2011-2018 Additional Transmission Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Dec 22, 2020.
  1. Dec 22, 2020 at 1:18 PM
    Genuine Cooling Systems [OP] New Member Vendor
    2011-2018 Tundra transmission cooler kits now available. This kit will tie directly into your factory transmission cooler to provide additional cooling efficiency for those owners who need it.
    This kit uses the Setrab Series 9, 10 row cooler.
    SpooledReel, Spvrtan, Joe333x and 5 others like this.
  2. Dec 22, 2020 at 3:31 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I would have been a couple weeks ago. I actually bought a Setrab 920 and designed a bracket in SolidWorks to mount it.
    For others who are considering a transmission cooler for their truck. Setrab is widely regarded to be one of, if not the best for oil cooling in the motorsports world. Le Mans, Baja, Dakar, these Setrab oil coolers have been on winning cars for a long time. I choose to make my own cooler setup using one of their coolers based on recommendations from guys who are serious track-car builders/racers.
  3. Dec 22, 2020 at 3:55 PM
    was209
    was209 New Member
    Kingfield, Maine
    2020 Tundra TRD Pro, Superwhite
    Trifecta tonneau, tube steps, Setrab transmission cooler
    Yes, I am interested. More info please.
  4. Dec 22, 2020 at 4:05 PM
    Which model did you go with? What year is your truck?
  5. Dec 23, 2020 at 10:25 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    My truck is a 2020.
    I got a Setrab 920 (9 Series, 20 Row, PN 50-920-7612). In hindsight the 915 was probably the better choice for this application, but I wanted to compensate for the efficiency loss due to the lack of ducting/shrouds. Regardless, the thermostat will keep the ATF in the right range.
  6. Dec 23, 2020 at 11:24 AM
    TheBeast
    TheBeast The Beach
    dont we have a transmission cooler on models below 2018s with tow package? will this be more efficient ?
  7. Dec 23, 2020 at 12:19 PM
    2011-2018 years have the ATF routed to the condenser, no external cooler.
  8. Dec 23, 2020 at 12:23 PM
    I am designing a bracket for the 915. The 920 is a little big to design a bracket for where I want to put it.
  9. Dec 23, 2020 at 12:29 PM
    Kanobi13
    Kanobi13 New Member
  10. Dec 23, 2020 at 12:32 PM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
  11. Dec 23, 2020 at 2:49 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Where are you planning on locating the 915? Similar location to the Hayden 778 setup you designed or somewhere else?
  12. Dec 23, 2020 at 3:01 PM
    Next to the center cross member, length ways down.
    Where did you locate yours?
  13. Dec 23, 2020 at 3:31 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Okay, I can see how you are trying to mount it.
    Mine is going to end up closer to the passenger side, but similar orientation, length wise down with the fittings facing 9 o-clock when you're looking at the front of the truck. I'll get mine installed in the next few weeks hopefully now that I have some time off work. I'll post up pictures at some point. I look forward to seeing your kit.
    If anyone is on the fence about a trans cooler kit for their 2019+, this new Setrab kit Nick is working makes it a no brainer. A must buy IMO, I would be buying if I hadn't already designed my own Setrab setup.
  14. Dec 23, 2020 at 3:56 PM
    Looking forward to seeing your set up. Do you have your own cnc machine as well?
  15. Dec 23, 2020 at 4:03 PM
    Vizsla
    Vizsla ☠️☠️☠️
    The external cooler is stacked on top of the condenser, they are 2 completely different and separate units, just packaging.
  16. Dec 23, 2020 at 7:37 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
  17. Dec 31, 2020 at 1:41 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I have access to a very small 5-axis CNC mill at work, but it can't handle a part this size. I'll have a local machine shop make my mounting plate. They have a 5-axis water jet and I work with them regularly to make stuff. They should be able to cut my mount next week now that I've had time to finalize all my dimensions/hole locations.
  18. Jan 18, 2021 at 2:04 PM
    I am looking for one person with a 2011-2018 willing to test fit the Setrab kit on their truck and provide feedback, pictures, and directions for me to update my website. This person will receive 40% off their Setrab kit.
    PM me if interested.
  19. May 1, 2021 at 7:52 AM
    timsp8
    NY
    Any update on this?
  20. Jun 27, 2021 at 4:53 AM
    Update: I have a design being fabricated now that will utilize the Setrab Series 9, 10 row cooler. It will be about 2 weeks before it is tested.
    ATHiker, Pbed85 and batman900 like this.
  21. Aug 3, 2021 at 5:03 AM
    Looking for a tester for the additional cooler on a 2011-2018 Tundra. Must be able to complete this install ASAP and work with me to provide feedback and photos.
    Please email me at genuinecoolingsystems@gmail.com if interested.
    ATHiker likes this.
  22. Aug 3, 2021 at 5:20 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5
    ATF Cooler
    Might be interested in helping, I'll email you now.
  23. Aug 4, 2021 at 1:04 AM
    I found someone, thanks everyone.
  24. Aug 4, 2021 at 1:51 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Interested.
  25. Aug 6, 2021 at 3:06 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    I’m interested, as well, when you get this up and going for my 2015 limited crewmax
  26. Sep 6, 2021 at 4:46 AM
  27. Sep 6, 2021 at 3:54 PM
    timsp8
    NY
    I have his kit. I haven’t towed yet, but driving around my truck used to level out around 195. Now it stays at 185. This is unpinned.
    The install took about 1 1/2 hours. Mostly looking for my tools. I could do it again in about 30 min. It also uses the stock hose. You just move the horn, mount the cooler, and turn the upper stock hose to the lower part of the cooler and put a new top hose on.
    If you are worried about the atf check procedure, I just added fluid to the cooler with a funnel. It took about 1/4 quart. Hardly any came out when I first unhooked the stock hose.
    Because it uses the stock hose, I could remove it in about 15 min. Just 2 hoses and clamps and 3 bolts. The dealer would never know it was there.
    My thoughts are the stock cooler isn’t that big. It’s just the top few inches of the condenser. This kit adds more surface area for cooling which will help dissipate heat when you are working the truck hard - towing or slow off road driving.
    For the price, ease of install, and ability to remove it quickly if you have to go to the dealer for any trans issues, I definitely recommend this kit.
  28. Sep 7, 2021 at 6:32 PM
    ATHiker
    ATHiker New Member
    Tom
    So is there a price for this kit?
  29. Sep 7, 2021 at 7:53 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    I’d be interested depending on price...
  30. Sep 8, 2021 at 3:07 AM
    timsp8
    NY
    SpooledReel likes this.
