Who has mounted a lightbar behind your grille?
Discussion in 'Lighting' started by ToyotaTundraMike, Aug 11, 2016.
  1. Mar 21, 2017 at 10:31 PM
    #61
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Do you have tips on wiring the bar?
  2. Oct 13, 2017 at 6:29 PM
    #62
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    smslavin likes this.
  3. Oct 18, 2017 at 6:50 PM
    #63
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I put a 42" behind grille and have a 32" for bumper. I was worried about air flow and cooling with both. I covered up the lower bumper opening on a 95 degree day to test and all was good. Now what I don't know is if the tstat just opened more to compensate. I will probably mount the 32 in bumper opening back a little to allow some air flow around it.
  4. Apr 30, 2020 at 9:30 PM
    #64
    Mrlumens
    Mrlumens New Member
    Hey man. Great looking truck! What light bar is that in your hood bulge? how has it treated you?
  5. May 1, 2020 at 2:21 AM
    #65
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    This looks very nice.
  6. May 1, 2020 at 5:20 AM
    #66
    Zero One Actual
    Duel @Caliraisedled light bars. One spot. One combo. Ditch lights as well.
  7. Dec 7, 2020 at 11:33 AM
    #67
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    Nice set up. I am thinking of doing the same with the dual light bars. Might be a dumb question... is there a noticeable difference between having two light bars compared to the one?
  8. Dec 7, 2020 at 1:07 PM
    #68
    Zero One Actual
    Yes there is a massive difference. I have both on different switches so I can run one or the other or both whenever. Usually I will turn both on on back country single lane roads or dirt roads at night when coming back from hunting or where there is a possibility of wildlife (deer mainly). I also turn on my ditch lights which I have angled out like they should be and not facing straight and I am pretty sure the space station can see me making turns.
    Other times I may just run one. I have both types they offer with the driving combo being on the top and spot being on the bottom.
    Also, depending on what grille you go with, the Cali Raised fuel light bar bracket has pre drilled holes for pre set positions. But if you don’t like where the bars are just drill your own holes in the bracket to get them where you want. Just remember to paint the bracket holes to prevent rust.
    LA184[QUOTED] likes this.
