 AM
    #334
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    same
  5. Oct 7, 2020 at 8:56 AM
    #335
    King R 808
    Full height bar does not interfere with TSS
  6. Oct 18, 2020 at 8:04 PM
    #336
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    This Overland Bumper won't interfere with TSS right? Close to pulling the trigger.
  7. Oct 18, 2020 at 8:51 PM
    #337
    Wyoming
    Depends on what grille you have. If you have the pro grille that is pictured then you're fine. If your sensor is behind your emblem then the bar pictured will interfere.
    Bakelite[QUOTED] likes this.
  8. Oct 18, 2020 at 9:02 PM
    #338
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    @2020Platinum changed the game with his mod. I would check out his YouTube video around tss sensor relocation into the lower grill surround. That is what I am planning on doing to run my demello front bumper
    2020Platinum likes this.
  9. Oct 18, 2020 at 9:05 PM
    #339
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    Still going strong, this spot worked perfectly!!...no error codes at all, and if anything my sensor is actually a little more sensitive than it was in the original location....I’ll be doing a follow up video on it, here’s the link for the relocation for anyone who would like to see where I put it!
    https://youtu.be/rDTXe9eNAFg
    GODZILLA and itsZEUStime like this.
  10. Oct 19, 2020 at 5:45 AM
    #340
    King R 808
    Negative! Works fine still on mine
  11. Oct 19, 2020 at 10:08 AM
    #341
    Bakelite
    Bakelite New Member
    Sam
    Fellow Texan!
    Thanks for the response and picture - Look great! I did upgrade to the pro grille so it looks like I am ready to rock and roll.
    Thanks again.
    GODZILLA likes this.
  12. Oct 27, 2020 at 10:35 AM
    #342
    redkone1
    redkone1 New Member
    Red
    2018 Toyota Tundra 1794
    @King R 808 - I have the same smittybilt 12K winch, where did you locate your controller box? the wire lines are so short.
  13. Oct 27, 2020 at 11:11 AM
    #343
    matictundra
    Franco
    AZ
    I did my bro with C4 hybrid and Smitty 12K X2O winch. I mounted the control box to the right (passenger side) of the winch with provided bracket, no issues with power cable reaching the stock battery location.
    King R 808 likes this.
  14. Nov 17, 2020 at 7:13 PM
    #344
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    17 TRD PRO Barcelona Red
    just threw stuff at it
    RC released a new weld it yourself bumper. Doesnt look bad.
    Screenshot_2020-11-17 Toyota Front DIY Pre-Runner Bumper Kit (14-20 Tundra).jpg
    Ob1, DanGunit69, Dr.Nut and 2 others like this.
  15. Dec 12, 2020 at 11:11 PM
    #345
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    How did you flip the OEM receiver?
  16. Dec 13, 2020 at 3:37 PM
    #346
    Dr.Nut
    Dr.Nut New Member
    2011 Tundra CrewMax 5.7L
    I'll see if uncle would like this for his incoming 2017 Tundra project. We'll start working on it after we finished installing the suspension and dually wheels on the current Superduty project.
  17. Dec 16, 2020 at 2:40 PM
    #347
    matictundra
    Franco
    AZ
  18. Jan 6, 2021 at 5:29 PM
    #348
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Need help accessing my dashboard switch area
  19. Jan 7, 2021 at 8:02 PM
    #349
    HighonFirewood
    2019 Tundra
    I’m asking in this forum because I’m adding an OEM style light bar switch and I only have one blank spot available.
    I’m trying to access this blank switch:9980DCD0-A362-4215-9A67-43BA8F8AD8C2.jpg
    I’d like to either relocate my parking sensor (which will no longer be used and use that spot) or add the light bar switch to this location.. Can I enter through the cup area? I can’t find much info on this area. I don’t won’t to pull my dash and would like to enter through the bottom...
    any info is appreciated.
    ghost0211 likes this.
  20. Jan 8, 2021 at 8:54 AM
    #350
    matictundra
    Franco
    AZ
    I highly recommend to have a plastic panel removal tool.
    1. Take off the shift knob and put a rag over the threads so you don't scratch anything.
    2. Pop off the center console
    3. Remove the panel you identified, the HVAC panel may pop off with it.
    Tons of youtube out there...
  21. Jan 8, 2021 at 10:40 AM
    #351
    HighonFirewood
    2019 Tundra
    Yeah I can’t find that specific spot...I looked through a fair amount of em the last 2 days. I can pop the console super easy. I just want access to that switch. I plan to look tonight. Thank you
  22. Jan 8, 2021 at 12:03 PM
    #352
    matictundra
    Franco
    AZ
    Watch this...
    https://youtu.be/Y2FpifJdsRM
  23. Jan 8, 2021 at 2:36 PM
    #353
    HighonFirewood
    2019 Tundra
    Holy shit. I didn’t think that video had that info. I skipped over it multiple times! Thanks much, that’s wicked simple.
    matictundra[QUOTED] likes this.
  24. Feb 26, 2021 at 3:19 PM
    #354
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Does anyone else know of a front bumper that accommodates for wider fiberglass fender flares? I see C4 does but haven't seen anyone else
  25. Feb 26, 2021 at 3:33 PM
    #355
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What kind of glass some are wider then others
  26. Feb 26, 2021 at 3:47 PM
    #356
    cctxquicksand
    Demello will accommodate wider fenders
    here’s a shot of the overhang on the sides of the bumper
    SmokinGunner and equin like this.
  27. Jun 25, 2021 at 2:25 PM
    #357
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    ironman4x4 has a new bumper up for pre-order. design looks like an upgraded Westin Outlaw
  28. Jul 14, 2021 at 9:18 AM
    #358
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Saw this one the other night on a second gen. I appreciate the simplicity
  29. Jul 14, 2021 at 9:23 AM
    #359
    :puke:
  30. Sep 16, 2021 at 5:09 PM
    #360
    Ob1
    Ob1 New Member
    Went looking for a welder that could handle this project a couple of weeks ago. Finally found one and went to order today, now the bumper's gone up $100 bucks. Now having second thoughts.
