Driver Side Door Wont Unlock From KeyFob
Discussion in '2.5 Gen Tundras (2014-2021)' started by jDaGr8, Oct 15, 2020.
  1. Oct 15, 2020 at 6:15 PM
    jDaGr8
    jDaGr8 [OP] New Member
    Whenever I try and unlock my truck from my key fob, all the other doors unlock but my driver door doesn't. Same thing with locking as all the other doors locked besides the driver side door. Has anyone else had this problem and it something I could fix or would I need to take it to a shop?
  2. Oct 15, 2020 at 6:53 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Does your driver door lock/unlock with the button on the door? If not, sounds like the actuator for your driver door. If so, it's beyond my knowledge level.
  3. Oct 15, 2020 at 6:57 PM
    jDaGr8
    no the only thing that unlocks it is the actual key, so I guess its the actuator
    Moon Puppy likes this.
  4. Oct 15, 2020 at 7:57 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Reach out to @Roman for a part# and quote for the actuator. @2020Platinum has videos of how to take just about everything apart - he might have something that covers the door, at least on newer models. That may be enough guidance for you to get into yours. You can then replace it yourself and save the labor costs. Not to mention the feeling when you have fixed something yourself!
    Roman and 2020Platinum like this.
  5. Oct 15, 2020 at 8:26 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    If it's the actuator, you shouldn't hear the beep when you press the lock button on your remote.
  6. Oct 15, 2020 at 8:49 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Even if the other door actuators are working?
  7. Oct 15, 2020 at 9:45 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    It sounds like your cable may have come loose… Watch my video on how to take the door panel off and apart, check the cable that goes to the lock (check the side that goes into door, not where it engages lock on door)..,I’ve actually had mine pop off and it caused the same exact problem… I was able to pop it back into place and haven’t had a issue since, hope it helps!
    https://youtu.be/CkwrSuYg6xY
    mountainpete and jDaGr8[OP] like this.
  8. Oct 16, 2020 at 8:49 PM
    Tundra Fan
    Toby
    Yes, if any of the doors won't lock, you won't hear the beep. I've already had one replaced, have one totally out, and a third going out. I'm so used to manually locking my damn doors now that I'll probably keep doing it even after I get them fixed.
  9. Oct 17, 2020 at 4:25 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    This is common with Toyota’s unfortunately. Some will replace just the motor. All four of my actuators on my 4runner went out within three weeks of each other. Dealership will charge exorbitant amounts (my quote was $460).I ordered the aftermarket brand on Amazon and replaces them all. Cost was $45 each actuator.
  10. Oct 17, 2020 at 6:10 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Is your 2019 already out of warranty?
    EDIT: Sorry, I reread and so that your were talking about your 4Runner! Not enough caffeine yet!
  11. Oct 17, 2020 at 6:22 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    Actuator. Wife's Venza did this on 3 doors.
  12. Oct 17, 2020 at 8:57 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    What others said. Actuator is a common problem with our doors. Save yourself some $$$ and just replace the motor and not the whole assembly. Only like $8 on Amazon. I got lucky on mine and when I removed the door panel I found that the plug had just come undone, didn’t even have to replace the motor.
  13. Oct 1, 2021 at 2:44 PM
    kfaracesd
    kfaracesd New Member
    I am having the same issue, however I did replace the actuator. The actuator fires to lock just not unlock. Both with the key fob and the door switch work the same, i.e. can not unlock driver door. I took the whole door apart again and tested both lock and unlock wires to the actuator and on the lock wire had power when locking the door. The unlock does not. No power to the unlock cable. I followed the cable the the floor kickplate and it looks fine. All the other doors work. Can someone tell me if there is an unlock relay for the drivers door specifically. It would make since as when you press unlock on the fob only the driver side unlock first then on second press the other doors unlock?
    Maddog87 likes this.
  14. Oct 1, 2021 at 3:35 PM
    JackwagonJim
    JackwagonJim New Member
    Purlear, NC
    Isnt there a setting via the radio to enable all doors to be unlocked via fob?
  15. Oct 1, 2021 at 4:19 PM
    kfaracesd
    Yes there is a setting just tried it. Now all the doors except the front unlock on one click, not two. Lol. However I did find that there is a d-dr unlock relay. It appears to be above the driver side interior fuse box. But when I went to the dealer they couldn't find the part. Guess I have to pull the fuse box to see what is what
  16. Oct 1, 2021 at 4:25 PM
    BlueTSS
    BlueTSS New Member
    2014 Blue Tundra TSS
    Exterior - ReadyLift 4” SST Lift - BFG KO2 285/65/R20 - GST black wheels (2021 TSS) - MGP red caliper covers - TRD exhaust with black tips - TRD rear sway bar - Toyota blackout emblem overlays - Toyota bed rail system - Toyota bed light kit - AlphaRex headlights - AlphaRex style taillights - OEM LED fogs - OEM honeycomb grill - VLEDS Interior - Katzkin black leather seats - TRD black shift knob - Toyota all weather floor liners - SET wireless charger - Taco Tunes starter system - JL Audio 10TW3 - 3M 35% front tint - VLEDS
  17. Oct 1, 2021 at 5:39 PM
    kfaracesd
    Thanks but I already replace the actuator. The actuator is not getting power in the unlock wire. Hence I am looking to replace the drivers unlock relay
  18. Oct 1, 2021 at 6:07 PM
    BlueTSS
    BlueTSS New Member
    My bad, I misread that earlier. Any chance you have an aftermarket alarm installed?
  19. Oct 1, 2021 at 6:13 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Yep
  20. Oct 1, 2021 at 6:16 PM
    kfaracesd
    No alarm ... no looking forward to trying to pull the relay. Any advice
  21. Oct 1, 2021 at 7:34 PM
    JackwagonJim
    Purlear, NC
    Ah mis read your first post. Lol.
  22. Oct 19, 2022 at 11:39 AM
    cf_engineer
    cf_engineer New Member
    2017 White Tundra Platinum
    I am curious if anyone has resolved this issue with the driver door not unlocking? I, like others, have replaced the actuator and have determined that the actuator is not the problem. I confirmed this by paying the stupid tax at the dealer, then they wanted a blank check to keep trouble shooting this issue. I have also joined the TIS and paid to download the wiring diagrams and "if/then" statements trouble shooting the issue. I have landed at having to pull out the main body ecu (no relay in the system that I have found) to test the pin fit and continuity of the designated pins as outlined in the TIS. I am hoping someone else has resolved this issue without having to go as far as removing the main body ecu and/or having to replace it. As my issue was intermittent at first, (i.e. quit working for a couple days, then worked for a few weeks, and ran through this cycle a few times before it completely quit working) it does not seem that an ecu would be the culprit as I would think I would have more issues than just the door not unlocking. Below is a short list of symptoms and what has been done so far.
    Symptoms:
    -Driver door will not unlock using the key fob nor the unlock switch on driver or passenger door.
    -On first push of unlock button on key fob, there is no chime or "beep", no unlocking of door, but the courtesy lights on interior and exterior come on.
    -On second push of the unlock button on the key fob, all other doors unlock and there is a beep.
    -All doors Lock from the fob, door switches, and when truck is put in gear.
    -Driver door does not unlock when truck is put in park.
    Measures taken thus far:
    -Removed driver door actuator and tested manually. Functioned properly
    -Replaced driver door actuator anyway with OEM replacement part. NO change in the symptoms
    -Tested continuity from actuator to connections in kick plate, then to pins on front side of main body ecu. All checked out
    -Took truck to dealer and paid the initial diagnostic fee to confirm my findings. They confirmed and did not have a resolution and wanted an estimated $800 more to continue diagnostics. I declined as I didn't to put $1,100 into them trying to find the electrical demon....
    -Downloaded TIS diagrams and repair process for this issue
    -The TIS process follows what I have done thus far up to the point of testing the connections on back of main body ecu which requires removing it in order to gain access to connections.
    Modifications to truck:
    -I did the 2018 Headlamp and fog lamp swap to have all LED's, using contacts and suppliers from this forum
    Thank you to anyone with any solutions, ideas or suggestions.
  23. Nov 12, 2022 at 10:51 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    So I am having similar issues, but it's not just the drivers for that I am having issues with. Some times it is the drivers door and sometimes it is the front passengers door. But when they won't lock or unlock with the remote, they also won't lock or unlock with the button in the truck. I'm at a loss of what to do. :confused::confused:
  24. Apr 22, 2023 at 5:16 PM
    crazyjohnny
    crazyjohnny New Member
    Johnny
    2017 TRD Pro
    Shimmed, 1.5" Shackles, Viair Onboard air, Firestone Air bags, CBI Sliders
    Anyone ever figure this out? I am having the same issue with the unlock - the actuator is good but will not unlock.
    I replaced the actuator today to confirm that wasn’t the issue. Hopefully can find and replace a relay somewhere else.
  25. Apr 22, 2023 at 6:26 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  26. Apr 22, 2023 at 6:34 PM
    crazyjohnny
    Johnny
    2017 TRD Pro
    Thanks, confirmed it was not a key issue. The drivers door with not unlock from the inside either. All the other doors lock/unlock. The fob locks the drivers door, but somehow the unlock side must not have power.
  27. Apr 23, 2023 at 8:46 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Actuator is bad.my drivers front door died as well. Easy fix
  28. Apr 23, 2023 at 10:33 AM
    crazyjohnny
    Johnny
    2017 TRD Pro
    I replaced the actuator, did not fix the problem. So I figure it is something electrical.
  29. May 4, 2023 at 2:16 AM
    Siv_l185
    Siv_l185 New Member
    2016 TUNDRA SR5
    I'm having same issue. Haven't had time to trouble shoot fully but my plans are to check for power at actuator. Going to do some research on part diagram some how to see how many wires actuator has then go from there. Gotta figure out how the darn thing works before I can fix. I'll post any findings so as to pay it forward. Forums like these have helped me tons in the past.
  30. May 4, 2023 at 7:25 AM
    crazyjohnny
    Johnny
    2017 TRD Pro
    So I ended up testing voltage at the wiring harness into the door actuator. I've got voltage when it locks, but no voltage when unlocking. Going to try and work the problem down the line. See below for how to trouble shoot.
    If you have a multimeter you can verify the issue directly. The Wire plug connecting to the actuator has 2 large pins at the top, these are your power pins. If you take a multimeter and set it to DC current. Touch the 2 probes to the 2 larger pins and press lock and then unlock. When you press lock you will see a 12 volt reading (positive or negative does not matter). Then when you press Unlock you should see another 12 volt reading (opposite of your first reading).
    If you get the voltage reading when you press both Lock and Unlock the issue is a bad actuator.
    If you do not get a 12 volt reading on either of the presses then the problem is further up in your vehicle (ecu, bcm, wire harness, fuse....).
