2018 crewmax storage
Discussion in 'General Tundra Discussion' started by Rhernandez09, Aug 22, 2018.
  1. Nov 3, 2018 at 8:33 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Looks awesome, how about you make a set for your good old buddy silv333?
    Rhernandez09[OP] likes this.
  2. Nov 4, 2018 at 2:18 PM
    Rhernandez09
    Rhernandez09 [OP] New Member
    Roy
    2018 Black Tundra TSS
    The problem with that is that you would have to find a solution for the seat mounts they would get in the way a bit. I believe they travel the length of the seat.
    OR18TRD[QUOTED] likes this.
  3. Nov 6, 2018 at 4:49 AM
    Troubleshooter
    Troubleshooter New Member
    Sam
    2018 tundra limited
    Hello. Did this eliminate cutting holes in floor board?
  4. Nov 6, 2018 at 2:43 PM
    Rhernandez09
    Roy
    You still have to cut into the carpet and foam
  5. Nov 6, 2018 at 3:53 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Here is the setup that I did a while back:
    Drivers side is a 130pc tool kit, middle is a $10 tool organizer from home depot with random gear, top is a $7 Tupperware tote with my compressor and battery cables.
    WVI likes this.
  6. Apr 25, 2019 at 11:01 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Has anyone used the Sparks storage? How does it compare to ESP?
  7. Feb 17, 2020 at 10:28 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    Did you need to go 3 boards thick to fit the bins? Could a single board still work?
  8. Feb 17, 2020 at 11:00 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    If you can find a single board that’s 1.5” then yes, a single board will work. When I did mine, I glued two 3/4” pieces of plywood together (couldn’t find a 1.5” piece big enough to do the job).
    Tracker[QUOTED] likes this.
  9. Feb 17, 2020 at 11:02 PM
    Tracker
    Tracker New Member
    Shane
    Im ordering mine up, gonna save $$ over the esp. More money for other mods ;)
    Bob_Wiley[QUOTED] likes this.
  10. Feb 17, 2020 at 11:14 PM
    Bob_Wiley
    Eric
    AZ
    Good man. I don’t care for the ESP either, bins are too small. It’s not worth the money.
  11. Feb 18, 2020 at 5:30 AM
    joezamora
    joezamora New Member
    Joe
    2019 TRD Pro
    Do you know where I can get my hands on an already built tray to drop in?
  12. Feb 18, 2020 at 5:32 AM
    Tracker
    Tracker New Member
    Shane
    Depends if you are asking for a custom built one or the manufactured ESP storage system
  13. Feb 18, 2020 at 5:42 AM
    joezamora
    Joe
    2019 TRD Pro
    Something off the shelf....
  14. Feb 18, 2020 at 7:23 AM
    Rhernandez09
    Roy
    Going on a year and a half and so far and still happy with them. Don't really feel like I'm missing out on anything by buying a over the counter drop in. If you have the ability I would highly recommend doing it yourself. Save some cash.
    betotundra and LogCabins like this.
  15. Feb 18, 2020 at 10:10 AM
    joezamora
    Joe
    2019 TRD Pro
    Most definitely I’m pretty sure I can figure it out but I’m lazy
  16. May 14, 2020 at 6:46 PM
    Tracker
    Tracker New Member
    Shane
    How has this held up, Im about to break this project wide open
  17. May 16, 2020 at 6:41 PM
    Kanobi13
    Kanobi13 New Member
    WVI, betotundra, Skey44 and 1 other person like this.
  18. May 16, 2020 at 7:01 PM
    Rhernandez09
    Roy
    I did the same
  19. May 20, 2020 at 6:02 PM
    Tracker
    Tracker New Member
    Shane
    I got down n dirty with this. Actually went smooth so far and im a novice wood guy. Total cost about $50. I will cut the truck carpet tomorrow and wrap the wood in black carpet. Im going to Raptor spray the bins this weekend. I used some misc scrap wood I had to cut costs and made it work.
    WVI, Bob_Wiley and Rhernandez09[OP] like this.
  20. May 20, 2020 at 6:24 PM
    #50
    Kanobi13
    Kanobi13 New Member
    Looking good dont forget to cut the carpet to size to fit in bins
  21. May 21, 2020 at 9:31 PM
    #51
    Tracker
    Tracker New Member
    Shane
    Almost done, found out an initial razor blade cut then chiseling to the floor board made a very clean job. The first box wasnt as clean but the other two were perfect. My daughter helped get the job done. Now if the Post office goes back to work I can get my raptor liner to spray the pans.
    WVI, Bob_Wiley and betotundra like this.
  22. Sep 15, 2020 at 4:55 PM
    #52
    betotundra
    betotundra Toyota for Life
    Hi, did you use full size pans for the middle and left compartments? If so, why not in the right one also? Thanks in advance.
  23. Sep 15, 2020 at 5:02 PM
    #53
    Rhernandez09
    Roy
    The pan sizes are posted in a previous comment you have to use a smaller one on the far side cause of the tire jack. Looks like Kanobi13 used bigger pans then mine. The seat brackets are also not all evenly spaced
    khunk likes this.
  24. Sep 15, 2020 at 5:51 PM
    #54
    Kanobi13
    Kanobi13 New Member
    You got it.
  25. Sep 16, 2020 at 3:26 PM
    #55
    betotundra
    Thanks OP, I noticed YOUR pan sizes, I was actually wondering which sizes did @Kanobi13 use.
  26. Jan 3, 2022 at 3:30 PM
    #56
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Snohomish Co, WA
    2018 SR5 X Series Tundra
    so question - does the Toyota under seat tray not fit in the 2018s? There's that slight gap between the rise in the floor and bottom of the back seats, and I just don't see how the OE tray would fit (although I like this solution).
  27. Jan 3, 2022 at 3:39 PM
    #57
    mountainpete
    mountainpete Explore more
    Function before sparkle.
    There is no such thing as a Toyota OEM under seat tray for a 2018 Crewmax. Toyota only made under rear seat storage for the double cab.
  28. Jan 3, 2022 at 3:44 PM
    #58
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Snohomish Co, WA
    ahhh - yes, I see that now (was in the small print on the TP site - the direct Toyota site was much more clear). Thanks!! I will definitely be following this solution
    mountainpete[QUOTED] likes this.
