285/65/R18 pics on stock Limited
Discussion in 'Wheels & Tires' started by Mr. Wolf, Dec 12, 2020.
  1. Dec 12, 2020 at 3:59 PM
    Mr. Wolf
    Mr. Wolf [OP] New Member
    Hello
    I have a 2021 Silver CM 5'6" Limited with stock shocks riding on 275/55/R20's. I do plan on upgrading to the suspension to the Toytec Aluma Series but perhaps in a few months/once Covid subsides but in the meantime, I am keeping stock height and wanting to swap out the 20's for 18's (and a set of Toyo OC IIIs). So looking to see if anyone has pics of their stock-suspension trucks on 285/65/R18s as I'm not sure If I should go bigger? I know of that helpful breakdown/chart of max tire sizes but was hoping to see some more photos as I want to have my cake and eat it to by having larger tires that fit now, and, won't look too small when I add the Toytec 3/1 setup in the future. Or am I being unrealistic??
    Mr. TruckGood likes this.
  2. Feb 21, 2021 at 4:14 PM
    Mr. TruckGood
    Mr. TruckGood New Member
    Jeff
    2016 Limited Crewmax, MGM
    I have the same question. Any pictures would be great.
  3. Feb 23, 2021 at 9:11 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 fit perfect on a stock truck, so the 285/65 should be good to go as well. The 275s are slightly taller and the 285s little shorter but slightly wider.
    The 285/65s are more expensive size vs the 275s, cost $20-50 more per tires based on a quick search. Also know that moving to either size means moving from the stock standard load tires to E rated.
    Here are some pictures of 275/70-18s on a stock truck.
    Old.Ski.Bum likes this.
  4. Feb 23, 2021 at 9:40 AM
    Mr. Wolf
    Super helpful, thanks for responding!
