Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Mar 9, 2017 at 10:19 PM
    #721
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Ok, that kind of makes since in your case. Not sure about mine, but I'll have to check it out. I know the auto up feature does the bounce back thing. I can't pin her down on it, but seems to me that it has to do with my wife just not closing it all the way and not wanting to admit it. I find The window open in The morning and she swears it was closed. The sunroof definitely has issues. I'm just going to disconnect the power to it. We've had a couple close calls with it. I caught just before a storm a couple times and had to drive 20 miles in the cold when it wouldn't close with a storm coming in. Ever seen the front seats of a car full of snow? Not a pretty sight!
  2. Mar 9, 2017 at 10:49 PM
    #722
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    There we go blame it on the wife for not closing the window LMAO. You should know it is women's rights month. I'm sure this would be causing your problems. Just kidding of course. My 4 runner has the auto up feature and I have never had a problem with it. What is the bounceback thing? Does this happen when you drive the vehicle or only her? Did the sunroof and window problem start at the same time?
  3. Mar 10, 2017 at 5:33 AM
    #723
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    You have aftermarket trailer wiring installed?
    Sounds like a back feeding problem. You have power getting into your brake circuit some how when the tail light circuit is on... need to be saved with electrical to figure that one out
    Lots of mileage? Check for play in your wheel bearings up front, also us a backing plate could be it
  4. Mar 10, 2017 at 5:40 AM
    #724
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Only 63k miles will check for play in tires. Thanks bud!
  5. Mar 10, 2017 at 6:11 AM
    #725
    T-Rex266 [OP] Elon approved Staff Member
    Cat3ILS and Law323 like this.
  6. Mar 10, 2017 at 8:45 AM
    #726
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    I had an old 2 door Chevy Blazer that kept unlocking the doors by themselves. Went out of town and the battery was dead upon return with the doors unlocked. Turned out to be the electric door lock switch in the drivers door. But it was very frustrating.
  7. Mar 10, 2017 at 9:14 AM
    #727
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Will gen2 2wd spindles work on a gen 3 4x4 ?
  8. Mar 10, 2017 at 10:02 AM
    #728
    Tomcat
    Bakflip
    I have a factory tow package. No aftermarket wiring. I will be able to work on it later today after my woman gets done driving her truck, oops , I mean my truck.
    NewImprovedRon likes this.
  9. Mar 10, 2017 at 7:29 PM
    #729
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Lotsoftoys, I had Dave from Lexota plug in techstream and go for a ride on the mountain roads where I know the trac acts up. Even with the tires at 30 psi it still did it but not as bad. Dave found that the wheel speed difference from side to side is outside of the parameters, causing the computer to think it needs to step in to prevent a slide. From asking others on here that have the Hypertech speedo calibrater that it might help. I talked to hypertech yesterday and the guy said it won't because it simply plugs in behind the speedo. It doesn't plug in to the computer system. Is there any way to adjust the system for the taller tires? Any ideas on why it seems like tons of guys have taller tires than me and don't have this issue? I have stock wheels, seems like the majority of guys with lifts and bigger tires have less offset. Could widening the stance help? Doesn't seem that would make a difference. But maybe with the higher center of gravity, you need a wider stance to balance it out?
  10. Mar 10, 2017 at 10:56 PM
    #730
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Oh yeah, the guy at Hypetech said he new of several people who have had trac issues that were caused by the alignment being out. But it didn't do anything weird until the tires and everything looks good after you aligned it.
  11. Mar 11, 2017 at 11:59 PM
    #731
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    This caught me off guard when I first got my tundra too. Chevy, Lexus, Ford etc. all handled the same at a stop without needing much foot to hold the vehicle in place, but damn if the Tundra wouldn't creep forward every time using the same pressure I was used to on other vehicles. I'm used to it now...almost. I still catch myself every once in a while not holding enough foot on the brake.
  12. Mar 13, 2017 at 8:54 AM
    #732
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Question....
    Althoughthe 5.7L kicks ass, I live at almost 11,000 in elevation and my heavy truck with lift and 35s still has to work hard. What's the best remedy for the elevation I live to get better mpgs and power? Would a good intake approach be sufficient or should I go with a supercharger?
  13. Mar 13, 2017 at 9:03 AM
    #733
    Intake can't compare to a SC for power.
  14. Mar 13, 2017 at 9:04 AM
    #734
    Eclipsed & Floating
    Voluptuous Whitey
    I'm sure, but would an intake be sufficient? Isnt your truck supercharged?
  15. Mar 13, 2017 at 9:33 AM
    #735
    I don't even feel the 35" on mine with the SC
  16. Mar 13, 2017 at 9:33 AM
    #736
    Eclipsed & Floating
    Voluptuous Whitey
    That's all I needed to hear
  17. Mar 13, 2017 at 12:18 PM
    #737
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Doubtful
    I've heard different load ratings can cause issues with trac... try a different set of wheels and tires
    T-Rex266[OP] likes this.
  18. Mar 13, 2017 at 7:05 PM
    #738
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Jace, I'm sure that if I put the stockers back on my trac issues will go away. But I just spent $1500.00 on the upgrade and can't afford to sell at a loss. Is there any way to adjust the system for the taller tires? Looks like with the bullydog tuner you can turn the trac off without having to mess with the switch every time you start the engine. Still not a true fix, but if that is the only option I might go that route. I'm used to vehicles without trac, so not to concerned about it. Of course there goes another $400.00. Of course the tuner does do a lot of other stuff to. What are your thoughts on tuners?
  19. Mar 13, 2017 at 7:18 PM
    #739
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Could look into re-gearing as well. I haven't geared my truck yet but gears should give you both what you're looking for.
  20. Mar 14, 2017 at 7:22 AM
    #740
    timebak
    timebak New Member
    2011 Black Tundra Limited
    Husky Mats, Trailer brake controller, Tonneau cover, other goodies coming soon.
    Yesterday I received my new fuel/air ratio sensors (Denso #234-9026, from Amazon, 2 @ $115.88 ea.) and O2 sensors (Denso #234-4260, Left rear, from Amazon for $54.68, and Denso #234-4624, right rear, from Amazon for $52.83). I installed them last night and was able to get all four of them off using just a Craftsman 7/8" combination wrench, although I have the O2 sensor tool kit that Toyota uses. I chased the threads on the exhaust pipe fittings, used the anti-seize that Denso supplies with the sensors and had the whole job done in about 2 1/2 hours. Truck ran great immediately afterwards and instantaneous MPG readings seemed to be coming up to what it used to be.
    The real test was this morning. The truck sat out all night and the temperature this morning was 23 degrees. Prior to changing these sensors, the truck would have started jerking and bucking as soon at it got to about 1700 rpm and kept it up for at least a mile and a half. This morning it was SMOOOOOOOTH as chicken lips. No surging, bucking, jerking, belching or farting. Sarge behaved like a gentleman. (Wife named the truck, not me. But it's a good name for a truck that's tough, strong, and don't take no sheit off anybody.)
    mley1, kparrow, LOTSOFTOYS and 2 others like this.
  21. Mar 14, 2017 at 7:31 AM
    #741
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    glad you got it fixed!
  22. Mar 14, 2017 at 8:01 AM
    #742
    timebak
    timebak New Member
    tomsinamerica, This job cost me only around 350 bucks, including shipping, and the dealer wanted over $1,200 to do the same thing with the exact same brand and part number of parts.
  23. Mar 14, 2017 at 8:19 PM
    #743
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm not a huge fan of changing ecu logic... typically u can get alot of money for tires in good shape on cl... I don't know why you are having trouble, when other trucks with similiar setups are not.. weird. Only thing I can think of is the tires. Not exactly the size but the compound? I wish the had a sensitivity setting on the trac but they dont...
  24. Mar 14, 2017 at 8:32 PM
    #744
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Jace, yeah I am sceptical about tuners to. Trucks got plenty of power and I don't want to screw it up. I put the stock wheels with stock size P275/65/18 back on today. The only good news is that the tpms light didn't come in. Still doing the same thing. I stopped by Dave's shop, he ran tech stream on a drive a couple weeks ago. He's kinda stumped, no codes about a bad sensor. I'll drive it some more and see if maybe it'll settle down. Any ideas as to what the heck it could be. I notice that it looks like it might be toed in to much. Could the zero point be off still. I played with the amount of rake with the airbags and played with tire pressure.
  25. Mar 15, 2017 at 12:56 PM
    #745
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Jace, drove the truck a little more and it looks like the trac has settled down. It went off a little bit in a tight turn with loose sand on the pavement, just what it should do. Now I need to work on discount to trade me out to a different tire without having to take a big hit in the pocket. What do you think about going to the ridge grappler in a 275/70/18? Its still an E rated tire and 1.25 inch taller than stock but same width.
  26. Mar 15, 2017 at 1:10 PM
    #746
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Jase will know better than me, but I have the Ridge Grappler in 275/70R18 on my 2016 4WD CREWMAX and I haven't had any trac issues (knock on wood). I've only had the tires for a couple of weeks and only have a couple hundred miles on them, but so far I haven't had any problems. Just one data point for you. I've been following your issue for the past few weeks and hope everything works out with the trac issue.
  27. Mar 15, 2017 at 1:17 PM
    #747
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, I'm pretty frustrated with the whole trac thing. Guess I got the sensitive one!:annoyed:have you had your truck out on any windy roads? Mine was only doing stupid shit when the nose dives with the steering wheel at about a quarter turn.
  28. Mar 15, 2017 at 2:05 PM
    #748
    757TUNDRA
    Illinois
    I haven't to this point. All of the roads in my area are pretty much flat and straight. The closest thing to a windy road I've been on are sharp on- and off-ramps and I didn't have any issues there.
  29. Mar 15, 2017 at 2:11 PM
    #749
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Sharp on and off ramps are probably about the same. 30 to 40 mph? Of course I've heard that maybe the 3rd gens aren't as sensitive as the 2nd gen.
  30. Mar 15, 2017 at 2:19 PM
    #750
    757TUNDRA
    Illinois
    Yeah, anywhere from 30-45 mph on/off the ramps .
