Supercharger long term reliability?
Discussion in 'Performance and Tuning' started by BenAZ, Mar 23, 2017.
  1. Feb 5, 2021 at 9:17 AM
    #181
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    I made an adapter plate for the stock brake controller spot, and then moved those switches to the left.
  2. Feb 23, 2021 at 7:56 AM
    #182
    Warreng
    Warreng New Member
    i bought a used one with a SC. It was clearly taken care of, but zero issues so far.
    HulkSmurf14 and gosolo[QUOTED] like this.
  3. Feb 23, 2021 at 7:58 AM
    #183
    Warreng
    Warreng New Member
    Have a TRD supercharger with whatever intake came with the kit. What is everyone using for a replacement air filter? Apparently they do not make the TRD one anymore.
    HulkSmurf14 likes this.
  4. Feb 23, 2021 at 9:01 AM
    #184
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I too purchased a used one with stellar maintenance history...I have zero regrets on its reliability.
    I have the TRD airbox and just purchased a TRD air filter...if not available, I'd consider the AFE dry filter and be done...
    Warreng and snivilous like this.
  5. Feb 23, 2021 at 9:14 AM
    #185
    snivilous
    SW UT
    Something to add to this thread, my supercharger was getting loud a few months ago so I reached out to Superchargers Online (Magnuson had recommended I buy parts from them prior, and I had learned they rebuild blowers) so I sent mine to them. It was $1250 iirc for the blower to be torn down, new bearings and fluid and coupler and cleaned and all that jazz, and then they run it on a test rig to make sure it's working. It turned out mine had somehow ingested something (a bolt, a rock, who knows) and had caused the rotors to become mis-timed so they were running into each other which is why it had become so loud, and sounded like a bearing had failed due to the rotors being pushed apart when the FOD went through the rotors. It was another $1600 iirc for new rotors from Eaton. I also sent in my injectors and they cleaned and flow tested them too. All in was ~$2850 and that was to get the most extensive "maintenance" possible and effectively getting a brand new supercharger (minus housing) back.
    So in regards to actual supercharger maintenance, which regularly should be non-existent besides maybe new oil every 100k, $3000 is effectively the maximum cost one can expect to replace everything. If your rotors didn't have a critical failure like mine, it'd be ~$1250 to have someone service everything and make it cherry. $1250 every 5-10 years to get your $8000 supercharger freshened up seemed like a good deal to me, and Superchargers Online were super cool about everything.
    Joro43, KJJ2007, WSDMetal and 7 others like this.
  6. Feb 23, 2021 at 10:46 AM
    #186
    Warreng
    Warreng New Member
    Is the air filter for the generic trd intake or is it different for the SC?
    HulkSmurf14[QUOTED] likes this.
  7. Feb 23, 2021 at 10:53 AM
    #187
    AZTundra
    Paul
    Phoenix, AZ
    My Mag came with a K&N filter which is another available option.
  8. Feb 23, 2021 at 11:45 AM
    #188
    HulkSmurf14
    2014 Tundra Limited
    @Warreng, just a regular TRD air filter...it came oiled and I cleaned it most of the way off and reinstalled...it's doing well and my intake tube is still clean and not collecting debris over 10k miles...I shake it out every oil change...
  9. Feb 23, 2021 at 12:19 PM
    #189
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    My brother in-law just blew up
    His motor. 2015 w 150,000 miles. He had a larger magnusson blower on it. I’m sure he was always pushing it though.
    Joro43 likes this.
  10. Feb 23, 2021 at 12:24 PM
    #190
    snivilous
    SW UT
    Do you know specifics of what failed? What tune and fuel system was he running? Does he closely monitor his afr and temperatures?
    Tundyfundy[QUOTED] likes this.
  11. Feb 23, 2021 at 12:27 PM
    #191
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    My experience with K&N filters on the taconite ships (Cat gens) they do not filter out the fine dust all that well, they are very free flowing and basically just keep the large particles out. One other thing I'm not impressed with is the fit, as seen in picture. 20210215_204945.jpg
    And that was after stretching a bit.
  12. Feb 23, 2021 at 1:02 PM
    #192
    Warreng
    Warreng New Member
    ok thanks.
    ThAts the one I have as well. Not a fan of oiling filters. Was looking to get the dry style one and dont want to order the wrong one
  13. Feb 23, 2021 at 3:45 PM
    #193
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    You can’t just come in here and only say that. We need details! Tune, what specifically failed, which larger blower, etc.
    Joro43 and HulkSmurf14 like this.
  14. Feb 23, 2021 at 4:24 PM
    #194
    Tundyfundy
    Bay Area, CA
    I’m trying to get the details... I’ll for sure post them. Sorry for the wait
  15. Feb 23, 2021 at 4:25 PM
    #195
    Tundyfundy
    Bay Area, CA
    Waiting for details I’ll post back.
  16. Feb 23, 2021 at 7:38 PM
    #196
    wyso
    wyso New Member
    chris
    2010 Tunda
    TRD supercharger, big brake kit, 22 TRD wheels
    I'm at 145k. Stock TRD tune and parts. Replaced coupler at 140k.
    pvmike, Saltyhero13 and HulkSmurf14 like this.
  17. Apr 8, 2021 at 2:50 AM
    #197
    HighkmSCtundra
    HighkmSCtundra New Member
    Hey guys, just wanted to let ya know that I have just picked up a tundra that is all original and has had a SC since it has left the showroom in 2012. It currently has 375,000km on it and is running as if she has just left the showroom. The original owner is my boss and has religiously and meticulously done all of the services. He used it as his daily and to pull around his toy hauler/camper. I believe with the same care and the condition that it is currently in, I will get to 500 without any problems
    Joro43, MTRock, pvmike and 6 others like this.
  18. Apr 8, 2021 at 8:20 AM
    #198
    Warreng
    Warreng New Member
    amazing!
  19. Apr 22, 2021 at 6:11 PM
    #199
    Tcipp
    Tcipp New Member
    Todd
    2011 Tundra Crewmax
    TRD supercharger
    I own a 2011 Tundra crewmax that i had a TRD supercharger installed on when it was new. It has 150K on it and still runs very well
    Joro43, pvmike, T-Rex266 and 3 others like this.
  20. Apr 22, 2021 at 7:01 PM
    #200
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I have a 2012 cm with dealer installed sc that has under 90k smokes like a freight train and burns a sh!t load of oil, undrivable!
    L.o.f. every 5,000 miles with premium synthetic oil.
    Not sure what happened to it, haven't taken it apart to find out yet.
  21. Apr 22, 2021 at 7:28 PM
    #201
    TXTundra2722
    2015 Black Tundra
    Clearly it was driven like it was stolen, everyday of its life!
    Saltyhero13 likes this.
  22. Apr 22, 2021 at 7:33 PM
    #202
    Dr Doobie
    Talkeetna,Alaska
    Well not everyday.:thumbsup: lol
    SnowyTundra and Saltyhero13 like this.
  23. Apr 22, 2021 at 8:02 PM
    #203
    Tcipp
    Tcipp New Member
    Todd
    2011 Tundra Crewmax
    TRD supercharger
    The only issues I have had with mine are.
    1. I had to install an Eaton posi rearend as every time I stepped on the gas I spin the tires and the lsd would kick the brakes in
    2. I’m on my third TRD fuel pump
  24. Apr 22, 2021 at 8:04 PM
    #204
    Tcipp
    Tcipp New Member
    Todd
    2011 Tundra Crewmax
    TRD supercharger
    I would buy a new one but Toyota no longer offers them in Canada with the supercharger option and full warranty so I keep driving it
  25. Apr 22, 2021 at 8:11 PM
    #205
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Soooo did you end up going down this road?
  26. Apr 22, 2021 at 8:20 PM
    #206
    Tcipp
    Tcipp New Member
    Todd
    2011 Tundra Crewmax
    TRD supercharger
    Not sure I understand your question? I love the truck, quick, powerful, easily able to pull my horse trailer with 3 horses in it. And it will outrun most sports cars. I’m just pissed at Toyota from take the option to buy a new one away from me. My supercharger needs a service, tempted to buy a replacement with a smaller pulley. Can never have too much horsepower lol.
  27. Apr 22, 2021 at 8:21 PM
    #207
    Tcipp
    Tcipp New Member
    Todd
    2011 Tundra Crewmax
    TRD supercharger
    I think you plan a big bottom-end build? I am also considering this, done it on some of my late-model muscle cars, just not sure it is worth it on a 2011 truck?...
  28. Apr 25, 2021 at 3:59 PM
    #208
    snivilous
    SW UT
    It's like $1200 to have the supercharger fully refurbished, or you can do it yourself. There's no need to buy a new one, it's just a couple bearings and worst case the rotors are destroyed (unlikely) and then it's another $1200, long shot from buying another one most likely. I would also recommend one of the fuel pump options from URD if you keep having issues with your pump, I have an aeromotive pump in mine and have 30k+ miles on it in the past year and a half.
  29. Apr 26, 2021 at 4:16 AM
    #209
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    Hello All...
    I was looking at Magnuson website.... It does not show a SC for +19 Tundra's yet. Really would like to do this on my 21 PRO. Is everyone's think that this is available with Magnuson for +19 Tundra?
    If i didn't read well enough above... tell me to go read more!:(
  30. Apr 26, 2021 at 4:21 AM
    #210
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They may not support the most recent model years because they're not able to tune the ECUs just yet. I imagine that they will in time though.
