Dash rattle
Discussion in '1st Gen Tundras (2000-2006)' started by kidked888, Feb 6, 2021.
  1. Feb 6, 2021 at 5:16 PM
    kidked888
    kidked888 [OP] New Member
    Kansas
    2004 Tundra Double Cab 2WD
    Only comes intermittently when driving. Sounds like it’s either coming from the glove box or just underneath. Hard to tell exactly where. Banging on the dash hasn’t helped any. Sounds like something is loose but only makes the rattling noise on an on consistent basis. Anyone else had this problem and fixed it?
    2004 DC 2WD
  2. Feb 6, 2021 at 5:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A lot of us put backer rod between the dash, and the windshield for tension.
    Link
    You may need to play with the sizes of the backer rod/closed cell foam. I know when I had my OEM windshield I used ½. I had my windshield replaced and used ⅜.
    There are a lot of weird noises that come from the dash. I think if I had a do-over I'd try something like this.
    Link.
  3. Feb 6, 2021 at 5:25 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Remove your Glove Box and start feeling around jiggling stuff in there.
  4. Feb 6, 2021 at 5:25 PM
    kidked888
    Kansas
    Exactly what I am thinking I’m gonna have to do, trying to find instructions to remove glovebox now.
  5. Feb 6, 2021 at 5:28 PM
    Fred
    Hand Protectors
    Remove two bottom screws. Drop Box gentle down and squeeze the sides to wedge out. Bottom bracket has two nubs that lock in place so watch those for tricks. Do not over tighten screws when putting back or you’ll strip plastique.
    kidked888[QUOTED][OP] likes this.
  6. Feb 7, 2021 at 7:47 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    The change in my ashtray rattles sometimes, I just give it a jiggle and it settles down. That's probably not helpful.
    FirstGenVol, Jack McCarthy and abcinv like this.
  7. Feb 7, 2021 at 12:39 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Make sure it's not an ice scraper in the door pocket rattling at seemingly random times. DAMHIK. :)
  8. Feb 7, 2021 at 12:56 PM
    kidked888
    Kansas
    That was the rattling noise from last week, but got that one already fixed!
  9. Feb 7, 2021 at 1:31 PM
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Actually if you don’t push the ashtray completely in it will rattle around and make you think it’s a dash rattle. Even if it’s out 1/4” it can do that on mine but my shocks are completely gone so maybe that just exacerbates it now that I think about it.
  10. Feb 7, 2021 at 1:35 PM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    Had this on my wife’s 06. I finally ran it down removing the head unit and found a loose screw that attached the dash itself. Wish I had photos to show you. Took me two months to track down.
  11. Feb 7, 2021 at 4:25 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    My passenger airbags has rattled like crazy since the recall service.
  12. Feb 7, 2021 at 4:41 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I had a dash rattle off and on for years. The backer rod fix mentioned above worked well but only for a while. It would eventually come back when the rod compressed. Mine was always worse when weather was cold. I narrowed the location down while having passenger push down on different spots on the dash while it was doing it. It was center of dash slightly towards passenger side. I took out the stereo (pretty easy to do) and added sticky foam tape to a few spots back up in the area we pin pointed. Used the thick stuff home depot sells for doors and windows. Hasn't made a sound since.
    Usually pretty easy to fix a rattle, just have to find it first...
  13. Feb 7, 2021 at 10:38 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Mine did that too after I got it back from the stealership. I just banged on the passenger side dash and it went away.
