Battery died now truck won't start
Discussion in 'General Tundra Discussion' started by BOBONTUESDAY, Nov 13, 2020.
  1. Nov 13, 2020 at 3:58 PM
    BOBONTUESDAY
    BOBONTUESDAY [OP] Grocery Getter
    2016 Limited Trd
    2016 5.7 270k
    My smitty built winch took a shit it started randomly engaging the winch on its own.
    I decided to unhook the winch but now my battery took a shit too won't start. Tried jumping it bought a new battery that won't work either.
    What fuse controls starting the truck?
  2. Nov 13, 2020 at 4:01 PM
    There is a 10 amp IGN fuse under the hood. Its turning over just no ignition?
  3. Nov 13, 2020 at 4:04 PM
    BOBONTUESDAY
    2016 Limited Trd
    If I get a jump it'll turn over but no ignition. I checked that fuse and it looked to still be good. At this moment even with a jump nothing will turn on lights or anything.
  4. Nov 13, 2020 at 4:06 PM
    BOBONTUESDAY
    2016 Limited Trd
    It's acting very sporadically. Like I've got some sort of electrical gremlin.
  5. Nov 13, 2020 at 4:06 PM
    Vizsla
    Vizsla ☠️☠️☠️
  6. Nov 13, 2020 at 4:07 PM
    Sounds weird, and I assume both cables are good and tight?
  7. Nov 13, 2020 at 4:08 PM
    BOBONTUESDAY
    2016 Limited Trd
    Oh yeah cleaned and tight. It is cold out there though.
  8. Nov 13, 2020 at 4:08 PM
    BOBONTUESDAY
    2016 Limited Trd
  9. Nov 13, 2020 at 4:39 PM
    BOBONTUESDAY
    2016 Limited Trd
    So looks like the 40 amp main was popped but now the only light I get Is the red lock one when the security system is on. The immobilizer light.
  10. Nov 13, 2020 at 6:01 PM
    BOBONTUESDAY
    2016 Limited Trd
    Little update checked every fuse no luck idk wtf is going on but there are absolutely no lights or anything turning on besides the immobilizer light.
  11. Nov 13, 2020 at 6:32 PM
    BOBONTUESDAY
    2016 Limited Trd
    Is it possible for the immobilizer to be triggered and not allowing the truck to turn on?
  12. Nov 13, 2020 at 7:52 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Not familiar with the 2016 key. Do you have push to start?
    If you do, you may be able to hold the FOB in front of the start button for 30 seconds and then try to start. Works on other Toyota models with push to start.
  13. Nov 13, 2020 at 7:54 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Immobilizer will allow everything but engine start. Including cranking, just not starting.
    Do you have a voltmeter? I’ll run you through a few basic checks if you do.
  14. Nov 13, 2020 at 7:58 PM
    BOBONTUESDAY
    2016 Limited Trd
    It's a regular key just like an 07. I believe push to start didn't show up till 2018 or 19.
    Then it's definitely not the immobilizer. I don't have shit besides the red little flashing immobilizer light..
    Yes I do.
  15. Nov 13, 2020 at 9:04 PM
    BOBONTUESDAY
    2016 Limited Trd
    So I don't think it's the main fuse/fuseable link since I get power to all of the individual fuses. But maybe I'm wrong I hope I'm wrong and it's just the fuseable link.
  16. Nov 13, 2020 at 9:39 PM
    BOBONTUESDAY
    2016 Limited Trd
    Little update. This is really weird when I hook up the ground for the winch it lets everything on the truck turn in but my battery is acting like it's too low to turn on. Tried jump but the truck wasn't having it.
  17. Nov 14, 2020 at 7:15 AM
    I know your battery is new, but have you tested it? Also, is there enough cranking amps?
  18. Nov 14, 2020 at 7:36 AM
    BOBONTUESDAY
    2016 Limited Trd
    Yes and yes I actually took the battery back because I thought it.wasnt charged up enough but it tested at 12.5.
  19. Nov 14, 2020 at 7:51 AM
    Is it the same as your last battery as far as CCA?
    My next guess, based on ur ground wires post is a lose cable somewhere.
  20. Nov 14, 2020 at 9:51 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ok, sounds like you have a ground issue then. First thing I would do is disconnect your winch ground cable again.
    Turn your key to the ignition on position and leave it there while testing. This is important for these tests, even though nothing seems to be turning on.
    Use your voltmeter to measure between the battery Neg. post (the actual lead post, not the clamp) and the engine, somewhere accessible and clean bare metal.
    Also measure voltage from the battery negative post and the body - preferably not the ground wire bolt on the inner fender but something close that isn’t painted so you’ll get a good connection. Maybe a headlight or horn mounting bolt.
    Let me know what you get on both readings.
  21. Nov 20, 2020 at 10:15 PM
    BOBONTUESDAY
    2016 Limited Trd
    Smaller by a bit but factory sized. They did not have a wide selection and I was desperate to fix this.
    It was a ground issue very simple one too. Totally unrelated to the winch.
    I did blow the fuse labeled main. Swapped that.
    I pulled off the ground cable that connects to the fender right off the battery sanded it a little bit put it back on and boom truck works again.
    It was acting so weird though I thought I had fried something. The immobilizer light flashing really threw me off.
    Thanks everyone for the suggestions really appreciate it.
  22. Nov 20, 2020 at 10:32 PM
    TheBeast
    TheBeast The Beach
    highest mileage on a 2016 on the forum ;)
    BOBONTUESDAY[OP] likes this.
  23. Nov 21, 2020 at 4:29 AM
    Aurora CO
    I recall you were going maybe jump ship when you hit 270K. So what's up? Another 50K?:thumbsup:
  24. Nov 21, 2020 at 5:52 PM
    BOBONTUESDAY
    2016 Limited Trd
    I test drove a few domestic 1 tons. Almost followed through but I can't deal with random break downs. They're so pretty though. Maybe next year still hoping toyota does something to tow more. Doubt it though so,
    I'll be sticking Around for another 30k atleast probably more at this point I've got the truck how I like it. Might as well hit 300k and kill the miniscule trade in value left . And there isn't anything wrong with it I've beat the piss out of this truck and it's still fine. I'm running 7 to 10k oil change intervals, idling for hours on end. Got mud in my headlight housing trying to use my truck as a boat lol. My paint is pretty fucked up too but who cares it's a truck. I might just keep this truck and get something else too. We'll see I've got plenty of time and options.
  25. Nov 21, 2020 at 5:57 PM
    TheBeast
    TheBeast The Beach
    well broken in :)
