Won't start, red light with key on
Discussion in '2nd Gen Tundras (2007-2013)' started by NCHammy, Nov 15, 2020.
  1. Nov 15, 2020 at 12:15 PM
    NCHammy
    NCHammy [OP] New Member
    Jerry
    2013 4.6L Double Cab 2WD
    None yet!
    After I decided to give up on trying to install a new sound system, I replaced the battery connection and tried to start.
    It won't start, turns over but there is a red light on by the clock on the dash. It's the shape of a vehicle with a key in the middle.
    Help!
    Rica25 likes this.
  2. Nov 15, 2020 at 12:28 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    That's your anti-theft immobilizer. I wonder if it forgot your key? Have another key to try?
    Rica25 likes this.
  3. Nov 15, 2020 at 12:29 PM
    Azblue
    Azblue Beer is Good Ban Moderator
    The Dirty T
    My guess is the truck's security system isn't recognizing the key.
    Dammit, @19TurdPro beat me to it
    Rica25 likes this.
  4. Nov 15, 2020 at 12:31 PM
    NCHammy
    Jerry
    None yet!
    No, I only have one key and two aftermarket fobs.
    Rica25 likes this.
  5. Nov 15, 2020 at 9:32 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your starter relay, and ground cable.. ensure both sides have good clean contacts and are tight.... have your battery tested... if you changed the connectors there is a slight possibility that something is not properly tightened down, double check your work and grounds...
    Rica25 likes this.
  6. Nov 15, 2020 at 11:04 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    +1
    Rica25 likes this.
  7. Nov 16, 2020 at 10:23 AM
    Dr_Al
    Dr_Al New Member
    Al
    You can try to disconnect the battery again to reset the computer but it does look like the computer forgot your key. This may involve going to your Toyota dealer to have them fix.
    I bought two spare keys off Amazon because I only had one. I had the local hardware store cut them for me. They did it for free since they had no way of programming the key so they didn't offer it. Before I left I tried both of them. For giggles I tried to start the truck and it did the exact same thing. It just turned over but wouldn't start. I used TechStream to program them but I had to have a working key to do it if I remember correctly. If you have a copy of TechStream you could try it. But I'm guessing for security reasons only the dealer would have a way to get around not having any keys working. Maybe they can cut a key based on the S/N and program it to match the original key's chip.
    Rica25 likes this.
  8. Nov 16, 2020 at 5:05 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    You definitely need a working key, if not a Master key to program/register new chip using Techstream. I've done adding new key using Techstream on our 2010 rav4 with immobilizer.
    Rica25 and Wynnded like this.
  9. Nov 18, 2020 at 9:30 AM
    NCHammy
    Jerry
    None yet!
    Email from dealership:.
    The tech started to determine why you had a no crank on your Tundra. Ritchie reports a error code of B279A (theft dererrent system communication line high fixation. He also found a open in the remote start harness. Harness ordered & tech determine more diag & damage possible. There is sign of a mice nest, foam protector chewed, mice droppings with wires damage. The tech is recommending to remove the dash & evaporator box to determine what connection or part has failed. Labor to start is 10.2 @ the labor rate of $140.00 ($1428.00) . Parts needed-that could be effected are Engine ECU ($1019.47), Transponder ECU ($380.00) and the Dah’s harness (2156.00). Tech states unable to determine a fix until the dash is removed. Insurance will need to be involved.
    Rica25 likes this.
  10. Nov 18, 2020 at 9:33 AM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Holy bucket of worms. That is not what i expected for a simple trip to the dealer for a key programming.
    Were you able to see the actual mice nest or anything like what they stated?
    I just felt the major headache you probably are having right now, just from reading all that.
  11. Nov 18, 2020 at 10:03 AM
    NCHammy
    Jerry
    None yet!
    No I haven't, I've placed it over to my insurance company and hope
    Rica25 likes this.
  12. Nov 18, 2020 at 10:07 AM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Best of luck. O hope they will take care of it so you can have your truck back in better condition. In a way this radio adventure kind of put you ahead of what could be way worse, like the truck get caught on fire with the exposed wiring. Right?
    I dont know, just trying to see the 'brighter' side of the situation.
    Rica25 likes this.
  13. Nov 18, 2020 at 10:09 AM
    NCHammy
    Jerry
    None yet!
    Yes, that is true. It could have left me stranded some place besides my driveway. It could be worse. I have full coverage so hopefully this will work out.
    Thanks for your help and words. I appreciate it.
    BrandonL812 likes this.
  14. Nov 20, 2020 at 5:58 AM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    When will you get your truck back?
  15. Nov 20, 2020 at 7:18 PM
    NCHammy
    Jerry
    None yet!
    Tomorrow hopefully
  16. Nov 20, 2020 at 8:00 PM
    TheBeast
    TheBeast The Beach
    $140/ hour..damn ! PhD guy working on your truck ? straight up robbery
  17. Nov 20, 2020 at 8:10 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    That's what we (trucking fleet) pay for semi-truck work in major cities o_O
  18. Nov 20, 2020 at 8:17 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    As a former Tech myself i can guarantee you competent Techs who work flat rate only receive a small percentage of that money, no-matter how talented they are. The rates dealerships charge are completely ridiculous, but the amount they are willing to share with the guys who butter their bread is the real crime in the end, and one of the reasons i decided to leave. My rant for tonight. :goingcrazy: :cheers:
    bleach and TheBeast[QUOTED] like this.
  19. Nov 20, 2020 at 8:53 PM
    TheBeast
    TheBeast The Beach
    oh yeah I believe you. One of the reason I go to a small shop with the same tech. I'd rather have him get paid than the dealership.
    TILLY[QUOTED] likes this.
  20. Nov 21, 2020 at 9:00 AM
    NCHammy
    Jerry
    None yet!
    I only went to the dealership because it was a possible key/security/computer issue and I was hesitant with that.
    Otherwise all my stuff goes to a local shop here.
  21. Jan 12, 2024 at 6:04 AM
    bvech73
    bvech73 New Member
    2010 White Tundra Rock Warrior
    @NCHammy, what was the end result of your situation?
    I have a similar situation but I have not done any work on my 2010 tundra and haven't had any issues with it ever.
    (Nov. '23)
    Symptom: Crank, no start
    Resolution: Towed truck to Toyota services and they performed Health Check. Came back with DTC B2795 (Key with unregistered key code). They gave me a new key and reprogrammed my existing key. All is good. This resolved my issue.
    Asked for explanation how this would happen after almost 10 years of using the same key and they couldn't explain it.
    (Jan. '24)
    Symptom: Same issue....crank, no start.
    Resolution: Will need to have truck towed to Toyota again. Not sure what the options are going to be?
    The tech also mentioned a potential of 10 hours of labor to remove the dash to troubleshoot this.
