  1. Jan 22, 2021 at 6:35 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Noted, and will do. I appreciate the much-needed encouragement. I CAN do it! :D
  2. Jan 22, 2021 at 6:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Buy a top end gasket kit from Toyota. Price is good for what you get. Which is every gasket you’ll need. If you’re buying used heads, have them gone through with a full valve job and do all the valve stem seals (also in the kit) as for head bolts they can be measured to be reused if they’re in spec, but ideally replace. One all together, check valve clearance before putting it all back together and make sure that’s all in spec (you must remove the cams to adjust the valve clearance) check the block for trueness as well, and clean it well with a razor blade and don’t use anything too abrasive, removing the sharp edges on the block and causing them to be chamfered can lead to blown head gaskets later. And finally, use a quality accurate torque wrench.
  3. Jan 22, 2021 at 8:58 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Do you have any idea how lucky we are to have you around?
    oscardog86, Voss, CodyP and 3 others like this.
  4. Jan 22, 2021 at 8:59 PM
    empty_lord
    05 rollover special
    Aww shucks. Little ol me?
    oscardog86, Voss, NUDRAT and 3 others like this.
  5. Jan 22, 2021 at 9:01 PM
    FirstGenVol Brake Czar
    2002 AC
    Yes. You and your sexy voice.
    I shouldn't post after drinking all night...
    oscardog86, NWPirate, Voss and 5 others like this.
  6. Jan 22, 2021 at 9:02 PM
    empty_lord
    05 rollover special
    Hmm.. appreciate the compliment. But I’m afraid I like women
    oscardog86, jImmegart and Darkness like this.
  7. Jan 22, 2021 at 9:15 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I’ll cheers to that bro.
  8. Jan 23, 2021 at 8:04 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    Well it's cold & only colder lies in the forecast. Faced facts & dropped the Tundra off at local mechanic. Have to find out where the magical disappearing coolant is going. Now i wait.
    fun fact - got to the shop & he was working on my Tundra's ugly twin. Work truck vs. Gentleman's truck. the years have been far kinder to mine.
  9. Jan 23, 2021 at 9:29 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    What is this hole in the cylinder block?
    There are two per side, the other dimples don't have holes in them, and this one looks too small to be an expansion plug. It kind of just rusted away.
    oscardog86 likes this.
  10. Jan 23, 2021 at 12:10 PM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Finally replace my crusty positive terminal. The SDHQ kit is pretty stout so that also meant I couldn’t open the clamp any wider to slide further down on my tapered terminal. For some reason it has a higher deck, so I had to loosen the loom clip below to get some more slack out of it. But as I’m thinking about it now, I wonder I I could flip the clamp so that nub isn’t in the way.......
    I’ll do the negative tomorrow maybe
  11. Jan 23, 2021 at 1:57 PM
    2002 AC
    I did a test run with some plywood I inherited from this house we're renting. I overestimated how much room is back there.
    My dogs are just too big to ride back there comfortably. It would be fine for short trips but not for the trip we want to make out west.
    alee891, oscardog86, hammeron and 4 others like this.
  12. Jan 23, 2021 at 2:01 PM
    The SoAz
    None
    Haha look at those cuties!
    I’d even say 1-3 hour max with that setup.
    That is the main reason for the green light on a camper shell for us; the dogs are already super cramped in the rear of the 4runner, one 90lb and one 30lb in a soft crate.
    So I’ll then have to devise some sort of setup when I get the camper, probably gear closest to the cab, and pups at the tailgate; I’d rather not have them roaming all over the place while driving.(my mom’s neighbor recently had a freak TBone accident on her way to the vet, and seriously messed up the dog, like they had to put it down)
    oscardog86, Darkness and des2mtn like this.
  13. Jan 23, 2021 at 2:05 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Removed a fair amount off the edge/rim inside the Air Filter Box outlet. In ‘theory’ the air should flow better over a rounded vs. a squared off port. Took her on a test drive and picked up a couple chicks. :rofl:
    Seriously, after a city/highway mix drive there is something different. I’ll wait a few days and give a final conclusion.
    oscardog86, Darkness, Voss and 2 others like this.
  14. Jan 23, 2021 at 2:07 PM
    2002 AC
    Yep, it's just as dangerous as having a kid roaming around a vehicle. I had a friend who got in a bad wreck. She lived but her kitty in the passenger seat didn't. I haven't come up with a great solution to this. The vets say to put them in a crate but that doesn't work for 8 hour car rides.
    I also cringe when I see people drive around with dogs hanging half way out an open window or let them ride in their lap.
    oscardog86, CodyP, Darkness and 2 others like this.
  15. Jan 23, 2021 at 2:13 PM
    AlbertaBeef
    AlbertaBeef New Member
    Glen
    Airdrie, Alberta, Canada
    2001 Tundra 4x4 Access Cab TRD Off Road
    17" Rims and 265/70R17 tires, 20" Light Bar, Power Stop Brakes, Diff Breather Relocate
    Finally getting around to doing some grinding / rust-repair and cleanup ... Both sides looked like this before we started:
    JaxatfSsOsKRJ9FxgAmlXfYendOLbT0klxsjSmOb_b9d95cfa10063ad501d289bf314d4d9dba226d5b.jpg
    ... My son and I drove her into the shop, and did the passenger-side over the past couple days... Ground it all off, sanded, rust-protection, primer-filler, and paint.
    Here's what the passenger side looks like today :
    ThqCmaE6u_aA6lIpkZQZj1DwHTMg6ohFT0rJfK-z_9de0902a06ea3650260e65b2c4699257112db680.jpg
    Ignore the water spots, etc. I *do* drive this truck, LOL. We'll do the drivers' side next week, weather and shop-space permitting... Really happy with how it turned out considering what incredible amateurs we are!
    MS22, oscardog86, SouthPaw and 9 others like this.
  16. Jan 23, 2021 at 2:35 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Flushed the power steering fluid today. I didn’t even know that was a thing lol. So much to learn/so much fun to be had
  17. Jan 23, 2021 at 2:36 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    We have one of these, works great.
    https://www.chewy.com/barksbar-orig...8tGojoCXBP_EeMlnYc41UP6mCbKgfi2hoCwJkQAvD_BwE
    Darkness likes this.
  18. Jan 23, 2021 at 2:38 PM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    I noticed my engine fan shroud was loose because it was missing two bolts. I recycled some old misc. bolts and tightened everything back up, good to go.
    That's been on my to-do list!
    oscardog86, NUDRAT, hammeron and 3 others like this.
  19. Jan 23, 2021 at 3:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  20. Jan 23, 2021 at 3:48 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    but all those erratic scratches will cause turbulence & whirl the peas. You need to sand it smooth, maybe some bondo, then fiberglass resin.
  21. Jan 23, 2021 at 3:59 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    Outside the box, but if you're mounting a shell - you could have the back window removed for the trip. Shouldn't be too hard to weather tight between cab & shell/bed. Let the dogs have the 'top' of the bed, closest to the cab. A sort of makeshift SUV. Glass shop charge maybe $25 to pull the window, maybe that to $50 to remount the window. Fairly cheap solution. Most cap windows to the cab open, or remove easily, worst case is a slider window.
  22. Jan 23, 2021 at 4:13 PM
    Fred
    Hand Protectors
    Yeah. I didn’t snap a pic of the final job. I Swirled a thin layer of Toy 103 FIPG on the scratches. Smoov’d it right out. Pics make the scratches look worse than they are in person.
    Took a second test drive since the work. Liking it. Lots of low end power. Mid power seems same. High end seems good with the only difference being that she doesn’t drop out of O/D as easy when stepping on the throttle to pass.
    So far no ‘CEL’ with about 24 miles of drive time. Went to plug in the OBD and the phone was dead from no use. She is charging now and I’ll report back with some numbers some time this week.
    MS22, NUDRAT[QUOTED] and Voss like this.
  23. Jan 23, 2021 at 7:47 PM
    Ludogg808
    Ludogg808 New Member
    Luis
    2001 Tundra Sr5
    Weather Tech floor liners, Debadged
    SPC uppers
    Dura bumps up front
    2” ome lift with add a leafs
    Timbren bumps in back
    285/70/17 BFG ko2s
    Scs ray 10s in brushed copper
    Fresh mobile 1 oil change
    And topped her off with premium chevron gas auuuuritee
    If any one near Sacramento is interested I got oem style chrome wheels wrapped in 265/75 16 bfg ko2s. Saw the wheels on eBay brand new for around 1200. 700 takes em w the tires. No rock rash on wheels. About 60% tread
    oscardog86, Voss, recomr and 7 others like this.
  24. Jan 23, 2021 at 8:26 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I know you aren’t like an SCS rep but can I get a good side shot in the sun of those brushed copper? I’ve seen the brushed gold up close but not the copper.
    Ludogg808[QUOTED] likes this.
  25. Jan 23, 2021 at 11:02 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ordered up a shallow sub. I'm feeling inspired and from how hectic work has been lately I could use an outlet. Time to start working on the stereo again.
    lsaami likes this.
  26. Jan 23, 2021 at 11:31 PM
    Ludogg808
    Luis
    2001 Tundra Sr5
    oscardog86, N84434, NUDRAT and 2 others like this.
  27. Jan 24, 2021 at 6:00 AM
    Fred
    Hand Protectors
    Man, I’d snap those Chrome Patricks up from you if I was closer.
  28. Jan 24, 2021 at 9:08 AM
    Ludogg808
    Luis
    2001 Tundra Sr5
    Where u at?
  29. Jan 24, 2021 at 12:00 PM
    Fred
    Hand Protectors
    ‘Far Away’. :rofl:
  30. Jan 24, 2021 at 1:03 PM
    empty_lord
    05 rollover special
    Got the tundra squeezed in and the tractor up to the garage in prep for tomorrow
    [​IMG] [​IMG]
    hammeron, Voss, abcinv and 5 others like this.
