Installing Coachbuilder front shims on a 2017 pro?
Discussion in 'Ekstrom Design' started by jcgill1959, Mar 2, 2017.
  1. Mar 2, 2017 at 9:55 AM
    jcgill1959
    jcgill1959 [OP] New Member
    john
    Does anyone have instructions for installing Coachbuilder front shims on a 2017 pro?
    I think they could be a good Saturday project
  2. Mar 2, 2017 at 10:09 AM
    gosolo
    Ray
    NW Oregon
    There's no difference from the '15 or '16 Pro. There's also plenty of write ups. Have you tried doing a search?
    Helps to have a helper and helps if you have a lift. If you have both you can be done in an hour. Take it straight to get alignment done.
  3. Mar 2, 2017 at 10:11 AM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    831Tun likes this.
  4. Mar 2, 2017 at 10:18 AM
    Newm
    Newm New Member
    KC
  5. Mar 2, 2017 at 10:27 AM
    jcgill1959
    john
    Tried searching cant seem to find them. Tried "Install shims on tundra", "installing shims" and so on.
  6. Mar 2, 2017 at 1:27 PM
    gosolo
    Ray
    NW Oregon
    I tried to find links too, no luck. The link above seems to have good information. I'm sure that info is on here, maybe someday else will chime in
  7. Mar 2, 2017 at 1:38 PM
    Newm
    Newm New Member
    KC
    I am by no means a pro at this. In say that I believe the coilover has to come out. Once out the shims are placed on top of the coilover as pictured below...then just reinstalled. I believe the shims themselves have little notches or grooves in one side of them. they line up facing outward from the truck.
    Hope this helps...and someone please correct me if I am wrong.
  8. Mar 2, 2017 at 1:39 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Law323 likes this.
  9. Mar 2, 2017 at 2:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    @Newm they didn't come with instructions on how to line them up?
    either way, I do think the grooves line up facing forward from the frame. Not 100% sure though.
  10. Mar 2, 2017 at 2:18 PM
    Newm
    Newm New Member
    KC
    I'm not the OP...just trying to help so I don't have the directions and was going off fuzzy memory.
  11. Mar 2, 2017 at 2:20 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Doy my bad buddy. Was in the middle of working something out at work LOL brain fart
    Newm[QUOTED] likes this.
  12. Mar 2, 2017 at 2:29 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You have to take them off and put the shims on top of the coilovers then fasten them back on. Here's a link I followed the first time I put my spacers on. Fairly easy but time consuming and definitely get a buddy to help you. (It's for a spacer lift but process is exactly the same)
    https://youtu.be/3f-l6UZiLoY
  13. Mar 2, 2017 at 8:29 PM
    gosolo
    Ray
    NW Oregon
    I got mine in without removing the whole assembly. After disconnecting stuff I pried down with a bar and my bud slipped em in. Mine didn't have any notches that I saw either. We had it on the lift though. I got permission from our shop boss to use the one at work on a Saturday.
    Law323 likes this.
  14. Mar 2, 2017 at 8:40 PM
    Newm
    Newm New Member
    KC
    Below is a pic of the notch I was referring to.
  15. Mar 2, 2017 at 8:42 PM
    gosolo
    Ray
    NW Oregon
    David must have started adding the notches since I bought mine. They definitely did not have that notch. It would have been handy though! I did mine in 2015.
  16. Mar 3, 2017 at 3:21 AM
    jcgill1959
    john
    Thanks guys! seems simple, not as intense as I thought. I guess I'm joining the Coachbuilder Club !!!! cant wait to take the Camry size tires off the Pro. You guys rock ! and this forum really helps us" Less Knowledgeable" followers. 35 General Gabbers on 18" Methods from my 2013 rock warrior are going on the Pro.
    TUNDRA FOR LIFE :turtleride:
    831Tun and Law323 like this.
  17. Mar 3, 2017 at 3:41 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yeah, the notches stick out. See where on step 1 it says the key way faces out towards the wheel.
  18. Mar 3, 2017 at 3:42 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice trade! Been thinking of methods myself!
    Enjoy and have fun!!
  19. May 21, 2017 at 3:25 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Any chance you can post a pic of the instructions? I have the shims but don't remember getting them.
  20. May 21, 2017 at 3:39 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    hey go solo why don't you just tell the guy how to install the shims if you know how.
  21. May 21, 2017 at 4:15 PM
    gosolo
    Ray
    NW Oregon
    Remove the top nuts, remove the lower control arm bolt, remove the clips holding the brake line so it doesn't get stretched or torn, remove the sway bar nut and pop er loose. Pry down and slip the shims in, over the bolts. Make sure you know how they orient directionally and top side, cause you can only get em in one way.
    I tried to do these alone but couldn't do it. I had help and a lift.
    Let us know how it goes
    Coachbuilder1 likes this.
  22. May 21, 2017 at 8:31 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Thanks. Got one in on the driver side. Within 3/8" from the passenger side now :thumbsup:
    Coachbuilder1, gosolo and 831Tun like this.
  23. Dec 27, 2018 at 2:50 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    hey does the TRD PRO skid need to come off?
