Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Jun 23, 2020 at 12:01 PM
    #271
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Jp-ProMamba[QUOTED] likes this.
  2. Jun 23, 2020 at 7:12 PM
    #272
    Xr0ckstar
    Xr0ckstar New Member
    2020 quicksand
    Is your truck stock height ? Is the 2020 Pro higher than a 2020 sr5 off road stock vs stock ?
    Farmbeavs likes this.
  3. Jun 24, 2020 at 8:48 AM
    #273
    Jp-ProMamba
    Jp-ProMamba New Member
    Jp
    2020 Toyota Tundra Trd Pro
    To my understand the Trd Pro comes 2” higher than stock suspension. The only thing I did to fit the tires was remove the front mud guards.
  4. Jun 24, 2020 at 1:55 PM
    #274
    Wyoming
    Pro is leveled, so it'll be 2 inches taller up front. Rear stays the same.
  5. Aug 18, 2020 at 6:31 AM
    #275
    Jp-ProMamba
    Jp
  6. Aug 18, 2020 at 6:59 AM
    #276
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    So I didn't see much information on this size lift combo... I'm running 6112s on 1.3. Will lt285/70/18 work with the stock trd wheels? Looking at the ko2s or possibly wildpeaks
    I think I definitely need to go taller then stock bc of the bilsteins make my tires look tiny now...just dont want a lot of sling on the side of truck if the tires are too wide as well..thx
  7. Aug 31, 2020 at 9:00 PM
    #277
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    I WOULD LOVE TO SEE SOME ADDITIONAL PICTURES ON THIS FORUM WITH BOTH THESE two SET-Ups as mentioned from the first page....
    3″ Lift Kit
    With a 3″ lift kit, the options continue to get better. However, the wider the tire, the greater the likelihood of trimming.
    Max tire sizes are:
    • 18″ rims: 285/75 R18 – 4/10ths wider and 2.8″ taller than factory.
    • 18″ rims: 305/70 R18 – 1.2 inches wider and 2.8″ taller than factory. There are Tundra owners running this size, but trimming is required. Replacing the stock wheels withafter-market 18′s that have lessbackspacing is recommended.
    Geodude82 likes this.
  8. Sep 7, 2020 at 6:45 AM
    #278
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    I have a stupid question that's not really related to how large I can run but I'm not really sure where to post it.
    I'm looking to get myself some winter tires and rims. Looking at the following 3 sizes, in addition to stock, which is 275/65R18.
    255/75R17
    255/70R18
    275/70R17
    From searching here, seems like some others have run each of these sizes but can anyone confirm if they'll fit? No issues with clearing the brakes, for example, with any of the 17" rims? Thanks.
  9. Sep 17, 2020 at 8:24 AM
    #279
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    I see plenty of threads about the largest tires you CAN run, but have done some searches, but not found info about whether you SHOULD get the largest tires possible for your setup.
    Say you are totally stock and go to the biggest tire that wont rub. What are the performance implications? It seems like even if you don't rub on level ground, if you start doing anything that loads up the suspension, you risk the tires hitting the wheel wells through bumps, etc.
    Trying to get an idea of the performance impact, and whether you should do it.
  10. Sep 17, 2020 at 8:37 AM
    #280
    I have 285/70/18's on a 0 offset on my 2013 with a 3 inch lift. Does anyone know if they will fit on a stock 2020 SR5 until I get my lift moved over?
  11. Sep 17, 2020 at 8:42 AM
    #281
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Moving to a bigger tire on a Tundra usually means moving to an E load tire. That is because there are few tires in standard load in sizes that fit our trucks (larger than stock that is). E load tires are heavier and larger tires reduce your overall gearing- the result: you will take a MPG hit- expect a drop of 1-2 MPG and depending on the size and weight, the truck may feel like it has slightly less power. As far as what fits stock without any mods- a 33 inch tire will fit depending on how wide it is, like a 275/70-18 for example.
    LaaMahTundra likes this.
  12. Sep 17, 2020 at 9:05 AM
    #282
    DVCNick
    DVCNick New Member
    Thanks (kind of sucks about the MPG hit)
    What about suspension travel though? I would think you still risk hitting the wheel wells a lot even if it doesn't rub unloaded on level ground?
    I found a set of 20's local on craigslist for pretty cheap that I'm hopefully going to get today. I was thinking of keeping stock size street-only tires on those, and then getting something bigger/AT for the 18's, to swap on if I'm going to be doing something where more grip would help.
    Suspension is absolutely stock right now, though I may be interested in leveling the front sometime. Would probably stop there.
  13. Sep 17, 2020 at 9:30 AM
    #283
    frichco228
    Frank
    Virginia
    I have stock suspension (2016) and run 275/70-18 which are 33 inch tires vs the stock 32 inchers. No issues at all in any conditions.
  14. Sep 17, 2020 at 10:46 AM
    #284
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    All those tires you listed will fit on stock suspension. As far as the 17" rim size question, you need to look at specific rims designed for the Tundra which will clear the calipers. I have 17" Icons. I believe there are Methods that also fit into this category but of course offset will always be in the equation as well.
  15. Oct 4, 2020 at 8:04 AM
    #285
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Hello.... just read through this few pages. All in all very interesting setups and a lot of useful info.
    I would appreciate any feedback on my upgrades. I am trying to make up my mind on lift kit, rims and tires.
    For rims, Im very much towards the Fuel Beast 20x9 with 1mm offset, having the Fuel assaults as a second option.
    For tires, maybe a set of Nitto Terra Glapplers G2. 305/50. Its a 12” wide and a 32” high with a 6” wall.
    For suspension I was thinking of the Bilstein 6112 for the front and 5110 for the rear, BDS or Total Chaos UCA and a 1” shackle or the BDS Kit with fox shocks, BDS UCA and shackles.
    About the past few pages....
    Im my opinion there are two misconception on spacers. People are saying that they dangerous. Any mod done to any suspension on any vehicle is dangerous when not using high quality parts and poor installation. Most if not all vehicles are design so everything works at the highest performance and reliability possible. We like to mod everything. That being said, it will come with a draw back. Bigger tires means less mpg, trim chassis, remove plastic parts, noise, etc. .
    Spacers are not a exemption. Buy cheap spacers with non graded bolts and nuts and people will will end up saying they are dangerous. Buy cheap Chineese wheels.....they brake. Buy cheap tires....they don't last, explode or wont balance. Buy cheap coilovers and they will brake or bend. I don't think spacers are dangerous. Its all about quality and installation.
    Another opinion that I read was that spacers are the solution if bigger tires rub...WRONG. Things will get worst. With a spacer, all you are doing is bringing the wheel away from the car. This will make the wheel travel on a bigger and more outer circle, which will make the wheel closer to the front. Its just geometry, but trust me it will get worst. The only reason to use spacers is when the tire is rubbing on the UPC or for looks. If your tire is rubbing the chassis or the fender when turning, a spacer will not help solve the issue.
    Hope my 2 cents help and again I will appreciate any input on my mod.
    LaaMahTundra and the ER kid like this.
  16. Oct 26, 2020 at 8:35 AM
    #286
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I have read and researched a ton, looked at pics and still need some reassurance before I drop almost $3k canadian for rims and tires
    Stock 2019 SR5, no lift
    I want to go the following rim:
    18x9.5 with +12 offset
    Tires will be 285/65/18. 285 due to rim size as the 275s I've looked say they aren't compatible with a 9.5" rim.
    Aside from removing stupid front mid flap, I'm hoping I don't run into any issues. Can't get a lift right now due to parking etc
    The below talks about tire and rim size but not going from stock 8" rim to 9.5", but maybe that is because it doesn't matter?
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
  17. Oct 26, 2020 at 11:33 AM
    #287
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    I'm running a 18x9.5 +25 wheel with Toyo 285/65/18s and only had to remove the tiny flap behind the front bumper.
  18. Oct 26, 2020 at 11:41 AM
    #288
    BravoDeltaRomeo
    Bruce
    MB Canada
    Awesome. That is reassuring to say the least.
  19. Nov 26, 2020 at 5:15 AM
    #289
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Do you think you could've gone with a bigger tire if you had a bumper shim or did more rolling or trimming to the fender?
  20. Nov 26, 2020 at 6:16 AM
    #290
    biebs96
    PA
    Hopefully this helps..
    Leveled up front with 5100s (not the full 3 inches you are requesting)
    285/75/18 on stock wheels with no spacers.
    Truck was dead level and tires fit with no rubbing aside from removing the front tiny mudflap.
    I did trim the wings off the skid plate because they were close (not rubbing) but I wanted the peace of mind.
    Adding a 1” rear lift gave me back the rake I wanted for when I needed to haul something without sagging.
    French Avocado and equin like this.
  21. Dec 13, 2020 at 7:24 PM
    #291
    Bebop
    Bebop New Member
    I just bought a trd 4x4 gen 3 with 18” wheels. Will be doing the ready lift 3/1 leveling. What’s the tallest tire I can run without tearing into anything?
  22. Dec 14, 2020 at 9:07 AM
    #292
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    Sssseeeeeaaaaaarrrrrrcccchhhh. Or even read the first post in this thread
  23. Dec 21, 2020 at 7:18 PM
    #293
    ThundaTundra4
    ThundaTundra4 New Member
    2021 Tundra Limited
    Wow. They look great. I just bought the 2021 nightshade crew max in wind chill pearl (white). The only thing I don’t like is the lower profile Stock 275/55/20 tired. Based on your post I’ll bump up to the 275/60/20 and put the KOs on (had these tires on my 2014. Love them).
    Green Thunder likes this.
  24. Dec 21, 2020 at 8:11 PM
    #294
    gdisarray
    gdisarray Short term member
    MGM SR5 TSS
    I want to go as big as I can on my 2019 TSS. Local 4 Wheel Parts told me that most tires in the size on my truck (275/55-20) lack a lot of tread depth because they are specked for OEM replacements. He said his Toyo Open Country AT2 as well Nitto Grabbers will have a lot less tread depth that size tire than other tires in the respective lineups. They don't look as beefy either.
  25. Dec 23, 2020 at 11:34 AM
    #295
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    What parts did you use for this? Looks very nice. Diff drop? Rear parts? Setting in 5100’s?
    biebs96[QUOTED] likes this.
  26. Dec 23, 2020 at 11:35 AM
    #296
    biebs96
    PA
    bilstein 5100 on the middle setting, 1” block in the rear.
    no diff drop and no wheel spacers.
    BravoDeltaRomeo likes this.
  27. Jan 4, 2021 at 11:30 AM
    #297
    sludgepickle
    sludgepickle New Member
    San Diego
    2018 Silver SR5 DC 4x4
    In the OP it says you can run this:
    But it only gives you the 285 max...it doesn't give you the max 275 tire...would that be 275/70?
  28. Jan 4, 2021 at 11:47 AM
    #298
    War Machine
    War Machine SSEM # 5 3MW
    Went with 295/55/20 on mine.
  29. Jan 4, 2021 at 1:31 PM
    #299
    ThundaTundra4
    2021 Tundra Limited
    Sweet. Love it. Did you need to do any modifications?
  30. Jan 4, 2021 at 1:41 PM
    #300
    War Machine
    Had to remove front mudflaps and spats. Also trimmed the front splash guard a little, but could’ve just heated them up and pushed them forward. (Miscommunication with the guy who put the tires on.)
