Offset and backspace
Discussion in 'Wheels & Tires' started by T-Rex266, Feb 1, 2014.
  1. Feb 1, 2014 at 7:50 PM
    T-Rex266 [OP] Elon approved Staff Member
    I took this info off of another board, as I figured we could benefit from it here, on Tundras.com.
    Offset and backspace are essentially two different ways of looking at the same thing. They determine the location of the wheel and tire assembly when bolted to the vehicles hub. (how far in - tucked, or how far out they will sit)
    Offset is the measured distance between the hub mounting surface and the wheels center line.
    With X being the determined offset, the hub mounting surface on positive offset wheels is X amount forward from the wheel center line. The hub mounting surface on negative offset wheels is X amount backwards from the wheel center line. The hub mounting surface on 0 offset wheels is the wheel center line. ​
    Backspacing is the measurement from the hub mounting surface to the back edge of the wheel.
    ***Typically speaking, the higher the offset/backspace, the more the wheel will tuck inwards towards the suspension or away from the fender. The lower the offset/backspace, the more the wheel will push out away from the suspension or towards the fender.
    For Example:
    *If the offset on a 9" wide wheel is +12mm, the hub mounting surface will be 12mm forward from the wheels center line. Measuring from the hub mounting surface to the back edge of the wheel, the backspacing is 5.5"
    *If the offset on a 9" wide wheel is -12mm, the hub mounting surface would be 12mm towards the back of the wheel from the wheels center line. Measuring from the hub mounting surface to the back edge of the wheel, the backspacing is 4.5" ​
    Here's how to calculate the backspacing using the rim width and offset:
    First - add 1" to the rim width and then divide by 2 to find the wheels center line (you have to account for the wheel flange which is why you add 1" to the rim width) . Second - convert the offset which is in millimeters into inches. There is 25.4mm in 1 inch so divide the offset by 25.4. Lastly - add the converted offset to the wheels center line if the offset is positive for the correct backspacing. Subtract the converted offset to the wheels center line if the offset is negative for the correct backspacing.
    For Example:
    17x9 +12mm offset
    *9" rim width + 1" = 10"
    *10"/2 = 5" (wheels center line)
    *+12mm offset/25.4 = 0.47" (0.50" rounded up)
    *0.50" + 5" = 5.50" Backspace
    17x9 -12mm offset
    *-12mm offset/25.4 = 0.47" (0.50" rounded up)
    *0.50" - 5" = 4.50" Backspace​
    ***Please note that the wheels center line is the backspacing for 0 offset wheels.
    Redbelle, Natron, aggrex and 8 others like this.
  2. Feb 4, 2014 at 8:40 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    good info. thanks!!!
  3. Apr 22, 2014 at 2:24 PM
    mike.D1Esel
    mike.D1Esel Spaceship Door Gunner
    Michael
    Schofield Barracks, HI
    Sticky this please!
    NewImprovedRon likes this.
  4. Apr 22, 2014 at 2:48 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Jrocker, 4x4_Angel and 040Tundra like this.
  5. Apr 22, 2014 at 6:04 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Done!
  6. Apr 22, 2014 at 6:59 PM
    mike.D1Esel
    Michael
    appreciate it!!!
  7. Sep 2, 2014 at 9:52 AM
    jedi926
    jedi926 New Member
    Hello. Brand new to the site. I am trying to find an all black alloy wheel that I can put on my stock 2013 Tundra DC 4x4. I am looking to do a RL 3/2 I am struggling to find the right wheel with the proper backspace and offset. I believe the tire I am thinking about purchasing is the Nitto 305/70R17. My third Toyota truck and my first attempt at a lift and aftermarket wheels. I definitely do not want anything rubbing against the UCA. Can you guys help me out? Thanks in advance. Jedi.
  8. Jan 20, 2015 at 6:58 PM
    MrTuRDPro
    MrTuRDPro New Member
    2019 Tundra TRD Pro (Voodoo Blue)
    None...yet!
    Seems like this is the place to post this great little resource. If you're interested in seeing how your stock tires match up to other sizes you may be considering for upgrade, this calculator is amazing. It provides a detailed comparison of tire sizes in the following areas:
    Tire specs:
    - Diameter
    - Width
    - Sidewall
    - Circumference
    - Revs/Mile
    Speed Differences at 20 - 90 MPH (in 10 MPH increments)
    Dang, this tool even gives you a "Visualizer" button which allows you to see both tires side by side, across two separate views (straight on, and the side view). It's been a crucial tool for me and I really hope it proves valuable for everyone else. Make sure to click the "Tire Size Comparison" tab in the middle window pane of the page...everything beyond that is very intuitive. Here's the site:
    http://tire-size-conversion.com/tire-size-calculator/
    Enjoy!
    040Tundra likes this.
  9. Jan 22, 2015 at 6:41 PM
    Tundra2010
    Tundra2010 New Member
    2010 black tundra 4.7
    So just to be clear, which will make the wheel stick out further negative or positive?
  10. Jan 22, 2015 at 8:40 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Negative offset sticks the wheel/tire out
  11. Feb 11, 2015 at 2:46 PM
    Mkyle
    Mkyle New Member
    Hey just joined today I have a question I just ordered a set of 18x9 xd hoss wheels with 35" 12.50 toyo mt tires the offset is +30 will this fit I just noticed the uca may be in the way I am also installing a 3" low range off rd leveling kit
  12. Feb 12, 2015 at 3:52 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Mountun Goat likes this.
  13. Feb 12, 2015 at 5:12 PM
    Mkyle
    Mkyle New Member
    Thanks from what that says it should wrk I'll find out in a couple days
  14. Mar 16, 2017 at 6:51 PM
    KCTundra
    KCTundra -Caeleb
    Caeleb
    Kansas City
    2016 Crewmax Platinum
    3/2 Ready Lift, 35" Nitto Trail Grapplers, 20x10 Fuel Assault Wheels (-18 offset / 4.75" backspace), BAM Budget Exhaust
  15. Mar 24, 2017 at 3:59 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    How do we find out what offset we need? I want my tires to stick out about 3 to 4 inches. So before I buy my rims and tires how do we know this info???
  16. Mar 24, 2017 at 6:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Use the calculator on post 4
  17. Mar 24, 2017 at 7:12 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I think that calculator is broke lol page not coming up
  18. Mar 24, 2017 at 7:15 PM
    csuviper
    Broomfield, CO
    Jsena[QUOTED] likes this.
  19. Mar 24, 2017 at 7:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    You want -15 to -44 offset.
  20. Mar 24, 2017 at 8:14 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  21. May 15, 2018 at 12:40 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Jsena likes this.
  22. May 15, 2018 at 2:09 PM
    jberry813
    Lake Tahoe
    Ok?
    I don't own that website, just one of the many results from the google.
    Mountun Goat[QUOTED] and Jsena like this.
  23. May 15, 2018 at 4:52 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  24. Sep 19, 2020 at 6:35 PM
    Motopilot
    Motopilot New Member
    NC/FL
    2005 double cab 4.7 4WD SR5
    Which offset will you get less rubbing? It seems like a negative which puts the tire outward would be less prone to rubbing.
  25. Sep 20, 2020 at 1:08 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Not speaking from personal experience (so take this with a grain of salt), but from what I understand there are different places your tires can rub. For example, a high positive offset on a wider tire could cause rubbing on the LCA at full lock, so generally speaking a less positive (or even negative) offset would help mitigate that. However, you still have to consider the angle of the wheel against the outside fender wall, which could require additional trimming. This video explains the fitment of wheel spacers, but it applies to higher negative offset wheels as well:
    https://youtu.be/GVqVQj49KDc
    From what I’ve seen / read about our Tundras, an 11 or 12 inch wide tire is best situated in the wheel well with somewhere between +18 to +25 offset.
    Hopefully someone on here can correct me if I’ve misspoken, but that’s my understanding.
    GODZILLA likes this.
  26. Sep 20, 2020 at 12:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Really, the most positive offset without hitting the UCA will rub the least. Somewhere in the +35 to +50 range. But very few wheels come in that offset and it really doesn’t give an aggressive enough stance most people are looking for. +25 is a good trade off between rubbing and stance and is a very common offset.
    irishpride114 and Bob_Wiley like this.
  27. Sep 30, 2021 at 4:47 PM
    21SXmachine
    21SXmachine New Member
    Black 21 SX
    17x8.5 +35 285/75
    Stock suspension
    No rub anywhere
  28. May 27, 2022 at 6:24 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I've done some searching but want to be certain before placing any order. I have a 21 platinum that I'm lowering with the SOS 2/4" kit. I want my rims to be flush with the fenders without flares. What offset or backspacing should I be looking for?
