Need new u-bolts after SumoSpring install?
Discussion in 'Suspension' started by BrakeDust, Feb 24, 2021.
  1. Feb 24, 2021 at 4:14 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I installed Sumo Springs, instructions said to completely loosen the axle u-bolts, swap out the stock rubber bumpers and then torque the bolts again. No mention of replacing the bolts.
    Yet I've read here that the bolts are designed to stretch and the threads will deform. New bolts are required.
    Which is it? Am I going to be ok provided I never touch them again? Or should I get new bolts? If yes, what kind?
  2. Feb 24, 2021 at 4:24 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  3. Feb 24, 2021 at 5:59 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    my understanding was that u bolts were one time and done because they stretch and bend slightly when torqued. However, this install and others I looked up reuse the original u bolts. So, I am no help!
    https://www.youtube.com/watch?v=8k4fM6GKtaQ
  4. Feb 24, 2021 at 6:05 AM
    Yes I was on the fence about it too when I moved my lift over from truck to truck. I got a new set from Toytec....about $40.00 or so. Well worth the piece of mine especially if you have kids that ride with you.
    GODZILLA likes this.
  5. Feb 24, 2021 at 7:12 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    I wouldn't stress over it. I would say if you re-use them, as I did with my Timbren install, just recheck the torque after a few hundred miles. They aren't going to break, the biggest concern is just not keeping the proper torque if they stretch. I have reused plenty of yield to torque bolts more than once :notsure:
    equin likes this.
  6. Feb 24, 2021 at 9:58 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You will be fine. Just torque to spec and check them again after a week of driving.
    Just to add. Make sure the threads are clean before you undo the nuts. Also apply some lube to the threads to protect them when you undo them. Make sure you clean the top of the leaf spring before setting the Sumospring in place. Bottom plate should be free of dirt.
    BulldogDan and JohnLakeman like this.
  7. Mar 19, 2021 at 12:17 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Torque em to 75 - 80 and you will be fine.(use blue loctite on the U-bolts also)
    If your a worry wart, Pick up another set of nuts in the Nylock or aircraft type that do not come loose.
    Pop those on after the original have been torqued to spec and nothing will come loose no matter what.
    Not even if you run over an IUD.... truck will be in shreds but those nuts will be still tight.
    Hbjeff and Jhon like this.
  8. Jun 18, 2022 at 7:56 AM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    I just ordered the black Sumos and this was a concern of mine too. I will take all the good advice here and re-use the original U-bolts, loctite and recheck after a few hundred miles.
  9. Jun 18, 2022 at 8:02 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put brand new ones on then loosened them to install my bump stops. Re-torqued. Checked torque again a couple weeks later. No problems.
  10. Jun 18, 2022 at 8:06 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oh and never use lock washers or soft metal washers.
    BulldogDan likes this.
  11. Jun 18, 2022 at 8:09 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I can’t believe no one jumped on this typo. And he’s not even here to rib anymore.
  12. Jun 18, 2022 at 8:11 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    If you use loctite don't recheck, unless you check at like 10lbs less than what you torqued them too. You run the risk of breaking the loctite off the threads.
    BulldogDan[QUOTED] likes this.
