Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. Aug 28, 2020 at 1:32 AM
    #151
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Stock transmission internals with an IPT valve body. Stock 4.30 diffs (I’m AWD, so each diff gets about half the total torque). I have a powertrax grip pro lsd on the way for the rear.
    dorton and Mountun Goat like this.
  2. Aug 28, 2020 at 12:42 PM
    #152
    forrestgump8326
    forrestgump8326 New Member
    2007 Toyota Tundra SR5 Crewmax 5.7 S/C
    TRD Supercharged
    Very cool. John is building me a 2wd transmission. What led you to the Powertrax setup? I've been weighing my options, kinda leaning towards the Auburn Pro series.
    dorton likes this.
  3. Aug 28, 2020 at 10:02 PM
    #153
    ViktorG
    Viktor
    Calgary, Canada
    Auburn uses clutches and they are known to wear out quickly, especially on high power trucks.
    Some guys have blown up 3 auburns in a few years.
    Grip pro is a gear lsd, no wear parts.
  4. Aug 29, 2020 at 1:36 PM
    #154
    forrestgump8326
    TRD Supercharged
    Interesting. I have a bit more research to do, but will have made a decision within a week.
    ViktorG[OP] likes this.
  5. Sep 6, 2020 at 12:35 AM
    #155
    ViktorG
    Viktor
    Calgary, Canada
    Best time to date!
  6. Sep 6, 2020 at 5:36 AM
    #156
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Impressive!
  7. Sep 6, 2020 at 11:56 AM
    #157
    ViktorG
    Viktor
    Calgary, Canada
    Thank you :)
    Toyotoholic[QUOTED] likes this.
  8. Sep 6, 2020 at 2:59 PM
    #158
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    When are you going to hook up the spray?
  9. Sep 6, 2020 at 5:03 PM
    #159
    ViktorG
    Viktor
    Calgary, Canada
    11.7 was with a 75 shot.
    Black@Blue19 and AZBoatHauler like this.
  10. Sep 6, 2020 at 9:10 PM
    #160
    Danimal86
    Daniel
    Sacramento, CA
    What, no video on the spray setup?!?! Or did I miss it?
  11. Sep 6, 2020 at 10:36 PM
    #161
    ViktorG
    Viktor
    Calgary, Canada
    Lol
    I got a couple YouTube videos up on my previous 200 hp 8 nozzle direct port nitrous setup on the TRD blower.
    This is just a single wet fogger in the intake pipe between the MAF and the TB, nothing exciting.
  12. Sep 13, 2020 at 12:47 AM
    #162
    ViktorG
    Viktor
    Calgary, Canada
  13. Sep 13, 2020 at 1:49 AM
    #163
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Beast!
    ViktorG[QUOTED][OP] likes this.
  14. Sep 13, 2020 at 6:20 AM
    #164
    That's sweet.
  15. Sep 13, 2020 at 6:32 AM
    #165
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Viktor all giddy, lol! Well done sir! :bananadance:
  16. Sep 13, 2020 at 7:27 AM
    #166
    forrestgump8326
    TRD Supercharged
  17. Oct 7, 2020 at 11:12 AM
    #167
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Do you think you’ll switch to the Whipple now that it’s out?
  18. Oct 7, 2020 at 11:41 AM
    #168
    ViktorG
    Viktor
    Calgary, Canada
    No, I just dropped 6K (that took a long time to save up) on the Harrop and don’t have another 7K sitting around to go from a 2.65L to a 2.9L blower.
    Plus my blower is nowhere near maxed out yet.
    Harrop just announced they have the TVS3100 under development as well...
    GAknight, Saltyhero13 and Black Wolf like this.
  19. Oct 7, 2020 at 11:43 AM
    #169
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Good grief...
  20. Oct 7, 2020 at 11:46 AM
    #170
    Danimal86
    Daniel
    Sacramento, CA
    I tried to find info on the tvs3100 but didn't come up with anything. whats the difference with the new one, just more airflow?
  21. Oct 7, 2020 at 12:01 PM
    #171
    ViktorG
    Viktor
    Calgary, Canada
  22. Oct 7, 2020 at 12:13 PM
    #172
    TemujinNomad
    TemujinNomad New Member
    What would be your educated guess on how much power the tvs3100 could/will produce?
  23. Oct 7, 2020 at 4:05 PM
    #173
    ViktorG
    Viktor
    Calgary, Canada
    Over 1000 whp with the proper supporting mods (not on a 5.7L Tundra though).
    Wynnded and Black Wolf like this.
  24. Oct 7, 2020 at 4:20 PM
    #174
    Danimal86
    Daniel
    Sacramento, CA
    Dont tell me you've given up?
    Saltyhero13 and Filthyphil like this.
  25. Oct 7, 2020 at 4:21 PM
    #175
    Aurora CO
    It would be great once the Covid situation subsides you can get down here to Colorado and drag race your beast at Bandimere Race Track. :thumbsup: :benchpress::burnrubber:
    Next Summer! Bring a case of Cheezies....:anonymous:
  26. Oct 7, 2020 at 4:53 PM
    #176
    ViktorG
    Viktor
    Calgary, Canada
    My 1000 hp plan has always included a healthy shot of nitrous lol
    Filthyphil likes this.
  27. Oct 7, 2020 at 4:54 PM
    #177
    ViktorG
    Viktor
    Calgary, Canada
    I’m down!
    Wynnded and Black Wolf[QUOTED] like this.
  28. Oct 7, 2020 at 4:58 PM
    #178
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd show, if I'm free....
  29. Oct 7, 2020 at 5:01 PM
    #179
    Aurora CO
    Kuul. Us Colorado boys will be in force! Bandimere owners already got in trouble this summer for violating local Covid rules. Ha!
    Let's hope next summer will be a better new normal. Whatever the hell that is.......
  30. Oct 7, 2020 at 5:03 PM
    #180
    Aurora CO
    Pit crew should be covered.....maybe.....I'm volunteering for that!
