Poll: 2018+ TSS Radar/Precollision Problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by silverhack, Aug 22, 2018.
Do you have recurring TSS Radar/Pre-collision warning problems?
  1. NO: stock suspension (or new shocks set at stock height)
    45.4%
  2. NO: leveled/no rake (+2 front only or 3/1)
    12.3%
  3. NO: lifted with no rake (over 3" front lift and no rake or <1" difference front/back)
    4.3%
  4. NO: lifted with rake (1" or more difference front/back)
    8.2%
  5. YES: stock suspension (or new shocks set at stock height)
    20.9%
  6. YES: leveled/no rake (+2 front only or 3/1)
    3.9%
  7. YES: lifted with no rake (over 3" front lift AND no rake or <1" difference front/back)
    2.3%
  8. YES: lifted with rake (1" or more difference front/back)
    2.7%
  1. Aug 31, 2020 at 4:31 PM
    #181
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes but it's not turn off permanently. If you want to use it you have to select ON. It was meant for those that changed their grills or lifted the truck so that if there was an accident Toyota couldn't be held liable.
  2. Sep 3, 2020 at 10:04 AM
    #182
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    After replacing the AJT bracket with the Jomax, I haven't had a single issue. I was having errors every single drive, even if it was a short 5 minute hop. Now it's been two days, about 50 miles, and no issues. I'm not sure if it's the front cover that's about a quarter of the thickness of the AJT, or the fact that the Jomax puts it in a slightly different location, but it's so nice not having error codes for once!
    silverhack[OP] likes this.
  3. Sep 3, 2020 at 12:03 PM
    #183
    glowblue
    glowblue From time to time
    VA
    Nice - I’m not familiar with the AJT bracket but it appears that something causes the radar sensor to not work properly. The Jomax bracket is most expensive but it seems to work better.
  4. Sep 3, 2020 at 12:48 PM
    #184
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Opposite here, I had never heard of the Jomax until recently.
  5. Sep 5, 2020 at 1:45 PM
    #185
    Timberwolf2020
    Timberwolf2020 New Member
    Update. I took it to the dealer, of course they said it's normal, they all do that. They said they could not change the setting to default off on the PCS, I had to change it every time I started it. I may try another dealer. Does anyone know how to do this on techstream? Or what I could tell my dealer? I just hate to have to manually turn off this stuff every time.
    100LL likes this.
  6. Sep 5, 2020 at 1:49 PM
    #186
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    I have a Techstream connector on the way and I'm hoping to do this. If I figure it out, I'll let ya know.
  7. Sep 5, 2020 at 2:36 PM
    #187
    AggiePhil
    College Station, TX
    How does the Jomax bracket position the sensor differently? Do you recommend this piece when going from a Platinum grille to a TRD Pro grille? I was under the impression that the TRD Pro grille comes with the necessary bracketry. Was also wondering if, since the sensor is lower on the TRD Pro grille, it should only be used on trucks with a bit of a lift. Currently, my Platinum is still stock height.
  8. Sep 5, 2020 at 2:43 PM
    #188
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Compared to the AJT, it appeared to be a little bit down, and it isn't centered with the pillar it mounts on. Although that was just eyeballing them off the truck. I have a feeling it was more about the thickness of the front plate. I'd highly recommend the Jomax for anyone modifying the truck in any way. I've been having TSS issues since day one of having the truck, and haven't had a single issue with it since putting on the Jomax.
    None of the TRD pro grilles come with bracketry. The 2014-17 pro grilles don't come with anywhere to mount the sensor. The 2019+ ones have a spot for it, but you need to buy the cover: https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
  9. Sep 5, 2020 at 2:46 PM
    #189
    AggiePhil
    College Station, TX
    Roger that. Looking at the new style TRD Pro grille only. I take it the Jomax/AJT brackets are only for the older style grilles?
  10. Sep 5, 2020 at 2:49 PM
    #190
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Did you mean older style grilles? Yes, they are for grilles without TSS sensor mounting locations. However I would recommend the Jomax to anyone having issues after lifting their truck, no matter what grille they're running.
    AggiePhil[QUOTED] likes this.
  11. Sep 5, 2020 at 2:51 PM
    #191
    AggiePhil
    College Station, TX
    Will I have issues if I switch from a 2020 Platinum grille to a 2020 TRD Pro grille? Truck is a stock height Platinum.
  12. Sep 5, 2020 at 2:52 PM
    #192
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Most likely not, but you may want to ask someone who has done that particular swap
  13. Sep 7, 2020 at 3:00 AM
    #193
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    My AJT bracket was working about 50%. I had my machinist buddy flycut the front sensor cover, reducing thickness in half. Now it works 100%
    100LL likes this.
  14. Sep 15, 2020 at 9:18 PM
    #194
    BMET
    BMET New Member
    2018 Tundra Limited
    Still working without problems?
  15. Sep 16, 2020 at 8:20 AM
    #195
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Its about 95% working, has some intermittant outages, but corrects itself promptly
  16. Sep 16, 2020 at 9:03 AM
    #196
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    I've heard disconnecting the battery overnight has helped some people with intermittent issues, have you done that yet?
  17. Sep 16, 2020 at 9:06 AM
    #197
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Quick update: Two weeks and 500 miles later, not a single TSS issue after replacing the AJT with the Jomax. This is the longest I've gone without an issue since buying the truck!
    shawn474 likes this.
  18. Sep 16, 2020 at 9:11 AM
    #198
    AggiePhil
    College Station, TX
    Don't you have the old style TRD PRO grill though?
  19. Sep 18, 2020 at 11:31 AM
    #199
    Tundrafan23
    Tundrafan23 New Member
    This is simply not true! There are videos on youtube by TOYOTA dealers showing how they recalibrate TSS on lifted trucks.
    https://www.youtube.com/watch?v=4vIRmKnyyB8
    Pillslinger, silverhack[OP] and 100LL like this.
  20. Sep 18, 2020 at 11:41 AM
    #200
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    That's really good info. My errors just came back an hour ago after 3 weeks and 600 miles. Once I finish putting armor and camper shell on, I'll be bringing it in for a re-cal. Hope they don't charge out the ass for it.
  21. Sep 18, 2020 at 11:57 AM
    #201
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    They will......they quoted me $700 to do it...…..I eventually pulled the trump card (my buddy is a GSM at a dealership) and his dealership did it for $195. Still a buttload, but much less than $700. I was fine paying since it was my issue by replacing the grill.
  22. Sep 18, 2020 at 12:02 PM
    #202
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    I had a feeling it would be around there. Fuck, maybe I'll just disable TSS with the t3chstream I just got.
    AggiePhil likes this.
  23. Sep 18, 2020 at 1:43 PM
    #203
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That was one of the dumbest videos I've seen. Absolutely no mention on how they perform the alignment. Toyota does not have a procedure for aligning a lifted truck. The target that the "Mr. Butters" held up is one for aligning the camera and has nothing to do with the radar. I've mentioned it before that in the instructions to realign the sensors targets are set out at an exact height for a stock truck height. When you lift the truck the target heights are no longer relevant. If they are compensating for the lifted truck by raising the sensors the same amount you may be able to get the alignment done but this would be going against Toyota's instructions and would be a huge liability for the dealer if a customer sued after an accident.
  24. Sep 18, 2020 at 2:16 PM
    #204
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Original post edited
    Found a solution to my problem
  25. Sep 18, 2020 at 2:28 PM
    #205
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    OK, honest question for both of you, are either of you a current mechanic at a Toyota dealership?
    If not, can we please get a Toyota dealership mechanic to chime in on this?
  26. Sep 18, 2020 at 2:55 PM
    #206
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check the "ask the mechanic thread" for my posts and info.
    Just retired Pro Tech.
    100LL[QUOTED] likes this.
  27. Sep 18, 2020 at 5:35 PM
    #207
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Not trying to start a debate here, but if you're retired, how do you know they haven't added a new revision to the manual, with procedures for lifted trucks? Do you still have access to current manuals?
    Fuck, I wish auto manufacturers weren't so greedy in hoarding maintenance info. I'm an aircraft mechanic and see the same shit. Some subscriptions run in the multiple thousands of dollars per year to access. Meanwhile, Robinson helicopter puts all their literature online for everyone to see. Wish more people would follow in their path.
  28. Sep 18, 2020 at 6:08 PM
    #208
    AggiePhil
    College Station, TX
    Surely someone has a Full Service Manual for our trucks. I know when I had a Dodge Ram (years ago), they were available for download if you knew someone who had one.
  29. Sep 18, 2020 at 8:02 PM
    #209
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ive been retired for two weeks.
  30. Sep 19, 2020 at 11:54 AM
    #210
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    haha, ok that makes sense. Congratulations!
    Ruggybuggy[QUOTED] likes this.
