Shaky at 55 mph
Discussion in '1st Gen Tundras (2000-2006)' started by ehshea5, Sep 15, 2020.
  1. Sep 15, 2020 at 6:56 PM
    ehshea5
    ehshea5 [OP] New Member
    Eric
    03 Black Limited
    Looking for help! Truck gets shaky at 55 mph but goes away once I get over 60. Had tires balanced and alignment done but no change. Any ideas?
    theblurry1 likes this.
  2. Sep 15, 2020 at 7:03 PM
    Welcome from NY.
    Did you try road forced balancing?
    What tires are you running?
    abcinv and ehshea5[OP] like this.
  3. Sep 15, 2020 at 7:06 PM
    ehshea5
    Eric
    03 Black Limited
    No road force balance, running AT 265/70 on 17's. Had the same issue with a 2001 4 runner that never got taken care of.....
  4. Sep 15, 2020 at 7:11 PM
    What brand?
    There are plenty of threads about BF Goodrich having these issues.
    ehshea5[OP] likes this.
  5. Sep 15, 2020 at 7:14 PM
    ehshea5
    Eric
    03 Black Limited
    Hankook Dynapro AT2
  6. Sep 15, 2020 at 7:26 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Universal joint or center carrier bearing?
  7. Sep 15, 2020 at 7:42 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Might be what SouthWestGA said, my truck had a vibration around 55mph, changed out the carrier bearing and all was good. I say all was good because I bought a dorman carrier bearing :facepalm: and it started to squeal around 1,000 miles later. Buy the Spicer CB if you decide to go that route.
    ehshea5[OP], Pucks18 and bmf4069 like this.
  8. Sep 15, 2020 at 7:59 PM
    X3, that was my next thought.
  9. Sep 16, 2020 at 5:23 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Steering rack bushings, LCA bushings, warped rotors, out of balance tires, etc.
    Just a check list.
  10. Sep 16, 2020 at 6:34 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    It's gonna be the tires 80% of the time. Some equipment, or rather the tech using it, doesn't do a great job of balancing the tires. Worn suspension or steering components may exaggerate the vibration, but rarely cause it. Good luck. and +2 on the road force balancing.
  11. Sep 16, 2020 at 6:44 AM
    shifty` Our private little trip to hell
    Most common source of vibration on vehicles comes from things which are spinning. Two big things that spin are the wheels & tires and the driveline.
    If you know without a doubt it's not the wheels & tires, you should inspect the driveline. Visually look at the drive shaft, u-joints, carrier bearings. I suspect it'll be the carrier bearing is worn out, but I'm not a betting man.
  12. Sep 16, 2020 at 7:00 AM
    55mph vibration is classic for an unbalanced wheel. Also, I've had 2 sets of Hankook Dynapro AT2's. I like the tire, but the first set failed on me at 55k miles. I thought that was a good run for a tire, but an odd fail. I'm assuming the belts in the tread area began to separate. Not sure if it was from a road hazard, or just began delaminating inside. I noticed it while trying to rotate the tires to get rid of the vibrations I was experiencing at 55mph, which were getting severe.
    Note the giant hump in the outer third of the tread. Decent tread left for 55k though! inspired me to buy another set. Should have gotten some Wildpeaks...
    My dad with his knee pads for the win!
    Darkness and ehshea5[OP] like this.
  13. Sep 16, 2020 at 11:44 AM
    Fred
    Hand Protectors
    Meant to say out of round tires earlier.
    These ‘off road’ tires are the worst offenders.
    Lots to check before narrowing it down to tires. Our trucks age has the front ends worn out and tired.
  14. Sep 16, 2020 at 2:45 PM
    ehshea5
    Eric
    03 Black Limited
    I appreciate the help. I am going to start with getting the tires balanced at a different shop. The tires are brand new and hopefully the crew that put them on did a crappy job. It has a new alignment done by a decent tech and he checked the front end stuff for wear.
  15. Sep 16, 2020 at 3:40 PM
    Medicineman
    Medicineman The Dark Side has better toys!
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LEDs, Bushwacker Flares, Line-X, Leer Cap, Yak Rack
    Had a similar issue when I put new set of BFG AT on my truck. Road Force Balance took care of it.
    ehshea5[OP] and abcinv like this.
  16. Sep 16, 2020 at 4:02 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Same here
    Two balances didn't correct it but one Road Force balance did
    I'm on K02's BTW
  17. Sep 16, 2020 at 5:47 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Start with least expensive and work your way up.
    #1 - road force balance
  18. Sep 16, 2020 at 7:03 PM
    ehshea5
    Eric
    03 Black Limited
    I keep seeing the road force balance as a recommendation so I will try that asap and post the results.
    bmf4069 and Hightide like this.
  19. Sep 16, 2020 at 7:08 PM
    :thumbsup:
  20. Sep 17, 2020 at 6:16 AM
    Fred
    Hand Protectors
    Observe your steering rack bushings. Crawl under while someone above turns the wheels. Looks for play at the 3 bushing points across the rack.
    Hope your cam bolts aren’t seized so that you can get a proper alignment. This happened to my truck which led to front end rebuild with New LCA bushings and cam bolts.
    Just throwing some stuff out there for you.
  21. Sep 19, 2020 at 6:19 PM
    ehshea5
    Eric
    03 Black Limited
    Road force balance did the trick! Appreciate all the input you guys are great!
  22. Sep 19, 2020 at 6:41 PM
    FirstGenVol Brake Czar
    2002 AC
  23. Sep 19, 2020 at 7:05 PM
    ehshea5
    Eric
    03 Black Limited
