Tailgate assist replacing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 88nitro305, May 8, 2019.
  1. May 8, 2019 at 7:29 PM
    88nitro305
    88nitro305 [OP] New Member
    Tom
    2015 Tundra CrewMax TRD Off-Road
    Looks like I’ll need to replace the piston that assist in the lowering of the tailgate.. I can’t find any videos.. Anyone guide me in the right direction?
    Rica25 likes this.
  2. May 8, 2019 at 7:34 PM
    n2deep
    n2deep Pavement Princess
    Super easy takes 5 min. Two screws to remove the driver taillight- it pulls straight out from the side not from the back. Remove the metal clips and replace.
    Rica25 and 88nitro305[OP] like this.
  3. May 8, 2019 at 7:35 PM
    88nitro305
    Tom
    Awesome! Thank you for that!
    Rica25 likes this.
  4. May 8, 2019 at 7:36 PM
    n2deep
    Just replaced mine yesterday
  5. Sep 3, 2020 at 3:07 PM
    pestman15
    pestman15 New Member
    How can you repair when the Back Door Stabilizer Joint is missing? Has anybody ever made that repair? The piston itself still works. Thank you in advance for any help.
    Rica25 likes this.
  6. Feb 16, 2021 at 2:09 PM
    Metecable
    Metecable New Member
    Jose
    2007 tundra crew
    Do you know the part number for the lift support?
    GTABurnout likes this.
  7. Feb 16, 2021 at 2:15 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    How much was this part??
  8. Sep 9, 2021 at 2:52 PM
    TLowgun
    TLowgun New Member
    Tony
    15 Tundra TRD
  9. Sep 25, 2021 at 3:53 PM
    TedFromOhio
    TedFromOhio New Member
    2013 Tundra
    I just replaced with the part from Rock Auto - super easy to replace but didn’t slow tailgate down as much as I expected. The one that added to my F250 lowers the tailgate very calmly - slow and easy. The Tundra drops pretty fast and still hits with a jolt. Is this normal? Thanks.
  10. Jan 5, 2022 at 2:18 AM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I'm wondering the same thing. What's the stock tailgate damper feel like? Does it control the tailgate drop without any human intervention or are you still expected to assist with the lowering?
    If I dont help it, mine drops pretty quickly then gets about two inches from the bottom, bounces back up a little, then settles slowly.
    TundraLLama likes this.
  11. Jan 5, 2022 at 4:25 AM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    I have the stock damper TG, 2021 SR5. I don’t have to guide it down at all, just let it go. Goes down smoother than Johnny Walker Blue.
  12. Jan 5, 2022 at 5:31 AM
    TedFromOhio
    2013 Tundra
    The one I added didn’t really make much of a difference. Not as happy with it as I would like.
  13. Jan 5, 2022 at 5:39 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I had to have my tailgate replaced and when I got it back it does that exact same thing. It wasn’t like that before it dropped very smoothly from the start. Looking to replace the damper I guess. Hope this part helps
  14. Jan 5, 2022 at 5:37 PM
    Tundra2Yak
    2016 1794 4x4 CM
    I'm going to see what the dealer says. Sounds like it should be covered under warranty.
    Doesnt bother me all that much but it would be neat to have hands free opening.
  15. May 4, 2022 at 4:31 AM
    HAGAR71
    HAGAR71 New Member
    2012 TUNDRA Ltd
    I just replace the shock and the arm to lower it on my 2012 tundra and it didn't help at all the tailgate drops very fast and hard I'm not happy with it is there anything on the 2012 that will work
  16. May 4, 2022 at 5:52 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    You probably need to replace the hinge too. The plastic bushing is prone to breaking.
    66102-0C021
