Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Feb 22, 2021 at 6:36 PM
    #781
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Man these things are nice. Did you order directly thru Diamondback? Is there any wait time for the them? That smooth cover correct?
  2. Feb 22, 2021 at 8:21 PM
    #782
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Ordered directly from Diamondback on December 21st and received it on February 3rd. Yeah, it’s the smooth finish SE. I took my time installing it. I’ve yet to leak test it......I snugged down center panel (not too tight) and I used four 5 quart jugs of motor oil (say 30-35lbs.) to set the panel locking bars.
  3. Feb 22, 2021 at 8:24 PM
    #783
    RusPro21
    Don
    Pa.
    Thanks Will!!
  4. Feb 22, 2021 at 8:32 PM
    #784
    Hackasaw44
    Hackasaw44 New Member
    Rich
    Santa Rosa Beach, FL
    2014 Tundra Double Cab
    Du-Ha under seat storage
    I finally installed my Diamondback 270 this weekend after patiently waiting through two weeks of cold and rain. Super happy with the results. I installed the weatherstrip on the forward bulkhead, shims under the bed rail caps, and had time to center the panels, clamp them down and set the locking rods on the rear panel before it got too dark. Then we had a heavy rain last night and I hadn't finished adjusting the locking rods under the forward panels. They just sat on the bulkhead gasket and bed caps. No water got in. Now that everything is tightened down, I'm confident my equipment will stay dry and secured.
    I also ordered two sets of anchor cleats but they weren't in the package. Diamondback had 10 staples on each side of the cardboard box but when the pallet arrived, the lid was pulled open on both sides. The packing slip showed they were shipped along with the tonneau and cross bin. I won't name the freight line. I called the Diamondback shipping department and Mike was quick to send out two more sets, no questions asked. I couldn't ask for better service.
    It took me while to decide on the DB because of cost but once I realized the importance of protecting my investment in equipment, it was a no brainier. Money well spent. I couldn't be happier with this DB 270 looking forward to putting it in service.
  5. Mar 1, 2021 at 2:18 PM
    #785
    Jtpop610
    Jtpop610 New Member
    Jacob
    Charlotte
    2021 MGM Limited TRD OR
    Looks like two smooth SE Crewmax covers were posted to the outlet page. I just purchased one for $1439 with 3 day shipping, and it has a blemish you can't even see.
    Thanks to all who provided so much information on this thread. Buy once, cry once!
    Also, figured you can always turn around and sell it for $1k in a few years, where a BAK or cheaper cover may only fetch 300-400. Taking a $500 hit either way!
  6. Mar 1, 2021 at 2:20 PM
    #786
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I watched the outlet for a while but just got tired of waiting.
    Plan is to keep the truck until it gets totaled or rusts out anyway
  7. Mar 1, 2021 at 4:51 PM
    #787
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    I have the undercover flex and same issue. Every few months the screws fall out the rear panel. Tried threadlock, large gr er sheetmetal screws , still fall out. Diamondback will be in the future.
    French Avocado likes this.
  8. Mar 1, 2021 at 4:57 PM
    #788
    scout495
    scout495 New Member
    No matter what I tried it didn’t work. Teflon tape, coat the screw with gorilla glue, etc. I tried it all.
    don3032[QUOTED] likes this.
  9. Mar 3, 2021 at 6:44 PM
    #789
    Foster
    Foster New Member
    NE Ohio
    2020 Platinum Crewmax
    So my HD with the black (not smooth) finish is supposed to arrive next Friday. I’m curious, how easily does this cover scratch? I plan on hauling lumber and pelican cases most frequently on top. Second question is there has been a lot of discussion about applying black silicon to various places. Is this an OCD thing or should I just go ahead and apply it under the bed rail caps while I’m installing the shims?
  10. Mar 3, 2021 at 8:20 PM
    #790
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    April 4th is my estimate for the smooth black HD. Can't wait!
  11. Mar 3, 2021 at 8:26 PM
    #791
    Willard
    Willard New Member
    2022 Frontier Pro-4X
    The instructions recommend a bead at the front end of the bed side caps. Doesn’t need to be black - it’s underneath. I had slight leaking at the front corners until I did this. I also filled the small gaps between the bed sides and front wall at both corners.
    Occidentalis likes this.
  12. Mar 4, 2021 at 4:41 PM
    #792
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Definitely doesn't scratch easy, haven't thrown a toolbox at it but have tossed random stuff on top and don't have a scratch.
  13. Mar 11, 2021 at 2:16 PM
    #793
    Succinct55
    Succinct55 New Member
    2021 Tundra Platinum
    Hey you'll new guy here. Thank you all for sharing those great pictures. I have been looking for tonneau cover for a while and finally run into this forum.
    Just wanting to check on the consensus regarding the anchors for the DB SE. Do you all think that having it preinstalled is best?
  14. Mar 11, 2021 at 2:45 PM
    #794
    Willard
    Willard New Member
    The tie downs? Do you intend to use them? I did not have them preinstalled and haven’t needed them a single time.
  15. Mar 11, 2021 at 9:07 PM
    #795
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Received Diamondback HD today and got it installed. Super easy, hardest part was tweaking the rods to line up in the bed rails when locking it in place. I ordered it without the cleats installed and am debating whether or not to add them. Super happy with my DB so far.
  16. Mar 11, 2021 at 9:11 PM
    #796
    Occidentalis
    North Florida
    I ordered mine with the cleats pre-installed. Happy to see more pics of the smooth finish
    They help me while I wait.
    THOR's and Clemshady like this.
  17. Mar 14, 2021 at 5:19 AM
    #797
    Willard
    Willard New Member
    Just saw this on my IG feed - Uptop has some new brackets that allow their rack system to attach to the top of a diamondback cover. These photos show one on a Tacoma but they have said if you give them the dimensions they can easily assemble one for a Tundra.
    Two heights offered, 6” and 11.5”, both allow the panels to open when nothing is mounted on top of the rack.
    https://www.uptopoverland.com/products/tacoma-diamonback-truss-bed-rack-2018-2021
    7AE758FF-8492-4DDB-8ABA-BDB4ABE873DE.jpg 58857F8C-C503-4160-9CB7-F9FE7B87D676.jpg
    don3032, equin, Hackasaw44 and 3 others like this.
  18. Mar 14, 2021 at 6:46 AM
    #798
    don3032
    don3032 New Member
    don
  19. Mar 14, 2021 at 6:50 AM
    #799
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
  20. Mar 14, 2021 at 6:59 AM
    #800
    Red8654
    Red8654 New Member
    Eddie
    2014 Toyota Sequoia
    Talk to me about that slide out Pop? I have the same cover and would LOVE something like that
  21. Mar 14, 2021 at 7:12 AM
    #801
    Willard
    Willard New Member
    Definitely a little jealous. Slightly worried about the loss of height. Hmm!
  22. Mar 14, 2021 at 12:30 PM
    #802
    pop's
    pop's 1794
    Michael
    North Aurora IL
    $7500 in upgrades
  23. Mar 14, 2021 at 12:32 PM
    #803
    pop's
    pop's 1794
    Michael
    North Aurora IL
    $7500 in upgrades
  24. Mar 14, 2021 at 11:27 PM
    #804
    Clemshady
    Jeff
    I should have had mine pre-installed too. Huge pain in the ass and nerve racking drilling holes in my $2100 DB but I got it done. I thought I would like it without the cleats but it was too plain looking.
    TK1979 and Occidentalis[QUOTED] like this.
  25. Mar 15, 2021 at 3:44 AM
    #805
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    I have the SE with extra tie downs preinstalled. I'm glad that I got the extras and really glad that I had DB install them.
    NewImprovedRon and Clemshady like this.
  26. Mar 18, 2021 at 11:28 AM
    #806
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    There's only one right now for a 1st Gen Tundra Access Cab. I inquired about the suitability for the Double Cab since the bed is about 1/2 inch shorter and this is what they told me...otherwise I would have bought it. Whomever picks it up will get a good deal.
    "Thanks for your interest. Unfortunately the cover for the access cab and double cab are different in length, width, taper, and locking rod placement. These are not interchangeable. Let us know if you have any other questions at all."
  27. Mar 18, 2021 at 11:31 AM
    #807
    Occidentalis
    North Florida
    They go fast! When they posted this there were actually three - two double cabs and a crewmax. The crewmax was an SE and it just had some peeling underneath. One of the DC covers just had misaligned cleats. The other had a weird gap. Gone now though!
  28. Mar 21, 2021 at 10:12 AM
    #808
    Hackasaw44
    Rich
    Looks great Pops! I looked into a full bed slide but was concerned it took up some height for taller items I wanted to store. After tons of research, I decided to make my own with linear slide rails and customized the size to fit my heavy tool systainers. Got the rails on Amazon with a set of 4 bearing blocks for about 80 dollars, and bought extra sets of blocks for another 28. I wanted at least 6 block supporting the panel. IMG_20210222_135844.jpg IMG_20210221_142403.jpg IMG_20210221_155841.jpg IMG_20210222_135931.jpg
  29. Apr 1, 2021 at 9:24 AM
    #809
    Occidentalis
    North Florida
    Shipping is happening soon for my cover!
    equin likes this.
  30. Apr 1, 2021 at 9:47 AM
    #810
    eick
    eick New Member
    I got mine a couple weeks ago right on time. Installed it the day after it came in, looks good, no leaks, no weird looking high panel etc.
    I think after reading this thread the biggest takeaway I got was not over tightening the center panel so I was careful with that and I think the main reason why it worked out so well
    Clemshady likes this.
