Diffs and transfer case fluids
Discussion in '2.5 Gen Tundras (2014-2021)' started by Xyleff, Jan 20, 2021.
  1. Jan 20, 2021 at 2:58 PM
    Xyleff
    Xyleff [OP] New Member
    NorCal
    ‘16040CMSR5
    Looking to get the fluids done on the diffs and transfer case. What works or what’s best out there without having to go through dealership? The more specific, the better. Thanks.
  2. Jan 20, 2021 at 3:16 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I bought all Toyota fluids and did it myself. Got fluids off Amazon. Transfer case fluid was expensive. The rest was nominal.
    Transfer - LF version, 75W
    Diffs - LT version, GL5 75W-85
    Wallygator, Fishhead and Xyleff[OP] like this.
  3. Jan 20, 2021 at 3:19 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Just make sure and use a 75w in the t-case, otherwise pretty mundane.
    HulkSmurf14 and Xyleff[OP] like this.
  4. Jan 20, 2021 at 3:34 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    I used some mobile 1 75W, there are some good discussions about it, I'll try to find it
    Xyleff[OP] likes this.
  5. Jan 20, 2021 at 3:35 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Just about everyone on here are going to push Toyota fluids.
    These are always readily available and cheaper.
    Diffs: Amsoil Severe gear 75w-90
    Transfer Case: Ravenol MTF-3 75W
    coldcanuk, Wallygator, equin and 5 others like this.
  6. Jan 20, 2021 at 3:36 PM
    YotaBro
    Calvin
    FL
    I don't recommend the toyota fluids, they're overpriced. Mobile 1 has done perfectly fine for me
  7. Jan 20, 2021 at 3:47 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I am using Ravenol Fluid, MTF-3 for the Transfer Case and MTF-1 for the Differentials. Using Mobil1 for the engine and Toyota OEM for ATF and Engine Coolant.
  8. Jan 20, 2021 at 3:56 PM
    Doxiedad
    Doxiedad New Member
    James
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    At what mileage should I look into changing the diffs and t/c fluids on my 2020?
  9. Jan 20, 2021 at 4:24 PM
    YotaBro
    Calvin
    FL
    every 30k
    Doxiedad[QUOTED] likes this.
  10. Jan 20, 2021 at 4:24 PM
    YotaBro
    Calvin
    FL
    Also, remember to swap out the washers on all of them, don't reuse the old one
    Wallygator and HulkSmurf14 like this.
  11. Jan 20, 2021 at 5:22 PM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Would you happen to have the part numbers for drain and fill crush washers for the diffs and T-case?
    AggiePhil likes this.
  12. Jan 20, 2021 at 5:35 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    bulldog93 and Joro43 like this.
  13. Jan 20, 2021 at 5:48 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Both of our diffs are open so you don’t need anything special. Just stay within spec.
  14. Jan 20, 2021 at 5:55 PM
    Black
    2014 Tundra Limited CrewMax
    I used the Amsoil severe gear in the differentials.
    I used the Toyota stuff in the T case. Yup it is expensive at $55 a liter but it comes in the cool old school can. I swap these fluids at 50k so only do it every five years or so.
    While I don’t think the Ravenol will do any harm there are a number of reports of less than smooth shifts into 4wd and some folks not engaging without turning the wheel to one side a bit.
  15. Jan 20, 2021 at 6:03 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    I have used the Ravenol for 10 years now, no issues at all.
    Casper3 likes this.
  16. Jan 20, 2021 at 6:09 PM
    crewmaxlmt
    scott
    Great point about the transfer case especially with the recommendation about 10 miles of 4WD per month from Toyota. Maybe a premium in the t-case is worth it.
    As for the diffs, I have only seen stringent specs when limited slip mechanics are involved.
  17. Jan 20, 2021 at 6:27 PM
    YotaBro
    Calvin
    FL
    Nah, just got the washers straight from Toyota
  18. Jan 20, 2021 at 6:31 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Ravenol works great for me, had it in for about 35k miles now, I use 4wd alot and it shifts smooottthhhh, and the shifts are consistent.
    Casper3 likes this.
  19. Jan 20, 2021 at 6:54 PM
    Black
    I have heard of many folks having no issues. I just know my luck so figure I’ll spend a few bucks more. I only do about 10k a year so it is not a big deal. If I did a bunch more mileage I might give it a go.
    Wallygator likes this.
  20. Jan 21, 2021 at 10:45 AM
    Rocko9999
    Rocko9999 New Member
    Is the dealer the only source for the washers?
  21. Jan 21, 2021 at 11:08 AM
    Black
    Nope
    Rexka Transfer & Differential Service Gasket Kit Fits Toyota Lexus 4Runner Land Cruiser Tundra Tacoma FJ Cruiser Highlander RAV4 Sequoia Sienna 12157- https://www.amazon.com/dp/B07CJHTDVV/ref=cm_sw_r_cp_apip_kNCAHgyss8Cxk
  22. Jan 21, 2021 at 11:13 AM
    YotaBro
    Calvin
    FL
    I'm sure they aren't it was just the fastest option for me. I am iffy when it comes to Amazon.
  23. Jan 21, 2021 at 1:44 PM
    Xyleff
    NorCal
    ‘16040CMSR5
    Thanks y’all
    Rocko9999 likes this.
  24. Jan 23, 2021 at 6:21 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I just wanted to correct my post - lately I have been using the Kirkland Signature Full Synthetic from Costco rather than Mobil1. Normally $25 for two 5-qt jugs now on sale for $21. Good reviews on Bobistheoilguy.com
  25. Jan 23, 2021 at 7:21 AM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    Where did you get that information. I went through 2020 Tundra maintenance schedule and up to 120,000 miles and none of them mentioned that we have to change out difs and transfer case fluids. Toyota onle mentioned inspect the difs and transfer cace fluids. I normally do it every 100,000 miles on my other vehicles but I don't think we need to change them out.
  26. Jan 23, 2021 at 8:07 AM
    YotaBro
    Calvin
    FL
    https://www.tundras.com/threads/tundra-maintenance-guide.315/
    14burrito likes this.
  27. Jan 23, 2021 at 8:08 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    2020 maintenance card....
  28. Jan 28, 2021 at 4:23 PM
    naumanator
    naumanator New Member
    Salt Lake City, Utah
    2017 Silver TRD Off-Road Double Cab
    Is it an issue if we use limited slip diff oil in our open differentials?
  29. Jan 28, 2021 at 5:13 PM
    crewmaxlmt
    scott
    No. Absolutely not. Frankly, it’s a waste of money.
    Buckaroo likes this.
  30. Jan 29, 2021 at 5:27 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    This is for special operating conditions, though. Many people who have Tundras don't tow, haul, or have a car topper, so according to the schedule there is no need to change those fluids in that situation.
    While this may not be all of us, it is something to note.
