Choice between the REadyLift plus2, coachbuilder, or Westcott Designs?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NLTRDPro, Feb 7, 2020.
  1. Jun 13, 2020 at 9:47 AM
    ArmygreenPRO
    ArmygreenPRO New Member
    2020 Toyota Tundra TRD Pro
  2. Jun 13, 2020 at 10:02 AM
    jlewis44
    jlewis44 New Member
    Josh
    Huntington Beach, CA
    2017 TRD Pro - White
    Westcott TRD Pro Lift | SCS SR8 | BFG KO2 35x12.5r18 | Pioneer DMH-WT7600NEX & Tech 12 Volts - Hertz & JL 10w0's | BAKFlip MX4 | Line X Platinum | NFab steps | HR Interior LEDs
    Same here...rides exactly the same after the Westcott install...
    trd.james likes this.
  3. Jun 17, 2020 at 6:17 PM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    ReadyLift Pro +2 with 305/70r18 CoopersE9F6F334-7FC2-4077-9B76-17D9E842159B.jpg
  4. Jun 17, 2020 at 6:46 PM
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    Truck looks great @MaxYota Love the tires
  5. Jun 18, 2020 at 9:38 AM
    MaxYota
    Murf
    MS Gulfcoast
    Thanks. Can't beat the look of raised white letters.
  6. Jun 18, 2020 at 9:41 AM
    booyaa
    booyaa New Member
    Readylift +4 (for Pro) - rear block delete - + OME leaf pack CB+2
  7. Jul 24, 2020 at 2:10 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Just ordered the Westcott front only kit for my 2020 that I'm ordering this week. Unsure of what to do for the rear. I was told by Jeff Westcott that the Icon AAL expansion kit would work well, but then read bad reviews. What about the Toytec AAl or a CB shackle? Keeping stock bumper but I have a Rigd Supply mega fit waiting in the garage and going with 285/75/18 Toyo MTs with some recovery gear in the bed under a lo pro tonneau. Any suggestions? I have about 40 days before the truck arrives and I'd like to have everything ready when it gets here.
  8. Jul 25, 2020 at 5:35 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    Ordered the Westcott today. Looking forward to it.
  9. Jul 26, 2020 at 7:27 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m debating this lift kit in the future. Any pictures of the front bracket/coil overs for reference? And the rear with the shock extensions? I’m with you on the “no block”. New pack and shackles is the way to go.
  10. Aug 19, 2020 at 5:00 PM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
  11. Aug 19, 2020 at 5:38 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    @BurgEER I installed mine last week. Very happy with it. Install wasn't too bad. The video online isn't 100% accurate for a Tundra. Called Jeff Westcott at least 5 times during the install with questions. He always answered and always had the info I needed.
    Looking forward to wearing out my tires so I can go to 35/12.50's.
    Makes the truck sit perfect and exactly level +/- 1/8".
    Truck drives the same. Had to do an alignment after of course. Camber and caster were still in the green range, toe was the only thing affected.
    Have not gotten any good pics yet.
  12. Aug 22, 2020 at 6:38 PM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
    my 295/70 R18 are almost worn out and looking to go to 35x12.5. I think this westcott kit will be the quickest way to get there. I don’t want to screw around with the pro suspension much either as I enjoy it as it is. Thanks for the pic!
  13. Aug 22, 2020 at 7:35 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Yeah man. I have 0.75" between my UCA and the tire. With a 35/12.50 I will have 0.10" - a little close for my comfort. I may end up with 305/70 as well to get the height but only 12" wife versus 12.5". Too bad I only have 9800 miles on my 285's - I'm ready now!!
  14. Aug 23, 2020 at 7:51 AM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
    I’ve already ordered the Bora spacers so I won’t have to worry about any rubbing on the UCA.
    I think I’m also set on ordering at least the westcott front lift. Just need to decide if I want to go with CB shackles or the westcott block in the rear. Leaning towards the shackles as I had a rear block on my 2011 and it did chatter some in the rear.
  15. Aug 23, 2020 at 7:59 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    I have no noise from the rear
  16. Aug 23, 2020 at 8:41 AM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
    I should clarify, I never heard any chatter noise, but the rear end would skip around over speed bumps/expansion joints. Poor choice of words...
    Your rear block feels solid?
  17. Aug 23, 2020 at 11:00 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Yes sir it does. Feels just like it did before I installed it. I have about 1300 miles on it now
    BurgEER likes this.
  18. Aug 23, 2020 at 12:43 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is normal tundra poor ride. Blocks can make it worse. Consider shackle upgrade, it REALLY helps on expansion joints
    kingpin3919 and BurgEER[QUOTED] like this.
  19. Aug 23, 2020 at 4:51 PM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
    No kidding. I think I’ve made up my mind and will go westcott in the front and CB + 2 shackle in the back
  20. Oct 22, 2020 at 9:58 AM
    #50
    woofhauler
    woofhauler New Member
    Pacifica, CA
    I have a brand new readylift +2 not installed, going to sell it cheap to offload it. I want to lift but realized my big dog (mastiff mix) won't be able to jump in the back as he's getting older.
    If a time comes when I can lift, I'd go the Westscott route for the front. I did a similar lift on my 2015 Pro 4Runner and much prefer the raised perch collar over a top spacer. It overcomes the fact that Toyota makes these normally adjustable shocks unadjustable.
    I can't post for sale here due to my post count, so I'll guess I'll do local CL.
  21. Nov 18, 2020 at 3:40 PM
    #51
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Can you expand on that? Why do you prefer a preload spacer over a top spacer?
  22. Nov 18, 2020 at 8:11 PM
    #52
    woofhauler
    Pacifica, CA
    Since the Pros come with awesome shocks, the collar lift seems like the more natural way to adjust right height. Toyota neuters adjustability on the Fox and Bilsteins. If they were like their aftermarket counterparts ride height would be adjusted by raising the collar. Westcott's solution overcomes this.
    I recently put 285/75/R18 on and the fit is perfect without any lift, so I'm probably not going to lift at all. 2 additional inches is going to be too much for one of my dogs. That was something I should have thought about before I pulled the trigger.
    Anyone wants a readylift +2 brand new in box at a steal let me know.
    AggiePhil likes this.
  23. Nov 23, 2020 at 8:51 PM
    #53
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    For what it’s worth..... ReadyLift PROPLUS2. 295/70R18 Nitto Ridge Grapplers on Black Rhino 18x9.5 +12 offset.
  24. Nov 25, 2020 at 7:04 PM
    #54
    Canuckian
    Canuckian New Member
    Love my Westcott system. Easy, and didn't change any geometry so no changes to vehicle registration here in BC
  25. Nov 29, 2020 at 2:50 AM
    #55
    Fern
    Fern New Member
    2017 Cement TRD Pro
    Enjoying the readylift?
  26. Nov 29, 2020 at 3:20 AM
    #56
    gosolo
    Ray
    NW Oregon
    We had to get a ramp for our Katie...
    5ADF75DC-AAB4-4085-ABE0-0B831373FF1E.jpg It telescopes 3 sections on tracks. She has since, died. Still have the ramp
    woofhauler[QUOTED] and GarTX526 like this.
  27. Nov 29, 2020 at 4:03 PM
    #57
    GarTX526
    GarTX526 New Member
    Many pending.....
    No complaints here on the Readylift. No big off-roading here so it works for me. Aesthetically, I think I would have gone with the +4 if I did it again. I just like the stance of a bit more lift. Beyond that, it’s all good.
    Fern[QUOTED] likes this.
  28. Nov 29, 2020 at 4:05 PM
    #58
    GarTX526
    GarTX526 New Member
    Many pending.....
    Oh man....
    I had not seen the end of your message on your pup. Sorry to hear that.
    Prayers for Katie.
    kingpin3919 and gosolo[QUOTED] like this.
  29. Feb 13, 2021 at 10:46 AM
    #59
    Bigslick43
    Bigslick43 New Member
    Napa, CA
    2019 Super White TRD PRO
    SDHQ Sliders Line-X Bed Liner All Weather Floor Matts Westcott Designs Preload Collars Lift Kit Method MR312 18x9 +18 OS Toyo Open Country RT 35”x12.5”x18”
    I just ordered my Westcott Designs preload collar kit for my 2019 Pro. I want to run Method MR312 18x9 w/+18 OS with Toyo RT’s 35x12.5x18 tires. Do you think I will end up rubbing or need a BMC?
  30. Apr 1, 2021 at 9:07 PM
    #60
    Zizyang
    Zizyang New Member
    2020 tundra pro army green
    Does it effect towing or off roading
