Let’s see pics stock height Pro with 295/70r18
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jordanpop1, Sep 11, 2018.
  1. Jan 8, 2021 at 5:49 PM
    #331
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    Yours is a great looking truck
    Patch999[QUOTED] likes this.
  2. Jan 8, 2021 at 6:01 PM
    #332
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Thanks
  3. Jan 16, 2021 at 10:37 PM
    #333
    DadduMan
    DadduMan New Member
    2021 Black Tundra TRD Pro
    295/70R18 Nitto Terra Grappler G2 with 1.25inch Spidertrax spacers. Having slight rubbing at full lock but nothing a heat gun and some elbow grease won’t fix. :thumbsup:
  4. Jan 17, 2021 at 11:31 AM
    #334
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Where does it rub?
  5. Jan 17, 2021 at 2:40 PM
    #335
    DadduMan
    DadduMan New Member
    On mudflap and on front plastic. Red lines in this pic. But already took care of it this morning. I flattened the mudflaps with a heat gun and pulled the front plastic forward and also trimmed a little off of it. Not rubbing at all now.
    danno266[QUOTED] likes this.
  6. Jan 18, 2021 at 9:14 AM
    #336
    danno266
    danno266 n00b
    Did you run the tires/wheels without the spidertrax at all, or installed at the same time?
  7. Jan 18, 2021 at 9:33 AM
    #337
    DadduMan
    DadduMan New Member
    I had the spacers on before swapping out the tires so no. Didn’t run without spacers. Just seen on here several mentions of no rubbing on mudflaps and the common thing they had no spacers. But rubbing on front sway bar and/or UCA without spacers. I don’t have that problem as I have two fingers wide space from the UCA, Which is roughly 1.25inch and I attribute that to the spacers.
  8. Jan 31, 2021 at 6:34 PM
    #338
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not being super familiar with the 5100’s - what height does that add?
  9. Jan 31, 2021 at 6:50 PM
    #339
    Blueknights75
    Ron
    Clayton, NC
    You will rub the skid plate unless you have a PRO skid plate which is narrower. You will also rub the front little mud flap things in front of the tire.
  10. Feb 1, 2021 at 5:36 AM
    #340
    TelemarkTumalo
    Mark
    Bend, OR
    I did the same on my '18 TRD. I pulled the skid plate and used a grinder on the rear corners. Basically rounded off about an inch at the corner and tapered forward and medially. Primer + paint and reinstall. About 2 hours.
  11. Feb 1, 2021 at 12:34 PM
    #341
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Did you need any mods to go with the 35x12.5???
    I was looking at 33x12.5 with 1.25 spidertrax spacers
  12. Feb 1, 2021 at 12:54 PM
    #342
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    You know you gotta paint the front tow hooks red now to match all the other stuff? Nice Truck!
    DadduMan[QUOTED] likes this.
  13. Feb 13, 2021 at 8:02 PM
    #343
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    For those of you with the Wildpeaks, what psi are you running?
  14. Feb 13, 2021 at 9:56 PM
    #344
    RainMan_PNW
    Casey
    Clark County, WA
    I’m about 38 psi cold.
    Minarets[QUOTED] and YotaBro like this.
  15. Feb 13, 2021 at 10:10 PM
    #345
    TelemarkTumalo
    Mark
    Bend, OR
    36 x 4
    Minarets likes this.
  16. Feb 13, 2021 at 10:20 PM
    #346
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    What do you run when you're on trails?
  17. Feb 13, 2021 at 10:23 PM
    #347
    RainMan_PNW
    Casey
    Clark County, WA
    Haven’t gotten out on any yet... :(
  18. Feb 14, 2021 at 1:41 AM
    #348
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    So I got all excited a few days ago because I got my friendly DT to order and install some Cooper 295/70 and patiently waited as they went through the install process. Tried backing out and had some serious rubbing issues to the point reversing out of the bay was next to impossible. Rubbing was mainly on the driver's side at 3/4 lock. Playing around with the steering while sitting there, there was some but nowhere near as much rub on the passenger side. I ended up reinstalling my OEMs.
    Any thoughts or pearls of wisdom here?
  19. Feb 14, 2021 at 4:58 AM
    #349
    biebs96
    PA
    It was probably just hitting the mudflaps. When it does it sounds like you’re ripping off a bumper.
  20. Feb 14, 2021 at 5:13 AM
    #350
    TheBubbaDude
    2020 Tundra TRD Pro
    That's basically the sound it made. I don't have time to do any bending or cutting right now either. What was puzzling to both the tech and myself was the significant difference in rub between the driver and passenger side.
    As a side note, I do have 1.25 spacers on the truck
  21. Feb 14, 2021 at 5:17 AM
    #351
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    "As a side note" lol
  22. Feb 14, 2021 at 5:49 AM
    #352
    biebs96
    PA
    The spacers are the issue.
  23. Feb 14, 2021 at 5:51 AM
    #353
    TheBubbaDude
    2020 Tundra TRD Pro
    That's kind of what I was thinking but wasn't 100% sure. The calculations in my head said differently but I'm no mathematician.
    I had seen a few posts here saying they could (and did) work but I was reading through past posts in this sub and was questioning if there was something different with the tire since NRG seems to work based on size
  24. Feb 14, 2021 at 8:25 PM
    #354
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    I have 295/70 Ridge Grapplers and I removed both mud flaps prior to install. I didn’t rub anywhere on the liners, but I had a slight rub at full lock on the passenger side sway bar. I just installed 1.25 spacers and had to heat/push in the front liners a bit to clear. No rubbing at all now.
    Take the spacers off or take a heat gun and push in those front liners. You can also get the Coachbuilder bumper shims if you don’t want to use a heat gun. Good luck!
  25. Feb 21, 2021 at 1:01 PM
    #355
    Browneye14
    Browneye14 New Member
    Newb here. I have a 2019 TRD PRO and just traded it in for the 2021 TRD PRO. Heated seats and Push to start are a must need. Anyways, is there not a lift for the TRD PRO out there? Wanting to put 37's if possible. TIA.
  26. Feb 21, 2021 at 5:35 PM
    #356
    DadduMan
    DadduMan New Member
    Here you go. This is specifically built for the Pro but you will probably still need to do some trimming and cutting to fit 37s without rubbing.
    https://shop-coachbuilder.myshopify.com/products/coachbuilder-trd-pro-kit-2015
  27. Feb 22, 2021 at 7:17 AM
    #357
    Browneye14
    Appreciate that sir. I've reached out to them. Can't really decide to whether go with the 35's or 37's yet.
  28. Apr 9, 2021 at 1:42 PM
    #358
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Not a Pro but I have 5100s on middle setting and Pro wheels. Can I fit 295/70r18?
    EN2TUNDRA, Figgy and GT87 like this.
  29. Apr 13, 2021 at 12:08 PM
    #359
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    I'm interested as well. I have a stock SR5 TRD offroad and would like to run 295/70's on the factory TRD wheels with 5100's at middle setting.
    Figgy likes this.
  30. Apr 13, 2021 at 12:38 PM
    #360
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    2018 White CM TRD Off Road
    For me, personally, with a 3" level I am running 297/70R18's on stock TRD wheels on a 2018 TRD OR. I have a buddy on a 2" level and he's running the same setup. You can fit 295/70's on your setup. You may just need to remove the front mud flaps (don't really need them IMO) and maybe bend or trim the outer sections of the factory skid plate (on a non-pro)
