Pics of your lifts with stats!
Discussion in 'Suspension' started by GratefulDean, Aug 27, 2020.
  1. Sep 20, 2020 at 8:59 AM
    #91
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    You see- now you went and did it. Got thinking about the regear and the rear locker again. Your setup is clean dude. Love it!
    PeakIT[QUOTED] likes this.
  2. Sep 20, 2020 at 9:05 AM
    #92
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Gears made a huge difference, just add 1000 rpm to everything. The AC works better, i live in Salt lake and spend most of my time on hills or in mountains or towing. No freeway commute. Getting 12mpg it was at 9 . But thats better than my Tacoma, and I'm heavy footed, the locker helps with tire spin with the lower gears and traction control i would hit regularly even stock.
    Beesta likes this.
  3. Sep 20, 2020 at 9:21 AM
    #93
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Looks good and getting all the bells and whistles, but honestly after replacing my stock leafs I think you’re missing out on a huge performance gain after I switched and the difference was phenomenal. Doesn’t have to be Deavers or Alcan custom. I got Dobinsons And sure icon performance is great too.
  4. Sep 20, 2020 at 10:12 AM
    #94
    PeakIT
    PeakIT Old Member
    Utah
    I had Dakar on my taco so squeaky once the snow and salt and sand gets in them i even took the packs apart sand blasted and used por15 on them . I cant go any higher in the rear until King makes my custom length rear shocks I ordered 5 months ago. Then i will do a spring pack. I only really want another inch in the back.
    Skey44[QUOTED] likes this.
  5. Sep 20, 2020 at 12:10 PM
    #95
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yes, OME are known for that. Why I went Dobinsons.
  6. Sep 20, 2020 at 7:00 PM
    #96
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Truck looks excellent! Did you do the BLHM to those headlights?
  7. Sep 20, 2020 at 8:15 PM
    #97
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Pro lights
  8. Sep 20, 2020 at 9:00 PM
    #98
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I have been running a simple Ready lift 3"/2" lift for the past 5 years without any issues. Running 296/65's which calculate out to about 36" I have chopped the cab mount brackets and done a little to the fender inner liners, it rubs a little with a full left or right turn, but its not bad.
  9. Sep 22, 2020 at 11:45 AM
    #99
    406Michael
    406Michael New Member
    2014 Limited CM
    Love your set up! How have you liked the regear so far?
  10. Sep 22, 2020 at 2:46 PM
    #100
    PeakIT
    PeakIT Old Member
    Utah
    Its way better on hills and in the city. The ac works better with a little more engine speed. The auto downshift for breaking on hills works better . I mostly do not do freeway unless I am going camping, The rpm are at 2100 at 75mph on the freeway and it does not gear search while towing. In the city it gets 2mpg better than before but -probably better for people who drive less aggressively than me. Its way faster now. Reminds me of how trucks used to be 20 years ago before they dumbed them down made them soft $60k+ luxury vehicles.
    406Michael[QUOTED] likes this.
  11. Sep 24, 2020 at 10:52 AM
    #101
    406Michael
    2014 Limited CM
    @PeakIT Thank you for the response. And I think I agree with you on the trucks from years ago! I built a rock crawler out of my 1988 Toyota pick up, 36" tires, arb locker and 5.29 gears. I am curious, are there options to re-gear to a little ratio, such as 4.56 or 4.88? If so, why did you choose 5.29s?
    PeakIT likes this.
  12. Sep 24, 2020 at 11:49 AM
    #102
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    There are only two options for our current gen, 4.88 and 5.29. I recommend 4.88 if you are going to 35's tires and 5.29 for 37's. I do wish they made 5.10 or 5.13 to better balance performance and mpg with 37's.
    brown1794 and 406Michael[QUOTED] like this.
  13. Sep 24, 2020 at 1:34 PM
    #103
    The Patriot 1776
    '16 TSS CM 4x4
    OME with 613 front springs, Dakar full lead pack, greasable shackles, Toyo M/T 285/75R18.
  14. Sep 24, 2020 at 8:26 PM
    #104
    PeakIT
    PeakIT Old Member
    Utah
    i had a 2016 tacoma i regeared to 4:88 with 33s and it was perfect. (The Tacos i think have a higher final drive gear than the tundra?). Somewhere theres a chart (maybe Yukon gears?) So i went with 5:29 for my tundra with 35" . Most of my use is in the mountains 4800feet to 9000 feet altitude. I wasn't looking for factory mpg performance and sustained 75-100 mph speeds, but lower gear ratio. I don't use freeways much, if i had a long freeway commute I might have done 4:88 . Everyone has their opinions on this .I will most likely supercharge mine, and i believe the higher engine speed will make more linear power.. Ive had probably 20 regeared vehicles rock crawlers, race cars etc. 4:56 in my cj7 was way way low but it had a different transmission gear ratio and final drive ratio and dual transfercases . If you are in Utah come drive it.
  15. Sep 24, 2020 at 9:52 PM
    #105
    Qwazymoto
    Qwazymoto New Member
    Wait, you didn't chop to fit those 35's with this setup??
  16. Sep 25, 2020 at 6:17 AM
    #106
    14burrito
    2014 SR5 CM 4x4 5.7
    Correct! 35s fit with no issues with proper wheel offset and alignment.
  17. Sep 25, 2020 at 7:30 AM
    #107
    GratefulDean
    GratefulDean [OP] Swagless
    Dean
    Rocky Mountains
    2020 Tundra SR5 TRD in Cement Grey
    Bed Rack, Decked System, Softopper
    What is the offset? I think you may have been what I was looking for when I started this thread. I’ve also been thinking of swapping my 18’s to 17’s. Was thinking of starting a pros and cons thread on the subject of rim size.
  18. Sep 25, 2020 at 8:23 AM
    #108
    14burrito
    2014 SR5 CM 4x4 5.7
    From my understanding, +25 on 9 wide is ideal (with proper alignment of course).
    Icon has a 17x18.5 +25,
    https://www.tundras.com/threads/icon-alloys-17-5x150mm-six-speed-wheel.22729/
    My rock warriors are 17x8 +50
    IMHO, the only pro to a 18 vs 17 is one specific tire size... 285/75/18 which is a narrow 35". Otherwise I'm a 17" guy.
    Hightide likes this.
  19. Sep 25, 2020 at 8:54 AM
    #109
    brown1794
    brown1794 New Member
    Joey
    Windsor, Va
    2015 sunset bronze mica 1794
    38s it is then....
  20. Sep 25, 2020 at 8:59 AM
    #110
    The Patriot 1776
    '16 TSS CM 4x4
    I have 18’s with +12 offset and don’t rub with 35’s. SPC UCA’s and the correct alignment makes a huge difference.
    406Michael likes this.
  21. Sep 25, 2020 at 9:32 AM
    #111
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    How are the BP51s treating you and wearing? Any leaks on the shock pistons? What's the rebuild time frame on these?! I have an Icon setup on my 4runner and had to rebuild them after 45k miles...tho they suggest every 15k if used for mudding and rock climbing...blew my mind!
    Edit: truck looks amazingly perfect!
  22. Sep 25, 2020 at 11:04 AM
    #112
    java230
    java230 New Member
    Thanks! I like it too :)
    So far so good. No obvious leaks, but I only have ~4k on them. I could soften the front up a little, but I have not messed with it yet. I have a bumper coming soon.
    No idea on rebuild, but like any rebuildable shock I am sure they say 20k ish. But IMO it depends on use a lot. Mud on the shafts all the time wears seal faster etc.
    HulkSmurf14[QUOTED] likes this.
  23. Sep 25, 2020 at 12:01 PM
    #113
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I have considered this setup for awhile now since the majority of my driving is on pavement and part of me wants to put 295/75/20 but not sure if that would fit. Obviously some trimming would be involved. Since you went with a larger tire did you have to recalibrate the speedometer?
  24. Sep 25, 2020 at 12:40 PM
    #114
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    @PeakIT Thanks for the info. I never knew re-gearing would help with the MPG's on our trucks. I'm going to look into that now. I'm at about 9.68 city now with my lift & stock gears. I actually have a shop re-gearing our 71 Chevelle so hopefully I can get a deal going since he's doing work for me already.
  25. Sep 25, 2020 at 12:44 PM
    #115
    ericnvb
    ericnvb New Member
    Eric
    Virginia Beach, VA
    2020 TRD Pro
    [QUOTE="300BLK, post: 1881972, 2.5" 612 Old Man Emu with a 1.5" Toytec block in the rear. OEM TRD Off Road wheels with 295/70/18 Falken Wildpeaks and 1.25" Spidertrax spacers. Installed everything myself.[/QUOTE]
    Looks real sharp... love the black on black look!
    300BLK likes this.
  26. Sep 25, 2020 at 1:56 PM
    #116
    BUCS_KID88
    BUCS_KID88 New Member
    Trdpro with CB shims +1 CB shackles +3 295/70/18 Nitto Ridge Grapplers. 18x9 +25 SR8 Gunmetal wheels
  27. Sep 25, 2020 at 3:02 PM
    #117
    -soysauce-
    -soysauce- New Member
    2001 SR5 2WD
    Bilstein 5100 Struts (front and rear)
    - Lowest setting
    Dobinson Coil Springs
    KYB Strut Mounts
    Energy Suspension Insulators
    JBA Upper Control Arms
    Moog Lower Control Arms
    SPC Cam Adjusters
    Toyota Genuine Lower Ball Joints
    yes... tires are next
    Tundra14Platinum and HammockYota like this.
  28. Sep 25, 2020 at 11:04 PM
    #118
    nikosan
    nikosan New Member
    2014 Tundra Platinum
    No I did not recalibrate the speedometer. GPS speedometer only shows a difference of 2mph speed difference compared to actual speedometer speed
  29. Sep 26, 2020 at 12:07 AM
    #119
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    New stance with 6112s maxed out up front and CB shim on driver side paired with Deaver 748 leafs and MCM shackles along ADS triple bypass rear shocks
    Still rockin 305/65R18 KO2s for now.
    35s coming soon along w ADS front shocks.
    drobb and HammockYota like this.
  30. Sep 26, 2020 at 4:44 AM
    #120
    Strangefellow
    Strangefellow New Member
    Ryan Stringfellow
    2020 Tundra Doublecab 4x4
    3.5” Rough Country lift, 275/65/R20 Cooper AT3 tires.
