Vinyl TRD Wheel decals installed.
Discussion in '2.5 Gen Tundras (2014-2021)' started by mambo143, Sep 13, 2020.
  1. Sep 13, 2020 at 7:22 PM
    mambo143
    mambo143 [OP] New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Installed gloss black wheel decals on the OEM wheels. I am happy with the results and so is my wallet.
  2. Sep 13, 2020 at 7:33 PM
    :thumbsup:
    mambo143[QUOTED][OP] likes this.
  3. Sep 13, 2020 at 7:41 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Nice looks good
  4. Sep 13, 2020 at 7:44 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Looks good.
    mambo143[OP] likes this.
  5. Sep 13, 2020 at 7:45 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    That looks good dude
  6. Sep 13, 2020 at 9:20 PM
    AZTundra
    Paul
    Phoenix, AZ
  7. Sep 14, 2020 at 4:37 AM
    berto40
    berto40 Always a noob.
    Looks nice!
  8. Sep 14, 2020 at 5:21 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I like that a lot! Where did you get the decals? how hard are they to apply?
    mambo143[OP] and Airn890 like this.
  9. Sep 14, 2020 at 9:22 AM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    That came out really good
  10. Sep 14, 2020 at 9:24 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I had no idea these existed. Makes me want to pick up a TRD OR wheel so I can have a matching spare. Where did you get these?
  11. Sep 14, 2020 at 9:26 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    @dblizzo
    I haven't installed mine but this guy did.
  12. Sep 14, 2020 at 9:27 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Looks sick. I need to make time to install mine.
    Got any tips ?
  13. Sep 14, 2020 at 11:01 AM
    mambo143
    Phil
    Maine
    I posted a couple of how-to responses in the post but not sure if you can see them? Seems when I scroll up in some responses I see it, but in yours I don’t. I can repost them if you can’t see it. There are some good vids on YouTube specific to the esty and a taco wheel.
    Ted4311[QUOTED] likes this.
  14. Sep 14, 2020 at 11:15 AM
    mambo143
    Phil
    Maine
  15. Sep 14, 2020 at 1:46 PM
    mambo143
    Phil
    Maine
  16. Sep 14, 2020 at 6:48 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Wish they made these for the limited 20"s.
  17. Sep 22, 2020 at 7:12 AM
    Durania
    Durania New Member
    Crossville, TN
    So, how hard were these to install? I picked up a set of offroad wheels yesterday and remembered this thread.
  18. Sep 22, 2020 at 8:08 AM
    mambo143
    Phil
    Maine
    Not so bad. You should read the instructions and then watch the You Tube video of the installation process. Remove the wheels from the truck and lay on a flat bench or surface for ease of installation. The process is a bit painstaking but relatively easy. Take your time and use the same method for each decal because your technique will improve with each installation. Make use to use ample rapid tac on the wheel and decal to buy you some time to move the decal into position. Use a piece of painters tape to peel the decal off and apply the rapid tac as you do this.
    I started at the right bottom of the spoke decals and lay them in place before applying any pressure.
    Use a small fabric squeegee and clean microfiber cloth on the first pass. (I used my fibers a lot to press in place.
    The vinyl stretches and adheres well. It also folds over a black operation of the TRD wheel slightly. ( wash the surface with alcohol before you begin the process to remove any residue to promote adhesion. Hair dryer is the last step to remove moisture. The decal could withstand quite a bit of pressure and rubbing to remove small imperfections. I had not tearing whatsoever.
    The vid will walk you through what it looks like. The results are very good. It’s a complete transformation. I got the gloss and the wheels look awesome. Even covered some wheel rash on one wheel. They come with an extra set so you can make mistakes. (I removed 1 because the decal stuck to itself... lesson is the Rapid Tas is your friend)
    Let it sit for a day if you can before washing etc.
    Have had them on for a couple of weeks and so far they look perfect. Best bang for the buck for 50$ mod.
    Good luck!!!
    Durania[QUOTED] likes this.
  19. Jun 4, 2021 at 12:31 PM
    kylers2k
    kylers2k New Member
    KWS
    Troutman, North Carolina
    Anyone know where to get these still?
  20. Jun 4, 2021 at 12:37 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    I got my from TVD Vinyl but it looks like they are currently sold out. Maybe email them and see when they will be back in stock?
    15whtrd, RobertD and kylers2k like this.
  21. Jun 4, 2021 at 1:09 PM
    kylers2k
    kylers2k New Member
    KWS
    I messaged them on Etsy. I’ll try an email too. Thanks
  22. Jun 4, 2021 at 1:34 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Looks great!
  23. Jun 4, 2021 at 8:08 PM
    Durania
    Durania New Member
    Crossville, TN
  24. Jun 4, 2021 at 8:20 PM
    kylers2k
    kylers2k New Member
    KWS
    Looks awesome. Another member sent me a PM with a spare set they had so I picked those up. Can’t wait to mount my new 35s and put the decals on.
    TunBrun, HARPER306 and Hbjeff like this.
  25. Jun 5, 2021 at 7:21 AM
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I did mine over a year ago, and I’m happy to report that they are holding up very well! They still look good-as-new
  26. Jun 5, 2021 at 7:54 AM
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    Definitely a cool inexpensive mod. I’d asked about these a few months ago but didn’t get a response. I thought about trying the bronze.
  27. Jun 5, 2021 at 8:00 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I have the Bronze on my TRD OR wheels and they look great. They’ve held up well too but I did just tear some of them on one wheel I got a bit careless with a power washer the other day so totally my fault.
    MAN N BLK[QUOTED] and 300BLK like this.
  28. Jun 5, 2021 at 9:46 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
  29. Jun 5, 2021 at 10:24 AM
    kylers2k
    kylers2k New Member
    KWS
  30. Jun 5, 2021 at 6:41 PM
    Durania
    Durania New Member
    Crossville, TN
    Yes, pull the Toyota emblem centers off, snap these back in.
    81 TOY[QUOTED] and kylers2k like this.
