Block Heater
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Oct 23, 2019.
  1. Nov 24, 2019 at 6:25 AM
    scottb2240
    scottb2240 New Member
    Scott
    2014 Tundra Platinum Silver
    TRD Exhaust, Swaybar, BBK
    Can anyone confirm the power consumption of the OEM block heater? I read somewhere that it's 1000w but then the Zerostart aftermarket one is only 400w. I'm curious to know so I can do a quick calculation. If it is 1000w, at $.15 a kwh, and 3 hours of heating before use, the OEM heater would be $.45 a day. For warm start ups when its really cold outside, that's a no brainer for me.
  2. Nov 24, 2019 at 11:12 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't really imagine it being greater than 400W.
    scottb2240 likes this.
  3. Nov 24, 2019 at 12:25 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Worst case scenario. Put a timer on your power from house and have it set to come on for a couple hours before driving to work in morning. So if you regularly get into the car at 630, have the block heater power come on at 330. Or if you get a fancy enough timer, have it set to 15min/hr.
    It doesn't need 24/7 power for the block heater. Most outdoor parking stalls for workers only run 10-20min per hour.
  4. Nov 24, 2019 at 12:51 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The Toyota cartridge block heaters I’ve seen are 400W as well. My Tundra already had one when I got it, but by the speed it warms up on the block heater I’m confident that it’s not 1000W.
    scottb2240[QUOTED] likes this.
  5. Feb 29, 2020 at 6:08 PM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    Alaska
    2020 DC TRD-OR, Cement
    Can anyone confirm if the OEM PU140-00913-2 block heater works with a 5.7L 2020? All I've seen confirmed thus far is that it's for 2014-2019 but I don't know why it wouldn't work for 2020 (same ancient engine).
    Just purchased my 2020 yesterday and had trouble starting her this morning when it was -5°F outside. I had one on my Taco but wanted to install it myself. The dealer here in Alaska wants to charge $260!
  6. Feb 29, 2020 at 6:14 PM
    timsp8
    NY
    It should. Crawl under your trunk and look for the hole. I think it’s a somewhat standard size where even aftermarket ones fit. If you have the hole, you should be good. I tested mine out last weekend and it was about 180* on the metal next to the heater. Not sure what all it heats though.
    AlaskanAssassin likes this.
  7. Feb 29, 2020 at 6:41 PM
    HailstorminMT
    HailstorminMT New Member
    Hailey
    Montana
    '14 Tundra and '04 4runner v8
    lift and lights
    Last winter we had about a month of -20f mornings and a lot of people's vehicles wouldn't start and they had to uber to work haha. I agree with ^^ it's usually the battery that will keep a gas engine from starting in the cold.
    My truck definitely cried in pain a few times and sometimes had to try twice before it would turn over.
    I had a remote start installed by the dealership after that winter and I would highly recommend.
    AlaskanAssassin and Luckydog like this.
  8. Feb 29, 2020 at 7:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The part number that I have for my '11 is PU140 00905. It's genuine Toyota, but I think I bought it on eBay; and it might actually be a Canadian part number. ¯\(°_o)/¯
  9. Mar 1, 2020 at 10:10 PM
    AlaskanAssassin
    Alaska
    I definitely plan to get one as it gets to -30°F regularly where I live. I had one in my 2018 Tacoma but was hoping to save nearly $200 installing it myself. Just trying to confirm the correct 2020 part number.
  10. Aug 9, 2020 at 5:14 PM
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    Remote start bypasses a lot of electronics... Maybe not needing to run those gave you enough power to crank?
    Half track and HulkSmurf14 like this.
  11. Feb 19, 2021 at 3:37 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    I watched a Canadian youtube video about heaters and they said 15-30 watts pure liter of oil for these types of heaters. The 5.7L uses 7.5L or 7.9qts of oil so that translates to around 170w of power for a heater. Interestingly the video also said don't use more watts than required because it can damage the oil? 400w of power seems like quite a lot for a block heater?
  12. Feb 19, 2021 at 3:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The heater that is used is a block heater, not an oil pan heater. Maybe link to the video so we can have a gander at it and maybe make some clarifications.
    Black Wolf likes this.
  13. Feb 19, 2021 at 3:41 PM
    Aurora CO
    This^^^^^^
    Wynnded[QUOTED] likes this.
  14. Feb 19, 2021 at 3:44 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Ok so yes he was talking about Alaska heat pads, not block heaters
    Black Wolf and Wynnded[QUOTED] like this.
  15. Feb 19, 2021 at 3:46 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are those what they throw on the floors of their igloos for sleeping on top of? ;)
  16. Feb 19, 2021 at 3:48 PM
    Aurora CO
    Yep, the heat pads. When I was up in Anchorage the Yota dealer would install the heat pad for $150. That was in 2012.
  17. Feb 19, 2021 at 3:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What do these look like, a diaper for the oil pan? :p
  18. Feb 19, 2021 at 3:55 PM
    Aurora CO
    I think they used some sort of adhesive. It was flat and attached to the bottom of the oil pan. I never needed one on my 09 Taco even tho it got cold as frack that winter.
  19. Sep 4, 2023 at 2:14 PM
    All Talk
    All Talk New Member
    2015 Toyota Tundra 1794 Edition
    Lift kit (that is horrible and will be changed), Wheel & Tire combination (that looks nice, but is not practical), Latter rack (that will be the foundation of camping system at some point)
    I recently (September 3rd, 2023) installed a block-heater, which is not for the faint of heart. I took a load of pictures, but it was after I had already installed the cartridge and ran the wire.
    I created an album of the pictures I took, with descriptions and wire routing as well. I hope it helps someone, because I had to dig this out of my @$$.
    WFD473 likes this.
