Common headlight level motor failure?
Discussion in 'Lighting' started by sk8142, Mar 25, 2017.
  1. Mar 25, 2017 at 3:53 PM
    sk8142
    sk8142 [OP] New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    My passenger side headlight level function stopped working recently so I pulled the back cover off to inspect the electric motor. I definitely wasn't expecting to find a completely rusted motor and circuit board on this thing so my question is... is this a common issue? This motor has never been apart (headlights have been retrofitted but he said he doesn't mess with them) so I have no idea why the rubber seal failed and allowed water inside.
  2. Mar 25, 2017 at 4:05 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    First I have heard of it. Maybe the seal wasn't seated properly from the factory?
    ColoradoTJ likes this.
  3. Mar 25, 2017 at 11:30 PM
    LML 3500HD
    I have never heard of this either.
    Throw this one into the bin of things that usually never happen, and you are the 1 in a few hundred thousand.
    MotoTundra likes this.
  4. Mar 26, 2017 at 8:22 AM
    sk8142
    Shawn
    WA
    Guess I'll have to do that. That bin just cost me 150.00 dollars. :(
    Any info on how to remove the old one and install a new one?
  5. Mar 26, 2017 at 10:33 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I believe the guys with Spyder headlights usually remove their OEM motors to put in their Spyder's, @Sean266 any experience?
    I forget who else has them off the top of my head.
    T-Rex266 likes this.
  6. Mar 26, 2017 at 10:49 AM
    RollMGM
    RollMGM New Member
    Counterclockwise to remove it.
    NewImprovedRon and MotoTundra like this.
  7. Mar 26, 2017 at 6:20 PM
    sk8142
    Shawn
    WA
    I'm thinking I'll swap the internals from the replacement motor into the existing motor already attached to my headlights. I don't want to tinker with them too much so I think swapping internals and seal would cause the least amount of disturbance.
  8. Sep 16, 2017 at 6:06 AM
    Skeew
    Skeew New Member
    Charles
    2017 quicksand sr5 tundra
    Mine went bad as well i can not find where to order one with out the whole light tho?
  9. Sep 16, 2017 at 6:15 AM
    LML 3500HD
    Check with some of the vendors on here that are parts slingers at dealerships. I have always had great service getting factory Toyota parts.
    @Roman
    Roman likes this.
  10. Sep 16, 2017 at 8:14 AM
    Yikes! Need to check mine..got me thinking cause says u live in Washington all sea breeze sea salt lots humidity? I live in Houston i have window vents i have my windows cracked n my seat frames at bottom rusting need check my HL motors
