Rocks cutting into Nitto Ridge Grapplers??
Discussion in 'Wheels & Tires' started by Caveman, Sep 17, 2020.
  1. Sep 17, 2020 at 9:08 PM
    Caveman
    Caveman [OP] New Member
    Just out of curiosity is anyone having issues with rocks cutting their Grapplers??
    I do a good about of fire roads and unmaintained forest paths, but most are hard pack with tons of rocks the size of your head.
    Last week I noticed when rotating my tires that I had a 2" plus cut in the tread base ( bottom) of my tread and tons of tiny sharp flat rocks all the way into my tread. My local the shop said it should not happen and replaced the one with the 2" cut.
    Are these normally very soft tires that get demolished by hard pack rocky trails?
    Normally I run 37 psi on all four for the road and drop to 28 psi on trails.
    I was thinking I could go way lower on trails from seeing other posts but wanted to play it safe.
    This pic from the web looks close but I'm usually playing in a dryer environment. Just rocky like this.
  2. Sep 18, 2020 at 7:28 AM
    Caveman
    In looked on my phone and can't find the pictures. Ill keep looking for the cut tire pictures
  3. Sep 18, 2020 at 8:02 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yes, have seen that. There was just a post this past week here about a members RGs being cut up a good bit, I believe one needed replacement.
  4. Sep 18, 2020 at 9:45 AM
    Caveman
    Interesting I'll continue to search for that thread. I'm not looking to buy another set of tires though....
