Bilstein 5100s...Top or Middle setting?
Discussion in 'Suspension' started by ToyotaTundraMike, Apr 10, 2016.
  1. May 30, 2019 at 8:17 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Middle setting with no lift in the rear was perfect for me on my 2nd gen. Had 285x65x18 KO tires
  2. Jun 19, 2019 at 10:02 AM
    Kevin80
    Kevin80 New Member
    2016 SR5 Crewmax
    This thread is a little old, but not too old so I'll give it a shot... I am looking at doing the same as a lot of people (middle setting in the front and no lift in the rear), but will I put myself into a "front end high" situation when my ~7,000 camper is on the bumper? I will be using a WDH but I don't want the "lean".
    Thanks for the help.
  3. Jun 19, 2019 at 11:30 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I went with the middle setting. At first I thought the installer made a mistake and put it on the high setting, but I double checked and they had it correct. If you are worried that it will make the front end a bit high when you hook up your camper, then I'd go with the low setting.
    Here's mine with the middle setting. The truck is sitting on a slope, so just note the space between the top of the tire and the fender.
  4. Jun 19, 2019 at 11:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would do middle setting for 275/70’s
    For a camper you’re gonna want to do low setting or airbags
  5. Jun 19, 2019 at 11:44 AM
    Kevin80
    Kevin80 New Member
    2016 SR5 Crewmax
    Ok, thanks. I don't have time for the airbags before a few trips so I'll go with the low setting for now (with the possibility of changing and adding airbags down the road.)
    Thanks for the help everyone.
  6. Jun 30, 2019 at 6:35 PM
    Calidude7
    Calidude7 New Member
    I just did mine , middle setting, Im loving it so far .685C3312-F0F7-4CF2-800A-284CCAE124CF.jpg
    clarkritchie, rv740, co2owen and 3 others like this.
  7. Jun 30, 2019 at 7:03 PM
    Middle setting.
  8. Apr 12, 2020 at 7:04 AM
    Pmoore849
    Pmoore849 New Member
    Patrick
    2012 silver sr5 4x2
    Before and after. Middle setting. Can barely tell in photo the difference, but ride quality is much improved and ended up with about 1.5 “ lift in front.
  9. May 6, 2020 at 5:42 AM
    Rubedog88
    Rubedog88 New Member
    2017 Toyota Tundra Double Cab SR5
    I put in some Bilsteins 5100 at top setting a day ago on a 17 DC 2wd. I do think I have a small lean but I think some rear shackles should level me out. Just don’t know if I should put in 1” 2” inch shackles?
  10. Jul 12, 2020 at 11:30 AM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    Here is mine. Middle setting. No lift in rear and one CB shim on Driver side. I’m going to bump it up to top setting and go with the CB shackles in rear. I’m running a +18 offset with OEM tires 20” and I get a bit of rub on mud flap at full turn. That way when I go with a all terrain tire, it should help. I’m also installing smooth fender flares as well. I’ll post pics when complete.
    Jsnake89, Celt and Florida Man 82 like this.
  11. Jul 16, 2020 at 11:16 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    Mine are all they way up and have Rough Country 1” block in the back. Sits level IMO and like it .
  12. Jul 16, 2020 at 11:28 AM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    Alaska
    2020 DC TRD-OR, Cement
    What size tires are you running?
  13. Jul 16, 2020 at 7:48 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    Still on the stock 275/55/20 going to get 285/60/20 later on.
  14. Jul 16, 2020 at 8:06 PM
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    20 sport premium cm black
    I just put on 5100’s all around top setting with 1” block. Looks level but I think I have a little rake which I like. Now my wife says my tires are to small :(
    Swede, Jsnake89, TNTundra16 and 3 others like this.
  15. Jul 16, 2020 at 8:39 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I think it looks great
  16. Jul 16, 2020 at 8:44 PM
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    Thanks. Wanting to put 295’s on though now.
  17. Jul 16, 2020 at 8:45 PM
    Lugnuts2020
    2018 crew max
    Changing the offset makes a huge difference. When I put on the new wheels, it didn’t look as tall compared to the stock wheels.
  18. Jul 16, 2020 at 8:46 PM
    Lugnuts2020
    2018 crew max
    Killer looking truck though! IMO trundles wear black better than any other truck.
    Jsnake89 likes this.
  19. Jul 16, 2020 at 8:49 PM
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    I actually like the +60 offset. I’ve been thinking of putting spacers on to bring the tires out a bit. But I don’t care for to big of an offset. Just personal preference
  20. Jul 16, 2020 at 8:50 PM
    #50
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    Agreed on the black colour.
  21. Jul 16, 2020 at 9:15 PM
    #51
    charbon
    charbon New Member
    eric
    2020 sx
    ABE3807F-3565-40B4-88C8-E3E3D0913777.jpg Bilstein 5100 top setting in the front add Leaf rear + 1.5 and 275/70/18. Duratrac !!
  22. Jul 17, 2020 at 9:02 AM
    #52
    Dr.X
    Dr.X New Member
    Antonio
    2018 Tundra Crewmax TRD Sport 4x4
    Is the rear stock? 5100s also? looks like it sits a bit high
  23. Jul 20, 2020 at 12:51 PM
    #53
    RedOakStyle
    RedOakStyle New Member
    Terry
    Waxahachie, Tx
    2020 Tundra Crewmax TSS Off-road
    2017 TRD Pro Grill w Jomax Customs Radar relocation Bracket Bakflip MX4 Bed Cover Bilstein 5100 on all 4 corners, w/ front Struts @ Top Notch ( sits level)
    Just installed Bilstein 5100 to top notch and left the rear stock. The rear is 1/4 Inch taller now close enough for level for me. These are stock TSS Tire and wheels AFE61E08-9FC2-4412-971D-6BBD7DEEF329.jpg852CF91F-D142-4BEF-A768-5E35287A7D71.jpg
  24. Jul 20, 2020 at 1:02 PM
    #54
    Dr.X
    Dr.X New Member
    Antonio
    Looks awesome man. Idk what it is with the tundras, but when they measure exactly the same f/r, the front always looks to be a little higher
  25. Jul 20, 2020 at 1:03 PM
    #55
    Dr.X
    Dr.X New Member
    Antonio
    What is the stock suspension on the TSS package? Is it the black, yellow, or red shocks?
  26. Jul 20, 2020 at 1:09 PM
    #56
    RedOakStyle
    Terry
    Waxahachie, Tx
    870060F4-16B2-42EA-97AA-D45770D17297.jpg 7D3540F5-F0CF-4758-9F56-B660E91A0519.jpg DA1D6948-3BE9-4DE0-89CD-2F7CB7B671D5.jpg Stock was black shock here’s a side by side pic of stock shock vs Bilstein 5100 I reused my stock coil spring rides better than stock! No Regrets this 4 piece set was $379
  27. Nov 18, 2020 at 7:08 PM
    #57
    nshipp
    nshipp New Member
    2017 Metallic Gray Tundra TRD Off Road
    33" KO2s, Tint, ESP Seat Storage
    I setup my front on the middle setting and I'm perfectly level. I was shocked however that I needed to trim the corners of my front skid plate from hitting my tires when my wheel was fully turned left or right. I only took off 1/4 of an inch. I thought by adding a lift up front it would give me even more clearance but not the case. I'm running 275/75/18 KO2s on the stock TRD Pro wheels. Everything is now fine and working and the truck looks great. I'm interested this spring on how it levels out towing my 28' travel trailer. We shall see.
  28. Feb 21, 2021 at 10:45 AM
    #58
    Florida Man 82
    Florida Man 82 New Member
    2021 TRD Off Road 4x4
    Looks really good. I'm thinking of doing exactly the same. I have about a 1/3" driver side lean now (stock). Anyhow, do you still like it? More pics, including of driver's side? Thanks
  29. Feb 21, 2021 at 10:57 AM
    #59
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Middle setting with .75” shackles on the rear.
    tonynw318, Swede, toyofan87 and 2 others like this.
  30. Mar 13, 2021 at 9:05 AM
    #60
    Lugnuts2020
    2018 crew max
    yeah I love it. I was able to run a 285/55/20 no rub what’s so ever and a 20” with +18 offset. It’s a very appropriate being a family man IMO and drives nice. All though, I’m still wanting a 3” lift and thinking less off set. More like +25 so the tires are flush with fender. They stick out like an inch now and throw crap all up my doors.
    I have fender flares I bought and had painted but they stick out further than the tire and it looks disproportionate. So I took them off. I might sell them. Undecided right now
