Steering wheel radio controls
Discussion in 'Audio & Video' started by Theyfzman, Feb 1, 2017.
  1. Feb 1, 2017 at 8:01 AM
    Theyfzman
    Theyfzman [OP] New Member
    Pa
    08 TRD
    Hi all does anybody know if you can swap out the non control steering wheel for a control steering wheel, I know they are prewired for the reverse camera and such wasn't sure if they did the same for the radio controls
    thanks
  2. Feb 1, 2017 at 8:56 AM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    They should be. Check with your local parts dept to see if the clock spring is the same. When you add cruise it is, not sure about the steering wheel controls
  3. Feb 2, 2017 at 1:01 PM
    Theyfzman
    Pa
    08 TRD
    Anybody try this ?
  4. Feb 3, 2017 at 2:48 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I just had it done when I did my audio build. Bought an entire wheel with controls and had it tied into my alpine aftermarket hu. I didn't do the work. My 12 volt guru buddy did it. Said it was no big deal. If you Google tundra steering wheel swap or steering wheel control swap there are threads out there about it. I sent the threads to him and he used as a guide.
    ColoradoTJ likes this.
  5. Feb 12, 2017 at 7:44 AM
    Dgoll75
    Dgoll75 New Member
    I looked into this too. You could actually just buy the smaller limited air bag and wheel switches and use the same wheel frame itself. There's two small plastic inserts tha take the place of the audio switches. Swap them for the real ones and smaller air bag and it may save you a few bucks.
  6. Mar 26, 2017 at 12:58 PM
    winemule
    winemule New Member
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    I bought one out of a wrecked 07 limited and installed it in my 07. Had it there since 07 and it has worked great. Just getting ready to sell the 07 double cab and move to my 14 CM Platinum
  7. Mar 26, 2017 at 7:31 PM
    Theyfzman
    Pa
    08 TRD
    Is the wire connections already in the colum ?
  8. Mar 27, 2017 at 4:45 AM
    winemule
    winemule New Member
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
