*HELP* Truck won’t start
Discussion in '2.5 Gen Tundras (2014-2021)' started by tbrown, Sep 3, 2020.
  1. Sep 3, 2020 at 9:30 AM
    tbrown
    tbrown [OP] 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Recently had fiberglass fenders and bedsides installed. Left there no problems. Out front and rear bumpers back on and wired up winch and lights, no problems. Plugged in. We lights for bumper last night, hit switch pros button, no light. Got up this morning to work on that, drove truck up to garage. Turned it off. Messed with wires, looked in fuse box. Saw nothing, so went to restart and this...wtf did I do now?
    https://youtu.be/D-E-aKc28Z8
  2. Sep 3, 2020 at 9:31 AM
    tbrown
    Nashville, TN
  3. Sep 3, 2020 at 9:34 AM
    somadbamos
    somadbamos Dude, you're being totally undude.
    Jake
    Idiot Out Wandering Around
    '14 Crewmax w/ Attitude
    Try disconnecting the battery and let sit for a bit.
  4. Sep 3, 2020 at 9:42 AM
    tbrown
    Nashville, TN
    tried with no luck :(
  5. Sep 3, 2020 at 9:43 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Sudden death of a Toyota battery?
  6. Sep 3, 2020 at 9:44 AM
    somadbamos
    Jake
    Bummer...maybe the starter relay?
  7. Sep 3, 2020 at 9:47 AM
    Bammer
    Monroe, CT
    That's what I was thinking.
  8. Sep 3, 2020 at 9:47 AM
    tbrown
    Nashville, TN
    its an optimal yellow top, could have killed it? Only 6 months old
  9. Sep 3, 2020 at 9:50 AM
    Bammer
    Monroe, CT
    I doubt it, Toyota brand batteries have a habit of giving up with no notice..
  10. Sep 3, 2020 at 9:52 AM
    timsp8
    NY
    Did you wire the switch pro to an ignition wire? Maybe something shorted out. Go in reverse of what you did before it stopped to look for the problem.
    tbrown[OP] likes this.
  11. Sep 3, 2020 at 10:50 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Optimas despise the heat, I killed 3 (yellow) within 18 months, and Pep boys refused to swap to a 4th one without authorization from Optima.. which they also declined, so I went back to over the counter batteries... The base I was stationed at also ditched the red tops due to poor reliability in the middle of the desert in favor of more reliable batteries...
  12. Sep 3, 2020 at 10:56 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Cranks strong. Not a battery or relay issue.
    Honestly, I'd go back and check the fuse box. I was doing work on my truck and stuck a fuse back in the wrong location. It's easy to do on our trucks because you're looking at the fuse box upside down.
  13. Sep 3, 2020 at 11:21 AM
    GratefulDean
    GratefulDean Swagless
    Dean
    Rocky Mountains
    2020 Tundra SR5 TRD in Cement Grey
    Bed Rack, Decked System, Softopper
    I wonder if its a security/ignition issue.
  14. Sep 3, 2020 at 11:23 AM
    tbrown
    Nashville, TN
    It was a fuse tap with a blown fuse, back up and running!
