Any PRO owners running 275/70/18 with a shackle/shim lift?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Maple85, Aug 22, 2020.
  1. Aug 22, 2020 at 6:52 AM
    Maple85
    Maple85 [OP] New Member
    Getting a new PRO and really want to put KO2s on it with a small lift. Thinking 1inch shim and CB 1.25 shackle. The KO2 sizing is not great. Basically jumps from 275/70/18 up to a 35 inch tire. Curious if the 275/70/18 KO2 with that small lift will look too small. I know it looks good at PRO stock height but raising the truck an extra inch might make them look small. Thoughts?
  2. Aug 22, 2020 at 7:10 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Pro is already higher than a standard Tundra by 2 inch in front. 275/70 fit stock on a standard tundra, no need for lift. I think it would leave the suspension alone and rock the tires that you want. And you can go larger than the 275/70s.
    For reference, here is my SR5 with that size, stock suspension.
  3. Aug 25, 2020 at 8:07 AM
    jfisher256
    jfisher256 New Member
    Huntsville, AL
    2019 Super White Tundra TRD Pro
    I have the 275/70/18 K02s and am in the exact same boat. Currently running at stock and have been trying to decide what CB setup to go with. Any suggestions would be appreciated. Pics are stock setup with 275 K02s.
    Y0TA PR0, Maple85[OP] and ryanwgregg like this.
  4. Aug 25, 2020 at 9:58 AM
    Maple85
    I emailed BFG yesterday and they said they will start production of a 295/70/18 KO2 in October. Sweet! Problem solved.
    trd.james, PermaFrostTRD and Hbjeff like this.
  5. Aug 28, 2020 at 8:14 AM
    NLTRDPro
    NLTRDPro New Member
    Robert
    2019 TRD Pro CM
    My TRD Pro is in the shop now getting the shims and +2 shackles installed with the KO2s 275/70/18. Will post pics when I get her back today. What is everyone running for PSI in the KO2s.
    Maple85[OP] likes this.
  6. Aug 28, 2020 at 12:53 PM
    BurgEER
    BurgEER New Member
    2019 TRD Pro
    You should do the 35x12.5 and get it over with. I’ve had 295/70 on my pro since I got it with no extra lift. Also debating my CB/westcott lift setup but going to 35x12.5 on stock pro wheels regardless
    trd.james likes this.
  7. Sep 1, 2020 at 6:07 AM
    Maple85
    How did it turn out? Got pics?
  8. Sep 1, 2020 at 6:17 AM
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    I did Westcott up front and +2 CB shackles in the rear to put 35x12.50 KO2's on the stock wheels, no wheel spacers.
  9. Sep 15, 2020 at 9:29 AM
    NLTRDPro
    NLTRDPro New Member
    Robert
    2019 TRD Pro CM
    Turned out awesome! Will get better photos as I done a complete paint correction, sealant, and wax.
    2019-1794, Huckwheat and Maple85[OP] like this.
  10. Oct 16, 2020 at 6:38 AM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    What all did you use on this Coachbuilder setup? Just the 1” shims and the +2 shackles? Or did you buy the complete pro kit?
  11. Oct 16, 2020 at 7:10 AM
    NLTRDPro
    NLTRDPro New Member
    Robert
    2019 TRD Pro CM
    Its only the shims and +2 shackles.
  12. Oct 16, 2020 at 7:13 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Just get duratracs in a 295/70. KO2's are the most overrated tire out, although that's just my opinion.
  13. Oct 28, 2020 at 9:09 PM
    Bsincs2k
    Bsincs2k New Member
    Kansas
    2019 Voodoo Blue TRD Pro
    On some Ridge Grapplers with spidertraxx spacers.
    cp44 and Maple85[OP] like this.
  14. Oct 28, 2020 at 9:11 PM
    Bsincs2k
    Bsincs2k New Member
    Kansas
    Another shot. I have some +3 CB shackles I still need to throw on.
    cp44 likes this.
  15. Oct 28, 2020 at 9:14 PM
    Maple85
    What size spacers? They seem to make that tire size pop and appear slightly bigger. Looks great!
  16. Oct 28, 2020 at 9:18 PM
    Txmgm
    Txmgm New Member
    2017 mgm crewmax tss sr5 4x4
    Mgm vinyl wrap chrome delete Trd shit knob Fortin evo remote start Full tacotunes sys 1 plus sound deadening Trd pro grill Wireless charging mod
    Nice teg back there. I never had a type r but loved the 2 gs ones i did own.
  17. Oct 28, 2020 at 9:20 PM
    Bsincs2k
    Bsincs2k New Member
    Kansas
    Maple85[QUOTED][OP] likes this.
  18. Oct 28, 2020 at 9:21 PM
    Bsincs2k
    Bsincs2k New Member
    Kansas
    Appreciate it brother. Had it for damn near two decades and been neglecting it. Now I’m paying for it because all the little shit I need to replace costs an arm and a leg because they’re discontinued. Lol.
  19. Nov 13, 2020 at 9:45 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Great looking ride! What are your impressions of the Westcott lift. How does the ride compare to stock?
