Load Rating - New Tires
Discussion in 'Wheels & Tires' started by JonSVSB, Jan 16, 2018.
  1. Jan 16, 2018 at 6:17 PM
    JonSVSB
    JonSVSB [OP] New Member
    Jon
    Santa Barbara, CA
    2017 TRD OR Crew Max 5.7L 4x4
    Hi there.
    Like everyone I'm going down the tire research rabbit hole. I'm 99% I've settled on some Falken Wildpeak's. I'm 90% highway use with some light dirt, and snow use. Size wise I'm ready, but the load rating I'm stuck on. 13 lbs per tire to go to a E rated tire is a lot.
    I have a 4wd Crewmax and will keep the stock wheels.
    Advice? Do I need E rating?
    265 /70 R18 116T SL RBL 47lbs
    265 /70 R18 124S E1 RBL 60lbs
    ColoradoTJ likes this.
  2. Jan 16, 2018 at 6:34 PM
    Slayer
    Slayer Member
    Slayer
    what is the purpose your truck..
    a lot of..
    towing?
    heavy bed loads?
    if not.. you would likely benefit from a bit softer ride & fuel economy with P rating
    Black Wolf and ColoradoTJ like this.
  3. Jan 16, 2018 at 10:19 PM
    LML 3500HD
    Good question and here is my answer:
    The 265/70/R18 is the tire that is on my single rear wheel one ton, and still exceeds my axle load rating. Not by a lot, but still does.
    I like LT tires, but it is difficult to buy tires on the Tundra since the 18’s are on many HD trucks and in the size 265/275. Tire selection is drastically reduced when looking for a LT tire in a load range C or even D. Then you are forced to look at tires that are on your family Buick car for your truck.
    I’m not going to lie to you, put some LR E tires on your truck, you will take a hit on City fuel mileage. I didn’t see as much on long trips.
  4. Jan 17, 2018 at 3:19 AM
    Berettafan
    Berettafan New Member
    2017 CM
    265???
    You mean 275/70??
  5. Jan 17, 2018 at 7:40 PM
    JonSVSB
    Jon
    Santa Barbara, CA
    Thanks everyone. @ColoradoTJ I hear ya. I put 275/70R18 KO2's on my last F150 and noticed the Mpg drop. It is nice though to know whatever I need to do the tires are up to the task.
    Most of my use is a once a week heavy load to the dump, moving furniture, occasional trailer hauling, the whole family and their crap in the truck. So Maybe once a month do I use the whole payload so to speak. Dirt roads only and snow. I'm not off-roading my truck I have a loan on it lol.
    @Berettafan yes, the Falken comes in a 265/70 size. I know there are a lot more options in a 275/70 but was just trying to avoid putting a 60lb tire on there.
  6. Jan 17, 2018 at 7:41 PM
    JonSVSB
    Jon
    Santa Barbara, CA
    Forgot to mention, my commute is like 2 miles. MPG isn't a huge deal as I drive about 1000 miles a month.
  7. Jan 18, 2018 at 4:43 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    I'm in the exact same situation right now. I primarily use my truck for towing my camper but it's a smaller unit with about 400 lbs tongue weight and max capacity weight around 4800. I'd love to save the extra 13 lbs by going with the SL Wildpeak's. Think I should spring for the E or stick with an SL for my use?
  8. Jan 18, 2018 at 6:33 PM
    LML 3500HD
    SL. You’re not going to see the benifit on a LR E except your wallet being much lighter.
    JonSVSB[OP] likes this.
  9. Aug 2, 2020 at 4:39 PM
    jassanch
    jassanch New Member
    Jason L.
    2015 Tundra 5.7L CM
    @sk8142 I’m in the same predicament, did you end up going the SL route? If so, how are they working out for you?
  10. Feb 22, 2021 at 12:47 PM
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    Looking at Faulken's website for ATW3 285/70/R17, any idea why the E tire is lighter?
  11. Feb 22, 2021 at 1:06 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Misprint is my guess. 68.9 maybe
  12. Feb 22, 2021 at 1:14 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    It is the load C 59000350 that is off:
  13. Feb 22, 2021 at 1:59 PM
    Ikonrat
    Ikonrat New Member
    Thanks Sundog. Falken's chart is all screwed up. The tire above it (28030907 LT275/70R17) is smaller type C yet says 57.1 lbs, more than the LT285/70R17 @ 54.97 lbs assuming what you found is correct. My head hurts. Way down the rabbit hole now....I'll reach out to Falken and follow up with what they say.
  14. Sep 10, 2023 at 8:28 PM
    rickyrockrat
    rickyrockrat Project Overload
    2018 Tundra Plat/78Corona/FJ62/three FJ60s
    Tundra is stock 78 Corona 20R decked head and bored out a few thou. 84 FJ60 is stock 85 FJ60 is stock, with Saginaw conversion. 85 FJ60 in progress, SOA, ARB locker back, Aussie locker front, rear stear. 88 FJ62, stock, but with a sick ECU. Soon to be Speeduinoed.
    @Sundog - where did you get that data? I'm trying to find the info on a LT275R70/18 Goodyear Wrangler Adventure Load Range E for tire comparison.
  15. Sep 11, 2023 at 4:44 AM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank)
    Same here, 2.1 mile drive.
  16. Sep 11, 2023 at 4:48 AM
    Dawoofles
    Cheyenne, WY
    I just did 265/70/18 Wildpeaks on Friday. I wanted a larger tire, but didn’t want to deal with new wheels, TPMS, or issues with rubbing at full turn. Don’t need the E rating so they seemed to fit the build for winter time.
  17. Sep 11, 2023 at 6:05 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I don't recall. So long ago.
