2021 engine whine /howl
Discussion in '2.5 Gen Tundras (2014-2021)' started by General Motors, Jan 27, 2021.
  1. Jan 27, 2021 at 4:16 PM
    General Motors
    General Motors [OP] New Member
    2021 Tundra SR5 SX
    2021 Tundra SR5 SX
    Does anyone else experience high pitch engine whine or howl at approx 60 mph cruising along
    This seem to be the sweet spot and will it dissipates when you take foot off gas or go past 60-65 mph . It’s pretty distracting and drowns out the radio
    Thanks
  2. Jan 27, 2021 at 4:36 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Nothing like that on my ‘20...
  3. Jan 27, 2021 at 4:42 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Not on my 19 either.
  4. Jan 27, 2021 at 5:27 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Only problem I have with my truck is for some reason the speedometer keeps creeping up and the fuel guage keeps creeping down. Might need to see if moving the seat back will help.
  5. Jan 27, 2021 at 5:50 PM
    General Motors
    2021 Tundra SR5 SX
    Ok item for dealer to check out
  6. Jan 27, 2021 at 5:51 PM
    Bronzeback
    Bronzeback New Member
    Mine whines at 2k RM throughout most gears when cold
    Hoff and Airn890 like this.
  7. Jan 27, 2021 at 6:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s the screen in the throttle body gasket causing a throttle-dependant whistle. A Sequoia gasket without the screen fits and cures the noise.
  8. Jan 27, 2021 at 7:01 PM
    Bronzeback
    not a whistle, mines a whine. Sounds like a supercharger. Lots of guys have it.
  9. Jan 27, 2021 at 7:12 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
  10. Jan 27, 2021 at 7:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If it changes / comes/ goes with throttle / load rather than RPM, and it’s coming from up front it’s the screen. Or you can pick fly poop out of the pepper. :notsure:
    Mine does it, although I can’t say I’ve noticed in the last two years. One day I’ll get to it. LOL
    JimboSlice413 likes this.
  11. Jan 27, 2021 at 7:16 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    It is like a dog whistle. It almost made me trade my truck in when it was still fairly new. My wife couldn't hear it at all. A little internet searching led me to that little screen. I took a pair of dikes to it and never heard it again
    Terndrerrr and landphil[QUOTED] like this.
  12. Jan 28, 2021 at 5:59 AM
    Bronzeback
    I took my screen out about 6 months ago and replaced it with the sequoia gasket. Mine is a bearing or a pulley or maybe air injector pump. I'll have to get it looked at next service I'm sick of hearing it.
  13. Jan 28, 2021 at 6:19 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    It’s definitely the screen. Switched mine out less than a month after I bought it. Do yourself a favor and just buy the oem one for the sequoia instead of cutting it out. It’s like $10 maybe. Coming up on a year of ownership now and honestly forget that I did this until someone brings up the whistle topic
    Rocko9999 likes this.
  14. Jan 28, 2021 at 6:41 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Did anyone figure out the logic behind the screen being there in the first place? Is it just in case the air filter fails or something, to prevent filter media shreds from entering the engine? And why isn't it on the Sequoia?
  15. Jan 28, 2021 at 7:19 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I have no clue what original thinking was for the screen, but upstream screens are often used in air ducts to generate turbulence that maintains more uniform distribution of air flow across the duct downstream. It's doubtful, IMO, that the screen is there to prevent FOD (filter debris into throttle body).
    I also can't explain why the screen would be desirable in the Tundra intake, and not in the Sequoia, unless Sequoia development engineers heard the whine and thought it unacceptable for a high-end family SUV. Maybe they decided to accept the penalty of not having whatever the screen is providing, in favor of reduced noise level in the cabin.
  16. Jan 28, 2021 at 7:41 AM
    2mchfun
    It might be that each manufacturing location has a different parts supplier. Sometimes one supplier cannot fill all the demand. Plus people do make mistakes, so each may have been provided a different drawing or set of manufacturing specs leading to each one making a slightly different design. QA may have decided well we already have tens of thousands made out of spec, let’s approach engineering. Then they could have said hmm maybe we can get a discount and still use them with no noticeable or negative impact. Resulting in some with, some without. Btw, IMO the only thing branded Toyota that I would consider high end is the Landcruiser.
  17. Jan 30, 2021 at 5:11 AM
    General Motors
    2021 Tundra SR5 SX
    Thank for info just ordered replacement
    Clemsonman14 likes this.
  18. Jan 30, 2021 at 5:29 AM
    FUSE86
    FUSE86 New Member
    2020 SR5 TRD 4x4 DCLB
    +1 same experience & remedy
  19. Jan 30, 2021 at 5:30 AM
    FUSE86
    FUSE86 New Member
    Was just about to comment that our 21' sequioa doesn't have this whistle. This makes sense, good to know.
  20. Feb 17, 2021 at 2:31 PM
    General Motors
    2021 Tundra SR5 SX
    Removed throttle body screen gasket and replaced with Sequioa gasket . Noise is all gone !!!!
    Henry1jg, Rocko9999 and Clemsonman14 like this.
  21. Feb 17, 2021 at 2:49 PM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Woah. My truck totally does this. I've read a lot about this issue, but never realized mine does it until you mentioned it's like a dog whistle.
  22. Feb 17, 2021 at 3:07 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    mine does it too. how do you replace it ?
  23. Feb 17, 2021 at 3:14 PM
    Clemsonman14
    2010bigdog[QUOTED] likes this.
  24. Feb 18, 2021 at 5:57 AM
    General Motors
    2021 Tundra SR5 SX
    Tools required a 10 mm socket .Time 15 minutes
    I_Am_Thee_Walrus likes this.
  25. Feb 18, 2021 at 8:55 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    My ‘18 Taco had the A/C whistle and it drove me nuts. Didn’t notice the whistle on the tundra until I was on my way home from buying it a month ago. Instantly felt upset. Read about the fix on here and just remembered to order the new gasket :thumbsup: Excited to get it in. ;)
  26. Feb 18, 2021 at 3:47 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks!
    Clemsonman14[QUOTED] likes this.
  27. Feb 18, 2021 at 4:07 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    I have it on my 2021. Replacing the throttle body gasket did nothing to stop it unfortunately
    Trentimus likes this.
  28. Feb 18, 2021 at 4:09 PM
    Sitting Sideways
    Beaverton, Oregon
    I have a 2021 Tundra and after replacing the screen it still whines. Super annoying. Just like people are describing it comes and goes with throttle input
  29. Feb 18, 2021 at 8:23 PM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    I snipped my screen a year ago - which eliminated 99% of my whistle. Just ordered the sequoia gasket. Not expecting a difference, but I’ll feel better about it being an OEM fix...
  30. Feb 19, 2021 at 6:39 AM
    Sitting Sideways
    Beaverton, Oregon
    Anything fixes to stop the whine?
