Weird Noise
Discussion in '1st Gen Tundras (2000-2006)' started by arlail76, Oct 27, 2020.
  1. Oct 27, 2020 at 8:53 AM
    arlail76
    arlail76 [OP] New Member
    Andrew
    Stock 2004 Toyota Tundra Double Cab 2WD
    So I have a question...
    I’ve noticed that when I’m on the highway and I get over 70...I’ll hear a noise...almost like a brief, high pitch wail like air has found its way through into the cabin of the truck. It’s very strange. It only does it over 70, and I was able to get it to continue to make the noise while going 80.
    I don’t have any loss of power, loss of oil pressure, or anything like that, it’s just an annoying noise...and sometimes it doesn’t happen at all.
  2. Oct 27, 2020 at 10:49 AM
    shifty` Our private little trip to hell
    Deteriorated steering shaft seal maybe allowing noises in from the engine bay? Have you checked the seal?
  3. Oct 27, 2020 at 10:55 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. Could be those deteriorated rubber flaps vibrating with the air passing over them like a reed on a flute.
  4. Oct 27, 2020 at 11:08 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Windshield seal is another possible culprit
  5. Oct 27, 2020 at 1:05 PM
    arlail76
    Andrew
    I’ll check it out and let everyone know
    thank you for the suggestions
  6. Nov 7, 2020 at 9:20 AM
    arlail76
    Andrew
    Well, I’ve sealed every place I could see on the top side that could be air coming in making the noise. Still got the noise. Guess I need to check underneath and get out that fine toothed comb.
