Tundra grille - how to get what you want
Discussion in 'Toyota of Cool Springs Parts' started by Roman, May 30, 2018.
  1. Aug 9, 2020 at 4:01 PM
    #121
    Yota82
    Yota82 New Member
    18 Black Tundra SR5 TRD
    3/2 lift
    Hello I have a 2018 SR5 218 black I want to keep the insert I have the bulge in 218 in cart and the trd pro in 218 black will this work and is this the cheapest route ? Thank u @Roman
  2. Sep 14, 2020 at 3:04 PM
    #122
    snake
    snake New Member
    Hi Roman
    I just bought a 2020 Sequoia TRD Pro and I am very curious if a 2020 Tundra TRD Pro hood bulge and even the hood will fit my new Sequoia?
  3. Sep 22, 2020 at 9:12 AM
    #123
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It won't be a straight swap over. You'd basically have to change everything from the back of the hood forward to do that kind of swap (hood, fenders, bumper, grille, etc.)
  4. Sep 23, 2020 at 2:14 PM
    #124
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Hello @Roman ,
    I have a 2020 limited that has the Toyota sensor in the grill emblem but grill, surround and bulge are all chrome and I need them all to be black.
    I need all three items in black but the main thing is the grill has to be the type with the Toyota emblem in the center because I ordered a DeMello Baja hoop bumper so the sensor will only work in its factory location.
  5. Sep 24, 2020 at 8:09 AM
    #125
    Roman
    Roman
    Franklin, TN
    Sure, I have all of the grille options listed here:
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    Pay close attention to the front emblem thread I have posted. You will need to determine which emblem you have before placing an order for a new grille.
  6. Sep 24, 2020 at 8:33 AM
    #126
    TDS65
    TDS65 New Member
    Alabama
    2018 Silver Sky Crewmax Limited
    @Roman, if I change from 2018 limited grill to a platinum grill do I use the Toyota emblem from my current grill
    On the new platinum grill.
    Thanks
  7. Sep 24, 2020 at 8:36 AM
    #127
    Roman
    Roman
    Franklin, TN
  8. Sep 24, 2020 at 9:33 AM
    #128
    TDS65
    TDS65 New Member
    Alabama
    @Roman, tss sensor will work with the new platinum grill?
    Thanks
  9. Sep 24, 2020 at 9:38 AM
    #129
    Roman
    Roman
    Franklin, TN
    Yes, the sensor will unbolt from the back of your grille and bolt to the new one.
  10. Dec 23, 2020 at 6:25 AM
    #130
    56539
    56539 New Member
    Roman - Thanks for taking the time to put so much info together. When I follow the links to the cool springs toyota parts online store, there is a grey banner at the top of the page that says the store is temporarily closed? Are you all not accepting online orders right now?
    jmdaniel likes this.
  11. Feb 4, 2021 at 6:25 AM
    #131
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I have this question as well. When I click the link for any of the grills, I get a message that the site is not secure. On Safari:
  12. Feb 4, 2021 at 6:30 AM
    #132
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I want to purchase and install this grille on my 2007, what parts do I need?
  13. May 19, 2021 at 3:52 PM
    #133
    Skolberg
    Skolberg New Member
    Chase
    2014 TRD PLATINUM
    Hey @Roman, resurrecting an old thread with a new question. I have a 2014 Platinum. I am looking to change my grille insert only to a black honeycomb and keep my existing bulge and surround. Can I buy an insert by itself and swap? Or do I need a full grille assembly and then swap the inserts myself? I have been reading about an emblem needed as well but am confused as I would assume the insert would come with a new emblem?
  14. Oct 26, 2021 at 5:10 AM
    #134
    deepsea5
    deepsea5 New Member
    2016 White Tundra 4X4 XSP-X Package
    2016 white Tundra XSP-X on the way, courtesy of carmax. From what I understand, the XSP-X has a billet grille. Love the black grille, but not a fan of the chrome surround and hood bulge. Will be looking to change out the chrome for white. Will be interesting to see how Toyota mounted the billet grille to the surround.
  15. Dec 20, 2022 at 12:49 PM
    #135
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    So say I have a 2021 sr5 tundra cement with chrome hood bulge and chrome surround. I want to keep the grille insert, but I want to have the hood bulge and the grille surround cement color. Technically I can just order the cement hood bulge, order a 2017 trd pro grille that comes with the cement grille surround. Just swap the grille inserts correct? Basically what I’m asking is do the 2018+ grille inserts fit into the 2017 grille surround?
  16. Jan 3, 2023 at 11:30 PM
    #136
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    Yes, it fits directly.
  17. Jan 4, 2023 at 5:14 AM
    #137
    Bergy24
    Bergy24 New Member
    This is exactly what I did on my limited with no issues. Take your time swapping the inserts and use heat.
    Here are the part numbers I used.
    761800C030B2 Hood Molding CEMENT GRAY
    531000C260B2 Grille CEMENT GRAY
    iHacker likes this.
